10.04 live cd no Realtime
- blazedforever
Not sure what to look for here but this is the output of dmesg:
hans@CnC ~ $ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001ffeb000 (usable)
[ 0.000000] BIOS-e820: 000000001ffeb000 - 000000001ffef000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001ffef000 - 000000001ffff000 (reserved)
[ 0.000000] BIOS-e820: 000000001ffff000 - 0000000020000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x1ffeb max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 0F8000000 mask FFC000000 write-combining
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001ffeb000 (usable)
[ 0.000000] modified: 000000001ffeb000 - 000000001ffef000 (ACPI data)
[ 0.000000] modified: 000000001ffef000 - 000000001ffff000 (reserved)
[ 0.000000] modified: 000000001ffff000 - 0000000020000000 (ACPI NVS)
[ 0.000000] modified: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001ffeb000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001ffeb000 page 4k
[ 0.000000] kernel direct mapping tables up to 1ffeb000 @ 7000-c000
[ 0.000000] RAMDISK: 1735d000 - 1802ffe3
[ 0.000000] ACPI: RSDP 000f7850 00014 (v00 ASUS )
[ 0.000000] ACPI: RSDT 1ffeb000 0002C (v01 ASUS CUSL2-C 30303031 MSFT 31313031)
[ 0.000000] ACPI: FACP 1ffeb080 00074 (v01 ASUS CUSL2-C 30303031 MSFT 31313031)
[ 0.000000] ACPI: DSDT 1ffeb100 03535 (v01 ASUS CUSL2-C 00001000 MSFT 0100000B)
[ 0.000000] ACPI: FACS 1ffff000 00040
[ 0.000000] ACPI: BOOT 1ffeb040 00028 (v01 ASUS CUSL2-C 30303031 MSFT 31313031)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 511MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1ffeb000
[ 0.000000] low ram: 0 - 1ffeb000
[ 0.000000] node 0 low ram: 00000000 - 1ffeb000
[ 0.000000] node 0 bootmap 00008000 - 0000c000
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001ffeb000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [001735d000 - 001802ffe3] RAMDISK ==> [001735d000 - 001802ffe3]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b414c] BRK ==> [00008b1000 - 00008b414c]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000c000] BOOTMAP ==> [0000008000 - 000000c000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001ffeb
[ 0.000000] HighMem 0x0001ffeb -> 0x0001ffeb
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001ffeb
[ 0.000000] On node 0 totalpages: 130950
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 125963 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0xe408
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dff80000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129926
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=22270de5-e187-415d-9ecf-425d694af6cb ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2621020 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 495240k/524204k available (4539k kernel code, 28204k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe07eb000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdffeb000 ( 511 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1035.205 MHz processor.
[ 0.008022] Calibrating delay loop (skipped), value calculated using timer frequency.. 2070.41 BogoMIPS (lpj=4140820)
[ 0.008071] Security Framework initialized
[ 0.008139] AppArmor: AppArmor initialized
[ 0.008159] Mount-cache hash table entries: 512
[ 0.008474] Initializing cgroup subsys ns
[ 0.008485] Initializing cgroup subsys cpuacct
[ 0.008497] Initializing cgroup subsys memory
[ 0.008521] Initializing cgroup subsys devices
[ 0.008529] Initializing cgroup subsys freezer
[ 0.008536] Initializing cgroup subsys net_cls
[ 0.008587] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.008596] CPU: L2 cache: 256K
[ 0.008608] mce: CPU supports 5 MCE banks
[ 0.008645] Performance Events:
[ 0.008652] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.008659] no hardware sampling interrupt available.
[ 0.008665] p6 PMU driver.
[ 0.008698] ... version: 0
[ 0.008703] ... bit width: 32
[ 0.008709] ... generic registers: 2
[ 0.008715] ... value mask: 00000000ffffffff
[ 0.008721] ... max period: 000000007fffffff
[ 0.008728] ... fixed-purpose events: 0
[ 0.008733] ... event mask: 0000000000000003
[ 0.008747] Checking 'hlt' instruction... OK.
[ 0.025488] SMP alternatives: switching to UP code
[ 0.034954] Freeing SMP alternatives: 31k freed
[ 0.034998] ACPI: Core revision 20090903
[ 0.043508] ACPI: setting ELCR to 0200 (from 0e20)
[ 0.043636] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.043655] ftrace: allocating 21003 entries in 42 pages
[ 0.057849] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.057863] weird, boot CPU (#0) not listed by the BIOS.
