2.8.1 and 2.9.0 download links are identical. Confused.
- beefy
- Thank you received: 58
12 Mar 2021 17:05 #202028
by beefy
2.8.1 and 2.9.0 download links are identical. Confused. was created by beefy
First of all, just letting you know I'm new to Linuxcnc and making an attempt at converting to the dark side. Should be receiving my Mesa boards very soon.
I'm a bit confused about getting version 2.9.0 (setting up PlasmaC) which I've been told is the version I should use for PlasmaC.
Refer these links.
This first one is for 2.9.0:
linuxcnc.org/docs/devel/html/
and within that, the "Getting Linuxcnc" link:
linuxcnc.org/docs/devel/html/getting-sta...etting-linuxcnc.html
For x86 PCs Download the Live/Install CD by clicking here:
www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso
And this second set is for 2.8.1:
linuxcnc.org/docs/2.8/html/
linuxcnc.org/docs/2.8/html/getting-start...etting-linuxcnc.html
So as can be seen the download link for both 2.8.1 and 2.9.0 is exactly the same. Could someone kindly explain what is going on here.
Cheers,
Keith
Refer these links.
Cheers,
Keith
12 Mar 2021 19:15 #202048
The documents describe the current released state. That is 2.8.1. master / 2.9 is a development version. The docs won't point to that until it is released.
You can't, in fact. download LinuxCNC 2.9 / master from www.linuxcnc.org.
You need to go to buildbot.linuxcnc.org and follow the instructions there.
Replied by andypugh on topic 2.8.1 and 2.9.0 download links are identical. Confused.
- beefy
13 Mar 2021 01:21 #202066
by beefy
Replied by beefy on topic 2.8.1 and 2.9.0 download links are identical. Confused.
Thanks very much for that info Andy. I would indeed have remained confused and pulling my hair out without that knowledge.
It's very strange that the development version link:
directs you to a download that is for a different version.
Off I go now to that link you gave me.
Cheers,
Keith
Cheers,
Keith
- phillc54
- Thank you received: 2100
13 Mar 2021 02:40 #202072
by phillc54
Replied by phillc54 on topic 2.8.1 and 2.9.0 download links are identical. Confused.
To help confuse things a bit more:
PlasmaC will run on either 2.8 or 2.9
The newer QtPlasmaC requires 2.9.
- beefy
13 Mar 2021 03:46 #202078
by beefy
Cheers Phil,
I never knew about that one either. Maybe Rodw can let me know if I should focus on that one from the start.
Keith
Keith
- phillc54
13 Mar 2021 03:54 #202079
by phillc54
It is basically fully functional, there are a few minor cosmetic things we are finishing off, should be done this week.
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html
- robertspark
- Thank you received: 216
13 Mar 2021 04:50 #202082
by robertspark
Replied by robertspark on topic 2.8.1 and 2.9.0 download links are identical. Confused.
Keith,
install 2.8 from the iso from a usb stick.
once it boots, you change the repository settings for linuxcnc to buildbot.
then just run
and then
from the terminal and it will upgrade / update to master.
given you are going to run Mesa hardware you will need to change the network using
and then run
I normally restart at this point (although it's probably not required)
then run
as it will clear out some of the related linked files / programmes that were required by wicd
(I'll come back later, got to go do something, to finish off how I have done my setup as I've done it so many times that I just do it automatically now)
I then setup the network address for the Mesa cards
get rid of the logon screen prompt
add qtvcp via script
add NativeCAM via script
deb http://buildbot.linuxcnc.org/ buster master-rtpreempt
deb-src http://buildbot.linuxcnc.org/ buster master-rtpreemptthen just run
sudo apt-get updatesudo apt-get upgrade -yfrom the terminal and it will upgrade / update to master.
apt-get install network-manager network-manager-gnomeand then run
apt-get remove wicd wicd-gtkI normally restart at this point (although it's probably not required)
then run
sudo apt-get updatesudo apt-get autoremoveas it will clear out some of the related linked files / programmes that were required by wicd
- scotth
- Thank you received: 62
13 Mar 2021 12:27 #202125
by scotth
Replied by scotth on topic 2.8.1 and 2.9.0 download links are identical. Confused.
Now we are at 2.8.1 how do we get to 2.9.0?
- robertspark
13 Mar 2021 14:13 #202136
by robertspark
upgrade your repositiories to use master....
easiest way that I do it is just via synatic package manager..... and just change the linuxcnc repositories listed to master as listed above.
deb-src http://buildbot.linuxcnc.org/ buster master-rtpreempteasiest way that I do it is just via synatic package manager..... and just change the linuxcnc repositories listed to master as listed above.
- scotth
13 Mar 2021 16:19 #202154
by scotth
My bad, I left the deb in front of the http:// ...
Works fine now running 2.9.0 in test.
Thank you,
Scott
Thank you,
Scott
Time to create page: 0.126 seconds
