new installation and mcs9865 pci parallel card [solved]
- 30121963
28 May 2021 20:14 #210556
by 30121963
new installation and mcs9865 pci parallel card was created by 30121963
Hi everybody,
I'm trying a new install from the official ISO to a PC with PCI parallel port to connect one ot those cheap 5 axis breakout board + 1x tb6600 driver and 1x salvage stepper motor.
I guess there is something wrong with the parallel card or its settings: whatever I do, everything looks just dead.
Is such HW configuration, supposed to work out of the box or not?
I'm not even sure my parallel card is suitable so before struggling with port testers and whatever, I would ask you whether that card is known to work properly or not. it would not be a big deal to buy a new 10Euro card, if needed.
otherwise, please give me some hint, where to start from to get a working system...
Thanks,
Stefano
Thanks,
Stefano
- Thank you received: 7488
28 May 2021 20:36 #210559
Replied by tommylight on topic new installation and mcs9865 pci parallel card
In a terminal
cat /proc/ioports | grep parport
Post the results here
Also
sudo lspci -v
might help
Also
sudo lspci -v
might help
- 30121963
29 May 2021 12:48 - 29 May 2021 12:51 #210619
by 30121963
Replied by 30121963 on topic new installation and mcs9865 pci parallel card
thanks tommylight.
pls note:
- the version installed on my local ssd is LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT.
stefano@linuxcnc:~$ cat /proc/ioports | grep parport
0000-0000 : parport0
stefano@linuxcnc:~$ sudo cat /proc/ioports | grep parport
e010-e012 : parport0
e013-e017 : parport0
"stefano@linuxcnc:~$ sudo lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Root Complex
Subsystem: ASRock Incorporation Family 15h (Models 30h-3fh) Processor Root Complex
Flags: bus master, fast devsel, latency 0
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) I/O Memory Management Unit
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) I/O Memory Management Unit
Flags: fast devsel, IRQ 24
Capabilities: [40] Secure device <?>
Capabilities: [54] MSI: Enable+ Count=1/4 Maskable- 64bit+
Capabilities: [64] HyperTransport: MSI Mapping Enable+ Fixed+
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Kaveri [Radeon R7 Graphics] (prog-if 00 [VGA controller])
Subsystem: ASRock Incorporation Kaveri [Radeon R7 Graphics]
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=8M]
I/O ports at f000
Memory at feb00000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [48] Vendor Specific Information: Len=08 <?>
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
Capabilities: [270] #19
Capabilities: [2b0] Address Translation Service (ATS)
Capabilities: [2c0] Page Request Interface (PRI)
Capabilities: [2d0] Process Address Space ID (PASID)
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Kaveri HDMI/DP Audio Controller
Subsystem: ASRock Incorporation Kaveri HDMI/DP Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 51
Memory at feb64000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Root Port
Flags: fast devsel
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Root Port
Flags: fast devsel
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Root Port
Flags: fast devsel
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 09) (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation FCH USB XHCI Controller
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at feb6a000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [90] MSI-X: Enable+ Count=8 Masked-
Capabilities: [a0] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Latency Tolerance Reporting
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:10.1 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 09) (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at feb68000 (64-bit, non-prefetchable) [size=8K]
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 40) (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation FCH SATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 29
I/O ports at f190
I/O ports at f180
I/O ports at f170
I/O ports at f160
I/O ports at f150
Memory at feb71000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [50] MSI: Enable+ Count=4/4 Maskable- 64bit+
Capabilities: [70] SATA HBA v1.0
Kernel driver in use: ahci
Kernel modules: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11) (prog-if 10 [OHCI])
Subsystem: ASRock Incorporation FCH USB OHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 18
Memory at feb70000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci-pci
Kernel modules: ohci_pci
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11) (prog-if 20 [EHCI])
Subsystem: ASRock Incorporation FCH USB EHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 17
Memory at feb6f000 (32-bit, non-prefetchable)
Capabilities: [c0] Power Management version 2
Capabilities: [e4] Debug port: BAR=1 offset=00e0
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11) (prog-if 10 [OHCI])
Memory at feb6e000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11) (prog-if 20 [EHCI])
Memory at feb6d000 (32-bit, non-prefetchable)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 16)
Subsystem: ASRock Incorporation FCH SMBus Controller
Flags: 66MHz, medium devsel
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD] FCH IDE Controller (prog-if 8a [ISA Compatibility mode controller, supports both channels switched to PCI native mode, supports bus mastering])
Subsystem: ASRock Incorporation FCH IDE Controller
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at f100
Kernel driver in use: pata_atiixp
Kernel modules: pata_atiixp, ata_generic
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 01)
Subsystem: ASRock Incorporation FCH Azalia Controller
Flags: bus master, slow devsel, latency 32, IRQ 16
Memory at feb60000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
Subsystem: ASRock Incorporation FCH LPC Bridge
Flags: bus master, 66MHz, medium devsel, latency 0
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] FCH PCI Bridge (rev 40) (prog-if 01 [Subtractive decode])
Flags: bus master, 66MHz, medium devsel, latency 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fea00000-feafffff
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11) (prog-if 10 [OHCI])
