RPI4 Raspbian 64 bit & LinuxCNC
5 years 6 months ago - 5 years 6 months ago #206760 by tjtr33
Thx Andy :-)
also
i ran a 50uS base thread ( still running)
and have max latency 28.7
i did change the environment in that i setup Samco's suggested ntp fix.
lateny-histogram --base 50000 --servo 1000000, with 4 glxgears
isolcpus=1,2,3 idle=poll
over 17hrs now
tjtr33
Last edit: 5 years 6 months ago by tjtr33.
5 years 5 months ago #207865 by Craig E
A total newbie I am trying to install this on a new PI 4b 8G
I get to here and it cannot find this file
git clone github.com/LinuxCNC/linuxcnc.git emc
Then I am done.
What am I doing wrong? any help is greatly appreciated
5 years 5 months ago - 5 years 5 months ago #207883 by andypugh
Try
git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
(It might well be that the command that you copied was munged by the auto-linking feature of the forum, where did you find it? )
Last edit: 5 years 5 months ago by andypugh.
5 years 5 months ago #207952 by Craig E
Thanks Andy,
I am following the procedure at the top of this string.
Your command worked but stopped on the next command after that. Below is the whats left for me to follow.
I am totally new to both LinuxCNC and Rpi4 but I was able to install the 64bit OS and the Real time Kernel rt64-kernel.tgz.
I am stuck on building LinuxCNC for PRI4 64 bit and installing it.
Below is where it all ended for me.
cd emc
debian/configure uspace
dpkg-checkbuilddeps
debuild -uc -us
cd ..
The .debs file can be also download from this link:
LinuxCNC_64bit.zip
Installing LinuxCNC:
cd ~/
wget ftp.it.debian.org/debian/pool/main/p/pyg...2_2.10.1-3_arm64.deb
sudo dpkg -i python-gtksourceview2_2.10.1-3_arm64.deb
sudo apt --fix-broken install
sudo gdebi linuxcnc-uspace_2.9.0~pre0_arm64.deb
sudo gdebi linuxcnc-uspace-dev_2.9.0~pre0_arm64.deb
sudo gdebi linuxcnc-doc-en_2.9.0~pre0_all.deb
5 years 5 months ago #207965 by elovalvo
If you followed Andy's command, the following command must move you to a new directory called 'linuxcnc-dev'
So the 'cd emc' command becomes 'cd linuxcnc-dev'
Also be careful that the command
will have to be fully extended to
wget ftp.it.debian.org/debian/pool/main/p/python-gtksourceview2_2.10.1-3_arm64.deb
5 years 5 months ago #207967 by Craig E
Thanks that worked but now I am getting this error
dpkg-checkbuilddeps
dpkg-checkbuilddeps: error: Unmet build dependencies: debhelper (>= 6) libudev-dev tcl8.6-dev tk8.6-dev libreadline-gplv2-dev asciidoc (>= 8.5) dblatex (>= 0.2.12) docbook-xsl dvipng ghostscript graphviz groff imagemagick inkscape python-lxml source-highlight w3c-linkchecker xsltproc texlive-extra-utils texlive-font-utils texlive-fonts-recommended asciidoc-dblatex libxmu-dev libglu1-mesa-dev libgl1-mesa-dev | libgl1-mesa-swx11-dev libgtk2.0-dev intltool autoconf libboost-python-dev netcat libtirpc-dev
I am assuming that these did not load correctly up in the build Phase I did get some files not found notes but no errors that I can remember
Time to create page: 0.172 seconds
