RPI4 Raspbian 64 bit & LinuxCNC
6 years 1 month ago #181542 by phillc54
I use it on a hobby plasma table.
This guy uses one on a mill:
The following user(s) said Thank You: elovalvo, AgentWD40
6 years 1 month ago - 6 years 1 month ago #181585 by elovalvo
Taking into account the recent update (24/8/2020) of the RaspiOS_arm64,
RaspioOS_64
I redone the Raspbian 64bit RT-Preempt kernel (vers. 5.4.61_rt37) downloadable to this link
and also the arm64 versions of LinuxCNC (2.8.0 e 2.9.0pre0) downloadable at this link.
LinuxCNC 2.8.0 arm64
LinuxCNC 2.9.0.pre0 arm64
For installation the instructions are the same as those in the my first message of this thread.
Last edit: 6 years 1 month ago by elovalvo.
The following user(s) said Thank You: phillc54, tjmarch, Freak, AgentWD40, COFHAL, rdtsc
6 years 1 month ago #181654 by knirps
Hi elovalvo,
thanks a lot for your work! I tried your release from today morning.
Without any glxgears running it look quite good (still not so good as phillc54's):
But as soon as I start 10 glx gears it look much worse:
I installed according to your description
Linux raspberrypi 5.4.61-rt37-v8+ #1 SMP PREEMPT_RT Wed Sep 9 18:58:22 CEST 2020 aarch64 GNU/Linux
cat /boot/cmdline.txt
console=serial0,115200 console=tty1 root=PARTUUID=60687991-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles processor.max_cstate=1 isolcpus=2,3
any ideas?
The following user(s) said Thank You: elovalvo, wiremonkey, rdtsc
6 years 1 month ago #181682 by tommylight
knirps wrote: any ideas?
Yes, that is still very good latency.
6 years 1 month ago #182331 by phillc54
knirps wrote: Hi elovalvo,
This is mine with 10 Glxgears after a couple of days. It had a couple of odd spikes but perfectly adequate for my machine which has a Mesa 7i96 and a 2mS servo thread.
This using the ISO from the LinuxCNC website without any modification:
www.linuxcnc.org/iso/
It has isolcpus=3 in /boot/cmcline.txt
6 years 1 month ago #183178 by Bari
Anyone have latency test results with the above 64b kernel with a browser open and playing back a youtube video?
We found that the integrated GPU is the real time killer. We might try using a USB GPU and see how it effects the jitter.
Time to create page: 0.264 seconds