[ 0.057868] SMP motherboard not detected.
[ 0.057875] Local APIC not detected. Using dummy APIC emulation.
[ 0.057880] SMP disabled
[ 0.058538] Brought up 1 CPUs
[ 0.058553] Total of 1 processors activated (2070.41 BogoMIPS).
[ 0.059344] CPU0 attaching NULL sched-domain.
[ 0.059724] devtmpfs: initialized
[ 0.060692] regulator: core version 0.5
[ 0.060836] NET: Registered protocol family 16
[ 0.061348] EISA bus registered
[ 0.061369] ACPI: bus type pci registered
[ 0.062542] PCI: PCI BIOS revision 2.10 entry at 0xf0df0, last bus=2
[ 0.062549] PCI: Using configuration type 1 for base access
[ 0.064715] bio: create slab <bio-0> at 0
[ 0.065887] ACPI: EC: Look up EC in DSDT
[ 0.075101] ACPI: Interpreter enabled
[ 0.075109] ACPI: (supports S0 S5)
[ 0.075136] ACPI: Using PIC for interrupt routing
[ 0.096468] ACPI: No dock devices found.
[ 0.096740] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.096840] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xf8000000-0xfbffffff]
[ 0.097266] pci 0000:00:1f.0: quirk: region e400-e47f claimed by ICH4 ACPI/GPIO/TCO
[ 0.097276] pci 0000:00:1f.0: quirk: region ec00-ec3f claimed by ICH4 GPIO
[ 0.097331] pci 0000:00:1f.1: reg 20 io port: [0xb800-0xb80f]
[ 0.097402] pci 0000:00:1f.2: reg 20 io port: [0xb400-0xb41f]
[ 0.097471] pci 0000:00:1f.3: reg 20 io port: [0xe800-0xe80f]
[ 0.097540] pci 0000:00:1f.4: reg 20 io port: [0xb000-0xb01f]
[ 0.097614] pci 0000:01:00.0: reg 10 32bit mmio: [0xf4000000-0xf4ffffff]
[ 0.097627] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xf6000000-0xf7ffffff]
[ 0.097655] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xf5ff0000-0xf5ffffff]
[ 0.097728] pci 0000:00:01.0: bridge 32bit mmio: [0xf4000000-0xf5dfffff]
[ 0.097738] pci 0000:00:01.0: bridge 32bit mmio pref: [0xf5f00000-0xf7ffffff]
[ 0.097799] pci 0000:02:0a.0: reg 10 io port: [0xd800-0xd81f]
[ 0.097852] pci 0000:02:0a.0: supports D1 D2
[ 0.097897] pci 0000:02:0a.1: reg 10 io port: [0xd400-0xd407]
[ 0.097950] pci 0000:02:0a.1: supports D1 D2
[ 0.098001] pci 0000:02:0b.0: reg 10 32bit mmio: [0xf3800000-0xf380ffff]
[ 0.098079] pci 0000:02:0c.0: reg 10 io port: [0xd000-0xd0ff]
[ 0.098092] pci 0000:02:0c.0: reg 14 32bit mmio: [0xf3000000-0xf30000ff]
[ 0.098156] pci 0000:00:1e.0: transparent bridge
[ 0.098166] pci 0000:00:1e.0: bridge io port: [0xc000-0xdfff]
[ 0.098175] pci 0000:00:1e.0: bridge 32bit mmio: [0xf3000000-0xf3ffffff]
[ 0.098185] pci 0000:00:1e.0: bridge 32bit mmio pref: [0xf5e00000-0xf5efffff]
[ 0.098204] pci_bus 0000:00: on NUMA node 0
[ 0.098215] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.098384] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.098482] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.160233] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[ 0.160482] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[ 0.160692] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.160940] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[ 0.161185] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.161394] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[ 0.161642] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.161888] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[ 0.162172] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.162184] vgaarb: loaded
[ 0.162540] SCSI subsystem initialized
[ 0.162754] libata version 3.00 loaded.
