2.8.1 and 2.9.0 download links are identical. Confused.
09 Oct 2022 13:47 - 09 Oct 2022 13:48 #253818 by smc.collins
I keep getting package failures after updating the repos and adding them, 2.8.4. Most of a day gone trying to upgrade to 2.9 so I can configure my 7i97
Last edit: 09 Oct 2022 13:48 by smc.collins.
09 Oct 2022 14:40 #253819 by andypugh
As far as I can tell the 7i97 is supported in 2.8.4
09 Oct 2022 15:40 - 09 Oct 2022 15:41 #253825 by smc.collins
I can 100% confirm that this is not correct. I wish that were the so. I also need to be able to configure the 7i76 that's connected to it so that I can grab some of the IO
7i97 is not supported in pnconf
Last edit: 09 Oct 2022 15:41 by smc.collins.
09 Oct 2022 16:20 - 09 Oct 2022 16:21 #253826 by andypugh
It might not be supported in pncconf, but it should still work.
You could try using MesaCT if you are unwilling to hand-modify a config.
github.com/jethornton/mesact
Last edit: 09 Oct 2022 16:21 by andypugh.
The following user(s) said Thank You: smc.collins
09 Oct 2022 17:14 - 09 Oct 2022 19:29 #253827 by smc.collins
unfortunately mesact won't allow for the io on the 7i76 connected via the expansion port. i have also been scratching my head as to why i can't assign the spindle output to analog 4 or 5.
maybe JT can chime in. i need my spindle to also be the c axis as well, not sure how to do that yet
Last edit: 09 Oct 2022 19:29 by smc.collins.
Time to create page: 0.205 seconds
