RPI4 Raspbian 64 bit & LinuxCNC
3 years 1 month ago #280432 by rodw
Thanks Andy, after reading the link,  the build installs the gpiod-dev package but does not include the gpiod package So it can't be a dependency of linuxcnc-uspace
Try: sudo apt install gpiod
Can the linuxcnc deb build include it as a dependency for ARM64 Architecture?
3 years 1 month ago #280434 by Cant do this anymore bye all
I was under the impression that if a deb package was built against a certain library dev package that the library package was automatically included as a dependency.
3 years 1 month ago #280436 by rodw
Only if the dependencies are listed in the debian control file by the developer of the .deb file
I'm not sure if dependencies can be specified for specific architectures
I think I did a bit of a package search on the debian site and decided to add gpiod-dev to the builder,  but left gpiod out. I'll add it back in.
There are probably a few more that will come to light.
3 years 1 month ago - 3 years 1 month ago #280452 by Donno
gpioinfo gives output i can read and write GPIO pins in terminal.
Did you remember to add the hal_gipo read and write functions to a thread?
Can you please show example ?
Last edit: 3 years 1 month ago by Donno.
3 years 1 month ago #280464 by andypugh
libgpiod-dev has libgpiod2 as a dependency:
packages.debian.org/stable/libdevel/libgpiod-dev
But that does not appear to have a dependency on gpiod.
This might not be a problem, as I think that goiod is just the package that includes the tools (like gpioinfo) and isn't necessary for the library code to work.
3 years 1 month ago #280465 by andypugh
addf hal_gpio.read base-thread addf hal_gpio.write base-thread addf hal_gpio.reset base-thread
Time to create page: 0.276 seconds