[ 0.163165] usbcore: registered new interface driver usbfs
[ 0.163199] usbcore: registered new interface driver hub
[ 0.163283] usbcore: registered new device driver usb
[ 0.163635] ACPI: WMI: Mapper loaded
[ 0.163641] PCI: Using ACPI for IRQ routing
[ 0.163962] NetLabel: Initializing
[ 0.163968] NetLabel: domain hash size = 128
[ 0.163973] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.164038] NetLabel: unlabeled traffic allowed by default
[ 0.164132] Switching to clocksource tsc
[ 0.169395] AppArmor: AppArmor Filesystem Enabled
[ 0.169454] pnp: PnP ACPI init
[ 0.169505] ACPI: bus type pnp registered
[ 0.176983] pnp: PnP ACPI: found 13 devices
[ 0.176992] ACPI: ACPI bus type pnp unregistered
[ 0.177004] PnPBIOS: Disabled by ACPI PNP
[ 0.177033] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.177042] system 00:00: iomem range 0xf0000-0xfffff could not be reserved
[ 0.177052] system 00:00: iomem range 0x100000-0x1fffffff could not be reserved
[ 0.177061] system 00:00: iomem range 0xffb80000-0xffbfffff has been reserved
[ 0.177070] system 00:00: iomem range 0xfff80000-0xffffffff has been reserved
[ 0.177090] system 00:02: ioport range 0x3f0-0x3f1 has been reserved
[ 0.177099] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.177115] system 00:03: ioport range 0xe400-0xe47f has been reserved
[ 0.177124] system 00:03: ioport range 0xec00-0xec3f has been reserved
[ 0.212160] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.212167] pci 0000:00:01.0: IO window: disabled
[ 0.212178] pci 0000:00:01.0: MEM window: 0xf4000000-0xf5dfffff
[ 0.212188] pci 0000:00:01.0: PREFETCH window: 0xf5f00000-0xf7ffffff
[ 0.212203] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.212212] pci 0000:00:1e.0: IO window: 0xc000-0xdfff
[ 0.212222] pci 0000:00:1e.0: MEM window: 0xf3000000-0xf3ffffff
[ 0.212232] pci 0000:00:1e.0: PREFETCH window: 0xf5e00000-0xf5efffff
[ 0.212257] pci 0000:00:01.0: setting latency timer to 64
[ 0.212270] pci 0000:00:1e.0: setting latency timer to 64
[ 0.212283] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.212291] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.212299] pci_bus 0000:01: resource 1 mem: [0xf4000000-0xf5dfffff]
[ 0.212307] pci_bus 0000:01: resource 2 pref mem [0xf5f00000-0xf7ffffff]
[ 0.212315] pci_bus 0000:02: resource 0 io: [0xc000-0xdfff]
[ 0.212322] pci_bus 0000:02: resource 1 mem: [0xf3000000-0xf3ffffff]
[ 0.212330] pci_bus 0000:02: resource 2 pref mem [0xf5e00000-0xf5efffff]
[ 0.212337] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.212345] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.212449] NET: Registered protocol family 2
[ 0.212707] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.213484] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.213815] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.214188] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.214198] TCP reno registered
[ 0.214545] NET: Registered protocol family 1
[ 0.214676] pci 0000:01:00.0: Boot video device
[ 0.214946] Simple Boot Flag at 0x3a set to 0x1
[ 0.215193] Scanning for low memory corruption every 60 seconds
[ 0.215541] audit: initializing netlink socket (disabled)
[ 0.215577] type=2000 audit(1284177956.211:1): initialized
[ 0.233959] Trying to unpack rootfs image as initramfs...
[ 0.256133] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.263883] VFS: Disk quotas dquot_6.5.2
[ 0.264150] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.265997] fuse init (API version 7.13)
[ 0.266272] msgmni has been set to 968
[ 0.272443] alg: No test for stdrng (krng)
[ 0.272629] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.272638] io scheduler noop registered
[ 0.272643] io scheduler anticipatory registered
[ 0.272649] io scheduler deadline registered
[ 0.272788] io scheduler cfq registered (default)
[ 0.273078] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.273139] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.273322] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.273333] ACPI: Power Button [PWRB]
[ 0.273483] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.273491] ACPI: Power Button [PWRF]
[ 0.277200] isapnp: Scanning for PnP cards...