Memory at feb6c000 (32-bit, non-prefetchable) [size=4K]
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Capabilities: [58] Express Root Port (Slot-), MSI 00
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 0)
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: pcieport
00:15.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: fe900000-fe9fffff
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 1)
00:15.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 2) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: fe800000-fe8fffff
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 2)
00:15.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 3) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fe700000-fe7fffff
Capabilities: [b0] Subsystem: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 3)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Function 0
Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Function 1
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Function 2
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Function 3
Flags: fast devsel
Capabilities: [f0] Secure device <?>
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Function 4
Flags: fast devsel
Kernel driver in use: fam15h_power
Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h (Models 30h-3fh) Processor Function 5
Flags: fast devsel
01:05.0 Parallel controller: MosChip Semiconductor Technology Ltd. PCI 9865 Multi-I/O Controller (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Flags: medium devsel, IRQ 20
I/O ports at e010
I/O ports at e000
Memory at fea01000 (32-bit, non-prefetchable) [size=4K]
Memory at fea00000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [48] Power Management version 2
Kernel driver in use: parport_pc
Kernel modules: parport_pc
03:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
Subsystem: Qualcomm Atheros AR9485 Wireless Network Adapter
Memory at fe900000 (64-bit, non-prefetchable) [size=512K]
Expansion ROM at fe980000 [disabled] [size=64K]
Capabilities: [40] Power Management version 2
Capabilities: [50] MSI: Enable- Count=1/4 Maskable+ 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: ath9k
Kernel modules: ath9k
04:00.0 USB controller: ASMedia Technology Inc. ASM1042 SuperSpeed USB Host Controller (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation Motherboard
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at fe800000 (64-bit, non-prefetchable) [size=32K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [68] MSI-X: Enable+ Count=8 Masked-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
05:00.0 Ethernet controller: Qualcomm Atheros QCA8171 Gigabit Ethernet (rev 10)
Subsystem: ASRock Incorporation QCA8171 Gigabit Ethernet
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at fe700000 (64-bit, non-prefetchable) [size=256K]
I/O ports at d000
Capabilities: [40] Power Management version 3
Capabilities: [58] Express Endpoint, MSI 00
Capabilities: [c0] MSI: Enable- Count=1/16 Maskable+ 64bit+
Capabilities: [d8] MSI-X: Enable+ Count=16 Masked-
Capabilities: [180] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: alx
Kernel modules: alx"
pls note:
I/O ports at f000
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
I/O ports at f190
I/O ports at f180
I/O ports at f170
I/O ports at f160
I/O ports at f150
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at f100
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
I/O ports at e010
I/O ports at e000
I/O ports at d000
Last edit: 29 May 2021 12:51 by 30121963.
29 May 2021 14:42 #210624
Nice, there is a parallel port recognised and in use, so set this address in the StepConf wizard :
0xe010
It can also be edited in hal with a text editor.
0xe010
- 30121963
29 May 2021 15:35 #210630
by 30121963
well..now the cnc board's relais can be toggled on and off. still no signs of life from the motor. But this is another topic.
thanks!
thanks!
29 May 2021 16:16 #210635
First thing to try is make the timings longer in the INI file or again using StepConf wizard to edit the existing config, namely :
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
- 30121963
30 May 2021 15:25 #210685
by 30121963
thanks. please let me know if the following is OT, I'll open a new thread.
I used the wizard and entered your parameters (step time,step space, direction hold,direction setup in the wizard).
Once finished, I checked the resulting hal parameters (in bold) but they don't match. I attached here my full hal file.
note:
- only the Y axis motor is connected for now. does it affect the system somehow?
- whatever the configuration, testing the axes in the wizard gives no results.
- my motor is a salvage KP54FP8-755, 7.5 deg/step, 10ohm/phase. should this be the issue here, I'll wait for the NEMA17 I already ordered..
- I suppose all my hardware should run quite out of the box so I can't figure out whats going on..
# Generated by stepconf 1.1 at Sun May 30 16:09:41 2021
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0xe010 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
loadrt pwmgen output_type=1
addf pwmgen.make-pulses base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 1166.66666667
setp pwmgen.0.offset 0.114285714286
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-cw <= spindle.0.forward
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
thnks!
note:
thnks!
30 May 2021 15:40 #210687
That is the hal file you attached, that needs to be set in the .INI file.
30 May 2021 20:15 #210733
Replied by andypugh on topic new installation and mcs9865 pci parallel card
Nontheless, it looks about right, using "reset" with a reset time of 5000ns.
This is looking like the classic "stepper driver not enabled" thing.
Is the stepper motor locked and not moving, or free to turn and not moving?
- 30121963
31 May 2021 11:30 - 31 May 2021 11:40 #210789
by 30121963
hi andypugh!
- the motor turns free as if it was not connected.
- maybe pointless but whatever the machine power status, I read the same:
Vcc > 12V
ena+, dir+, pul+ > +5V
I wired my motor to X axis.
[edit]
in my hal file:
the pin 17 of the breakout board is marked BDIR and is not connected..is that ok?
Vcc > 12V
[edit]
in my hal file:
Last edit: 31 May 2021 11:40 by 30121963.
Time to create page: 0.124 seconds
