other Approachs to install Linuxcnc
- anfänger
- Thank you received: 267
02 Sep 2020 11:14 - 02 Sep 2020 11:19 #180414
by anfänger
Replied by anfänger on topic other Approachs to install Linuxcnc
Yes this is also possible (dd is your friend)
You can also put the boot image on a hard drive. I did that a long time ago it’s the same process for a usb disc and a hard drive when using a Linux machine. Even with Mac it should be the same.
Last edit: 02 Sep 2020 11:19 by anfänger.
- Thank you received: 7490
02 Sep 2020 11:39 #180418
Replied by tommylight on topic other Approachs to install Linuxcnc
Yes it is possible but will last much longer than doing a fresh install, much much longer as DD copies everything, even the empty space on the drives.Yes this is also possible (dd is your friend)
- BeagleBrainz
- Visitor
02 Sep 2020 12:12 #180421
by BeagleBrainz
Replied by BeagleBrainz on topic other Approachs to install Linuxcnc
Clonezilla is an option, but an initial install is still required & if you can't boot the target system via cd\dvd\usb you still need to do everything on a 2nd machine. And for a one it's a lot of work, far more than doing an install and transferring the drive from one machine to another.
- anfänger
02 Sep 2020 12:13 #180422
by anfänger
I know I just wanted to say it is possible.
If I can’t boot from USB but have access to the hard drive I would install it on another computer and move the HD or make a 2nd hard drive with the install media.
But If I have another machine already running Linuxcnc and want to clone everything I would give DD a chance
Cause remembering alle packages I need to install later and compiling come other stuff, failing installing other packages trying again, also takes time
- BeagleBrainz
- Visitor
02 Sep 2020 12:23 #180424
by BeagleBrainz
Clonezilla is a hell of a lot quicker than using dd.
You can do a disc to disc clone. Doing it this way doesn't give you a image you can backup.
A disc to image then to disc clone. This way does give you an image you can use multiple times.
- anfänger
02 Sep 2020 12:34 - 02 Sep 2020 12:35 #180426
by anfänger
Maybe I am to old scool here. I was a regular Linux user 15 years ago the I switched to mac and stopped playing around with computers (had something to do with getting a job).
It was when I started using LinuxCNC four years ago i used Linux again. But only for my CNC. I am happy many of the old stuff still works.
Last edit: 02 Sep 2020 12:35 by anfänger.
02 Sep 2020 13:29 #180431
Clonezilla uses DD to do it's thing, but id does skip the empty sectors, so it is much faster.
- Mike_Eitel
- Thank you received: 183
03 Sep 2020 04:50 #180492
by Mike_Eitel
Replied by Mike_Eitel on topic other Approachs to install Linuxcnc
Why not use balena etcher, that is cross platform.
I do lots of different iso to sd/ssd. Never had a non booting that way.
m5c.
Mike
m5c.
Mike