[ 0.283176] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.283344] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.283493] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.284215] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.284427] 00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.285443] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 9
[ 0.285451] PCI: setting IRQ 9 as level-triggered
[ 0.285462] serial 0000:02:0b.0: PCI INT A -> Link[LNKH] -> GSI 9 (level, low) -> IRQ 9
[ 0.285478] serial 0000:02:0b.0: PCI INT A disabled
[ 0.341105] brd: module loaded
[ 0.342427] loop: module loaded
[ 0.342754] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.343068] ata_piix 0000:00:1f.1: version 2.13
[ 0.343230] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.343501] scsi0 : ata_piix
[ 0.343863] scsi1 : ata_piix
[ 0.345407] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xb800 irq 14
[ 0.345416] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xb808 irq 15
[ 0.346435] Fixed MDIO Bus: probed
[ 0.346530] PPP generic driver version 2.4.2
[ 0.346697] tun: Universal TUN/TAP device driver, 1.6
[ 0.346703] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.346949] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.346995] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.347028] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.352950] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[ 0.352963] PCI: setting IRQ 5 as level-triggered
[ 0.352975] uhci_hcd 0000:00:1f.2: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.352997] uhci_hcd 0000:00:1f.2: setting latency timer to 64
[ 0.353006] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 0.353237] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[ 0.353286] uhci_hcd 0000:00:1f.2: irq 5, io base 0x0000b400
[ 0.353588] usb usb1: configuration #1 chosen from 1 choice
[ 0.353663] hub 1-0:1.0: USB hub found
[ 0.353690] hub 1-0:1.0: 2 ports detected
[ 0.353811] uhci_hcd 0000:00:1f.4: PCI INT C -> Link[LNKH] -> GSI 9 (level, low) -> IRQ 9
[ 0.353828] uhci_hcd 0000:00:1f.4: setting latency timer to 64
[ 0.353836] uhci_hcd 0000:00:1f.4: UHCI Host Controller
[ 0.353939] uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 2
[ 0.353975] uhci_hcd 0000:00:1f.4: irq 9, io base 0x0000b000
[ 0.354226] usb usb2: configuration #1 chosen from 1 choice
[ 0.354294] hub 2-0:1.0: USB hub found
[ 0.354318] hub 2-0:1.0: 2 ports detected
[ 0.354532] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.354539] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.355513] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.360699] mice: PS/2 mouse device common for all mice
[ 0.361083] rtc_cmos 00:05: RTC can wake from S4
[ 0.361234] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.361270] rtc0: alarms up to one month, 242 bytes nvram
[ 0.361569] device-mapper: uevent: version 1.0.3
[ 0.361939] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.362130] device-mapper: multipath: version 1.1.0 loaded
[ 0.362139] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.368236] EISA: Probing bus 0 at eisa.0
[ 0.368276] EISA: Detected 0 cards.
[ 0.368284] cpuidle: using governor ladder
[ 0.368291] cpuidle: using governor menu
[ 0.369508] TCP cubic registered
[ 0.369956] NET: Registered protocol family 10
[ 0.371162] lo: Disabled Privacy Extensions
[ 0.372106] NET: Registered protocol family 17
[ 0.372197] Using IPI No-Shortcut mode
[ 0.372470] registered taskstats version 1
[ 0.372867] rtc_cmos 00:05: setting system clock to 2010-09-11 04:05:56 UTC (1284177956)
[ 0.372876] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.372881] EDD information not available.
[ 0.540441] ata2.00: ATAPI: LG CD-RW CED-8120B, 1.02, max MWDMA2
[ 0.540532] ata2.01: ATAPI: Pioneer DVD-ROM ATAPIModel DVD-116 0107, E1.07, max UDMA/66
[ 0.540606] ata2.01: limited to UDMA/33 due to 40-wire cable
[ 0.556202] ata2.00: configured for MWDMA2
[ 0.572193] ata2.01: configured for UDMA/33
[ 0.624688] ata1.00: ATA-6: ST340014A, 3.06, max UDMA/100
[ 0.624700] ata1.00: 78165360 sectors, multi 16: LBA48
[ 0.640318] ata1.00: configured for UDMA/100
[ 0.707803] usb 1-1: new low speed USB device using uhci_hcd and address 2
[ 0.970448] isapnp: No Plug & Play device found
[ 0.970864] scsi 0:0:0:0: Direct-Access ATA ST340014A 3.06 PQ: 0 ANSI: 5
[ 0.971303] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.971765] sd 0:0:0:0: [sda] 78165360 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 0.971914] sd 0:0:0:0: [sda] Write Protect is off
[ 0.971923] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.971995] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.972443] sda:
[ 0.972699] scsi 1:0:0:0: CD-ROM LG CD-RW CED-8120B 1.02 PQ: 0 ANSI: 5
[ 0.977550] usb 1-1: configuration #1 chosen from 1 choice
[ 0.980165] sr0: scsi3-mmc drive: 24x/32x writer cd/rw xa/form2 cdda tray
