- Thank you received: 280
They were pretty much the same,like underwhelmingly the same. pretty much the same as the previous 4.19.70something 4gb ram. I thought maybe between all the images i had saved, older or newers would be faster, but with vanilla settings they are all pretty close to the same. I tested elovalvo's 32bit 5.4 kernel and the 3gb 4.19 kernel official image side by side with 4gb and 8gb units. The only real difference I noticed was the ram, but i didnt dive to deep into the kernel config or anything. I have it loaded on my test unit and it preforms as expected aside for some reason I can only ever use 25% cpu usage, like when using make -j4. I forgot about that until just now.How do these compare with the "official" images for latency?
In this case, you must verify that a hal_pi_gpio module works because the Pi400 (6) version is not included in the source code.andypugh wrote: I can try it on the Pi400. (if I remember)
I don't think so, because I compiled the patch for the runtime with the bcm2711_defconfig option.andypugh wrote: Would you expect it to work on the Pi3?
I followed the steps in the first post of this thread.andypugh wrote: How did you make the images?
I have not installed the official releases at this time.andypugh wrote: How do these compare with the "official" images for latency?
Just tell me which version you need and I'll be happy to prepare itandypugh wrote: I make the "official" images. I would be more than happy to pass that task on.
tjtr33 wrote: Why is 80 'sweet'?
