RPI4 Raspbian 64 bit & LinuxCNC
5 years 10 months ago #191083 by PCW
Replied by PCW on topic RPI4 Raspbian 64 bit & LinuxCNC
Do you have 8G of RAM? There's a known USB issue with
that version. I think it needs a newer kernel than on the LinuxCNC
image.
5 years 10 months ago #191108 by JackRay
Hello ,
No I have 2Go of RAM
5 years 10 months ago #191109 by Mud
Replied by Mud on topic RPI4 Raspbian 64 bit & LinuxCNC
I'm tempted to pick one up - which version do people recommend?
5 years 10 months ago #191117 by JackRay
I do not know at all .
You think that the difference of "Ram" can have a difference to such an extent that the raspberry remains blocked?
5 years 10 months ago #191118 by snowgoer540
Mud wrote: I'm tempted to pick one up - which version do people recommend?
I used the 4gb version
The following user(s) said Thank You: Mud
5 years 10 months ago - 5 years 10 months ago #191226 by elovalvo
JackRay wrote: Hello ,
i built on u amd64 linuxcnc 2.9pre with switch kin branch. It works very well.
Now i want to make it all work on raspberry pi4
I'm trying to install a 64-bit Kernel Preemt-rt on my RaspPi4.
: www.instructables.com/64bit-RT-Kernel-Co...or-Raspberry-Pi-4B-/
works well, until the moment when it no longer happens on a simple file copy.
Can you help me please because I am not very easy in the matter.
thank you so much
The boot directory in rt-kernel is probably missing.
run this commands:
mkdir ~/rpi-kernel/rt-kernel
mkdir ~/rpi-kernel/rt-kernel/boot
Last edit: 5 years 10 months ago by elovalvo.
Time to create page: 0.173 seconds