[ 0.980206] Uniform CD-ROM driver Revision: 3.20
[ 0.980524] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.980711] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 0.983801] scsi 1:0:1:0: CD-ROM PIONEER DVD-ROM DVD-116 1.07 PQ: 0 ANSI: 5
[ 0.989917] sr1: scsi3-mmc drive: 40x/40x cd/rw xa/form2 cdda tray
[ 0.990247] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 0.990421] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 0.991584] sda1 sda2 < sda5 >
[ 1.018611] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.494352] Freeing initrd memory: 13131k freed
[ 1.550428] Freeing unused kernel memory: 620k freed
[ 1.553203] Write protecting the kernel text: 4540k
[ 1.553278] Write protecting the kernel read-only data: 1668k
[ 1.616808] udev: starting version 151
[ 2.206584] Linux agpgart interface v0.103
[ 2.229697] Floppy drive(s): fd0 is 1.44M
[ 2.251958] FDC 0 is a post-1991 82077
[ 2.325572] usbcore: registered new interface driver hiddev
[ 2.326840] usbcore: registered new interface driver usbhid
[ 2.327135] usbhid: v2.6:USB HID core driver
[ 2.340524] [drm] Initialized drm 1.1.0 20060810
[ 2.350962] agpgart-intel 0000:00:00.0: Intel i815 Chipset
[ 2.355712] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[ 2.376940] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 2.377220] 8139cp 0000:02:0c.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 2.413884] 8139too Fast Ethernet driver 0.9.28
[ 2.414797] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 9
[ 2.414809] 8139too 0000:02:0c.0: PCI INT A -> Link[LNKE] -> GSI 9 (level, low) -> IRQ 9
[ 2.449133] eth0: RealTek RTL8139 at 0xd000, 00:20:18:a1:0d:5a, IRQ 9
[ 2.463593] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1f.2/usb1/1-1/1-1:1.0/input/input3
[ 2.464328] logitech 0003:046D:C517.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-0000:00:1f.2-1/input0
[ 2.522009] logitech 0003:046D:C517.0002: fixing up Logitech keyboard report descriptor
[ 2.526208] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1f.2/usb1/1-1/1-1:1.1/input/input4
[ 2.528259] logitech 0003:046D:C517.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:1f.2-1/input1
[ 2.536295] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 2.536307] PCI: setting IRQ 11 as level-triggered
[ 2.536318] nouveau 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 2.548742] [drm] nouveau 0000:01:00.0: Detected an NV 0 generation card (0x20114000)
[ 2.548924] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[ 2.636951] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 2.637552] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 2.637559] [drm] nouveau 0000:01:00.0: BMP version 5.1
[ 2.637567] [drm] nouveau 0000:01:00.0: Bios version 02.05.17.03
[ 2.637575] [drm] nouveau 0000:01:00.0: Assuming a CRT output exists
[ 2.637582] [drm] nouveau 0000:01:00.0: Probing TV encoders on I2C bus: 1
[ 2.643534] [drm] nouveau 0000:01:00.0: No TV encoders found.
[ 2.651970] [TTM] Zone kernel: Available graphics memory: 254688 kiB.
[ 2.652000] [drm] nouveau 0000:01:00.0: 32 MiB VRAM
[ 2.652130] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 2.652160] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 2.652194] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 2.652226] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture)
[ 2.652512] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[ 2.654329] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 2.654356] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 2.697531] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.698418] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 2.811783] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x45000, bo d7b37400
[ 2.812217] fb0: nouveaufb frame buffer device
[ 2.812224] registered panic notifier
[ 2.812240] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 2.821311] vga16fb: initializing
[ 2.821328] vga16fb: mapped to 0xc00a0000
[ 2.821341] vga16fb: not registering due to another framebuffer present
[ 2.986143] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 2.986155] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
[ 2.989283] Console: switching to colour frame buffer device 160x64
[ 3.621175] xor: automatically using best checksumming function: pIII_sse
[ 3.640023] pIII_sse : 2121.000 MB/sec
[ 3.640030] xor: using function: pIII_sse (2121.000 MB/sec)
[ 3.651558] device-mapper: dm-raid45: initialized v0.2594b
[ 3.898594] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 5.821816] Adding 1489912k swap on /dev/sda5. Priority:-1 extents:1 across:1489912k
[ 6.135655] udev: starting version 151
[ 7.695784] lp: driver loaded but no devices found
[ 7.738490] parport_pc 00:09: reported by Plug and Play ACPI
[ 7.738552] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 7.836478] lp0: using parport0 (interrupt-driven).
