OS base for linuxcnc beyond support date
- dansawyer
25 Feb 2021 15:29 #200101
by dansawyer
OS base for linuxcnc beyond support date was created by dansawyer
I downloaded and installed linuxcnc-2.7.14-wheezy.iso. The OS base is out of support and I was unable to install or update packages.
Is there an iso image that is still within support?
If not Is there a linuxcnc package configured for a later OS that can be installed separately?
(as an aligened but separate note, linuxcnc is documented to requre linux RT kernels. Is this strictly necessary or if one is sensible about whatesle else is running will a standard kernel work? )
Thank you, Dan
Thank you, Dan
- Thank you received: 2176
25 Feb 2021 15:54 #200105
Replied by Aciera on topic OS base for linuxcnc beyond support date
The current official ISO is based on BUSTER:
linuxcnc.org/downloads/
And yes, the RT kernel is required. Note that this ISO is a fairly bare debian install which usually works fine for most machine controllers. However if you need driver support for say WiFi dongles there is also a less easy install procedure for LinuxMint that is based on Ubuntu.
forum.linuxcnc.org/9-installing-linuxcnc...stall?start=0#175816
28 Feb 2021 20:50 #200462
What was your path to that ISO? It's very old indeed.
Any link on the www.linuxcnc.org site should take you to Buster and v2.8.1
So, where did you find a link to the Wheezy ISO (so that I can expunge it)
Replied by andypugh on topic OS base for linuxcnc beyond support date
Time to create page: 0.213 seconds
