new installation and mcs9865 pci parallel card [solved]
31 May 2021 13:33 #210796 by andypugh
Replied by andypugh on topic new installation and mcs9865 pci parallel card
the motor turns free as if it was not connected.
That means that the drive is not enabled.
As a first step, just remove any wires to the drive "enable" pins. These are typically a "disable" and when connected to the parport the turn _off_ the drive.
There is no point wiring the enable on a stepper driver, you might as well save the parport pins.
31 May 2021 16:37 #210805 by 30121963
f**k :-)
The microstep dip switches were set to NC. My bad, sorry.
Your help forced me to triple check everything. I thought NC = nominal, no microstepping, not "not connected at all".
Thank you both!
Stefano
Time to create page: 0.066 seconds