[ 7.911696] ppdev: user-space parallel port driver
[ 8.412421] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.444199] intel_rng: FWH not detected
[ 8.998276] gameport: EMU10K1 is pci0000:02:0a.1/gameport0, io 0xd400, speed 1169kHz
[ 12.985446] ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 9
[ 12.985461] EMU10K1_Audigy 0000:02:0a.0: PCI INT A -> Link[LNKG] -> GSI 9 (level, low) -> IRQ 9
[ 14.550446] eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
[ 16.395870] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 16.398607] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 20.808463] RPC: Registered udp transport module.
[ 20.808474] RPC: Registered tcp transport module.
[ 20.808479] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 21.401161] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 21.827083] svc: failed to register lockdv1 RPC service (errno 97).
[ 21.831776] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 21.848690] NFSD: starting 90-second grace period
[ 24.928040] eth0: no IPv6 routers present
[ 39.245633] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 39.374128] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 39.374144] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
[ 69.076425] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 69.162163] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 69.162178] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
[ 79.613782] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 103.181323] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 503.306623] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1541.370101] [drm] nouveau 0000:01:00.0: Setting dpms mode 1 on vga encoder (output 0)
[ 1600.460782] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[60953.494255] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED
www.linuxcnc.org/component/option,com_ku...2/lang,english/#4020
- blazedforever
Running on Linux Mint 9 Fluxbox!
- wanispissd
So i just encountered this issue on a fresh install of 10.04 live cd, did a quick search, and found this thread (and the thread linked with the answer). I tired the fix, of changing the line in the grub file, and updating ... followed by a reboot. ... No dice..... I was able to verify that I have edited the grub file correctly, but I still get the same error at before.
Is their something else that may have caused this? Any tricks I may be missing?
I did let the software auto-update prior to trying to run EMC2 .... would this change anything? Should I avoid updates to maintain stability (or is this thought ridiculous)?
P.S. Huge THANK YOU to the developers for the 10.04 release !!
- step4linux
- Thank you received: 5
have you checked grub.cfg, is "lapic" now added ?
run dmesg and check lines with apic/lapic after boot.
I`m wondering if developers are aware of this common problem, and if it is already attacked.
Or do we need a bug report ?
Gerd
- wanispissd
Here is my grub file, that has 'lapic' added to the line.
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash lapic"
GRUB_CMDLINE_LINUX=""
And the errors that I get when I attempt to run are attached txt (to keep thread readable):
Any help is greatly appreciated !! Thanks. .
- wanispissd
GRUB_CMDLINE_LINUX="" [/i]
I think you need a Linux expert.
I find these sections of dmesg intriguing but don't know enough to know what it means.
[ 0.000000] No local APIC present or hardware disabled
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=45bb1e27-6f39-422c-a4b9-483899992682 ro quiet splash lapic
[ 0.080213] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.080229] weird, boot CPU (#0) not listed by the BIOS.
[ 0.080239] SMP motherboard not detected.
[ 0.080250] Local APIC not detected. Using dummy APIC emulation.
[ 0.080259] SMP disabled
Does the BIOS of a enable/disable APIC/LAPIC setup option?
- wanispissd
RTAI[hal]:ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED
Yesterday, I did some experimenting and a good bit of google research and one promising thing i found was this site: www.network-crawler.de/index.php/RTAI --which notes that if i get this error, then I will have to recompile. I have not idea what exactly i would recompile or how to do it, so please, if anyone knows, spell it out to me (i am really bad at Linux stuff).
The computer that I am trying to install 10.04 onto is a neoware e100 thin client, with a VIA processor. Although it is x86 compliant, some earlier versions were made without support for APIC. This can be found by typing $ 'cat /proc/cpuinfo' and looking at the flags section. Well, lucky me, my processor does not support APIC, however my BIOS does not seem to know (or care).
I am pretty sure that no APIC support on the process is my issue here, and this has absolutely nothing to do with 10.04. --Moderators, if you want to two and put in a new thread, feel free. --
So, at this point I have two questions:
1 - Does EMC2 require APIC support to run ?
2 - How would I go about configuring EMC2 to run with out APIC support ?
Any help is greatly appreciated!! Thanks in advance.
