Installing from linuxcnc-2.8.0-buster.iso fails via USB
- voltagex
03 Jul 2021 13:50 - 03 Jul 2021 13:58 #213562
by voltagex
Installing from linuxcnc-2.8.0-buster.iso fails via USB was created by voltagex
I am trying to install LinuxCNC from the linuxcnc-2.8.0-buster.iso image. I have tried writing the image to USB in both dd mode and FAT32 mode, both of which fail trying to "mount the CD-ROM".
I have tested debian-10.10.0-amd64-xfce-CD-1.iso and it installs successfully (or at least, gets past this step).
Last edit: 03 Jul 2021 13:58 by voltagex. Reason: Info on upstream
- Thank you received: 7488
03 Jul 2021 16:45 #213571
Replied by tommylight on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
Use win32diskimager
not Rufus.
not Rufus.
The following user(s) said Thank You: voltagex
- voltagex
04 Jul 2021 04:18 #213639
by voltagex
Replied by voltagex on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
Thanks, that seems to have worked - however I still think there's a bug, especially as Debian Installer seems to have fixed this issue somewhere between 10.6 and 10.10.
05 Jul 2021 22:13 - 05 Jul 2021 22:14 #213795
If you give it a couple of hours to upload, I have just created a new 2.8.2 .ISO file, you should find it in here:
www.linuxcnc.org/iso
(look for the LinuxCNC-2.8.2-buster.iso file.)
Perhaps you can test that and see if the problem is fixed?
If not, I will dive deeper.
Replied by andypugh on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
Last edit: 05 Jul 2021 22:14 by andypugh.
- voltagex
06 Jul 2021 11:58 #213849
by voltagex
Unfortunately I can't reproduce this in a VM and the other machine that I was having this problem with has been packed up ready to go to the friend with the actual CNC.
If you've updated debian-installer / cdrom-detect that will most likely fix it.
Can I ask how the ISO is built? I couldn't see source code easily in the GitHub for it.
06 Jul 2021 21:34 #213901
It uses the Debian "live-build" package and github.com/LinuxCNC/buster-live-buildCan I ask how the ISO is built? I couldn't see source code easily in the GitHub for it.
- probotix
06 Nov 2021 14:10 #225503
by probotix
Replied by probotix on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
Andy,
Can you give a quick tutorial on how to setup and run the live-build system?
08 Nov 2021 00:03 #225605
If you download that repository, then you should just need to enter the directory and enter the commands in the readme
08 Nov 2021 00:06 #225606
If you want to customise it, then there is lots of documentation here:
live-team.pages.debian.net/live-manual/h...manual/index.en.html
- probotix
08 Nov 2021 18:02 #225704
by probotix
At the very least, the debian repository URLs have changed. Haven't figured out what else is wrong yet.
Time to create page: 2.701 seconds
