10.04 live cd no Realtime
- blazedforever
hans@CnC:~$ sudo emc
EMC2 - 2.4.3
Machine configuration directory is '/home/hans/emc2/configs/my-mill'
Machine configuration file is 'my-mill.ini'
Starting EMC2...
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
Realtime system did not load
Shutting down and cleaning up EMC2...
RTAPI: ERROR: could not open shared memory (errno=2)
RTAPI: Locked memory limit is 64KiB, recommended at least 20480KiB.
This can cause the error 'could not open shared memory'.
For more information, see
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?LockedMemory
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Cleanup done
EMC terminated with an error. You can find more information in the log:
/home/hans/emc_debug.txt
and
/home/hans/emc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
(Your second sentence suggests that you have, I am just trying to be clear)
Not that that should be necessary on a fresh, LiveCD install.
- blazedforever
limits.conf :
# /etc/security/limits.conf
#Each line describes a limit for a user in the form:
#<domain> <type> <item> <value>
#Where:
#<domain> can be:
# - an user name
# - a group name, with @group syntax
# - the wildcard *, for default entry
# - the wildcard %, can be also used with %group syntax,
# for maxlogin limit
# - NOTE: group and wildcard limits are not applied to root.
# To apply a limit to the root user, <domain> must be
# the literal username root.
#<type> can have the two values:
# - "soft" for enforcing the soft limits
# - "hard" for enforcing hard limits
#<item> can be one of the following:
# - core - limits the core file size (KB)
# - data - max data size (KB)
# - fsize - maximum filesize (KB)
# - memlock - max locked-in-memory address space (KB)
# - nofile - max number of open files
# - rss - max resident set size (KB)
# - stack - max stack size (KB)
# - cpu - max CPU time (MIN)
# - nproc - max number of processes
# - as - address space limit (KB)
# - maxlogins - max number of logins for this user
# - maxsyslogins - max number of logins on the system
# - priority - the priority to run user process with
# - locks - max number of file locks the user can hold
# - sigpending - max number of pending signals
# - msgqueue - max memory used by POSIX message queues (bytes)
# - nice - max nice priority allowed to raise to values: [-20, 19]
# - rtprio - max realtime priority
# - chroot - change root to directory (Debian-specific)
#* soft core 0
#root hard core 100000
#* hard rss 10000
#@student hard nproc 20
#@faculty soft nproc 20
#@faculty hard nproc 50
#ftp hard nproc 0
#ftp - chroot /ftp
#@student - maxlogins 4
# End of file
* - memlock 20480 #EMC2
hans@CnC:~$ sudo /etc/init.d/realtime start
I updated the rt kernel via synaptic thats why the version shows as realtime-2.6.32-122-rtai, had the same error before the update.
- Mike_Eitel
- Thank you received: 185
Update had ...rtai--- problem.
decided to setup completly new by 10.4 iso.
Can not run emc2 ( see above )
decidet to go back to 8.04 and wait some time for bugfix before for next try
Mike
#* soft core 0
[/quote]
I am not sure that the format "* - memlock 20480" is valid, it doesn't match the file comments.
I wonder if it is worth trying
* hard memlock 20480
( and possibly also * soft memlock 20480 )
Ignore that, linux.die.net/man/5/limits.conf says that "-" means "hard" and "soft" at the same time.
Bugfixes don't happen automatically for problems not seen by the developers. It might be worth adding a bug report at
sourceforge.net/tracker/?atid=106744&group_id=6744&func=browse
Is the problem with existing configs, or do the sample configs not work either?
- Mike_Eitel
I have alread reinstalled back to 8.04
It's running on an old 650mHz pentium with 320mb
I installed new from CD, than updated via www.
same to emc2 .4 = latest
Tried to runt he sim-axis-mm No startup.
No emc but rtai .... errors ...
Decided too hard problem for me to solve
Tried to see the second parport... also no succes, but wrong-directory errors from manifacturers CD.
decided to solve one problem by the other = reinstall... Maybee PC is too old for 10.04..
Sorry
P.S.
In the moment I'm trying to get a second (cheep china ) parport running, for a luxury jog whell .
I wan't to have A / B, 4 axis and 4 speed buttons as inputs and 4 led's as choosen-axis- feedback.
- blazedforever
Regards,
Alex
