Installing from linuxcnc-2.8.0-buster.iso fails via USB
- probotix
09 Nov 2021 13:14 #225818
by probotix
Replied by probotix on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
Do you have a current set of working commands?
11 Nov 2021 21:58 - 11 Nov 2021 21:58 #226149
Seems to work for me.
But I suspect that you need the right things in your apt sources so that it can get all the packages.
Replied by andypugh on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
sudo lb config
sudo lb buildBut I suspect that you need the right things in your apt sources so that it can get all the packages.
deb http://deb.debian.org/debian/ buster non-free contrib main
deb-src http://deb.debian.org/debian/ buster non-free contrib main
deb http://security.debian.org/debian-security/ buster/updates main
deb-src http://security.debian.org/debian-security/ buster/updates main
deb http://www.linuxcnc.org/ buster base
deb-src http://www.linuxcnc.org/ buster base
deb http://www.linuxcnc.org/ buster 2.8-rt
Last edit: 11 Nov 2021 21:58 by andypugh.
- probotix
12 Nov 2021 00:55 #226167
by probotix
Thanks Andy. Got it working. My VirtualBox install keeps losing time when it goes to sleep. Resynced the time and it works like a champ. Now working on our preseeder. Let me know if you wanna see it.
- probotix
16 Nov 2021 13:47 #226650
by probotix
Hey Andy! Really digging buster-live-build, especially after swapping out binary_syslinux to solve the splash screen issue.
Have you ever figured out how to make live-build recompile the iso without cleaning and re-downloading everything again?
17 Nov 2021 22:06 #226795
I suggest subscribing to the debian-live mailing list. It's very low traffic.
I seem to recall that sometimes it just works, and sometimes not.Have you ever figured out how to make live-build recompile the iso without cleaning and re-downloading everything again?
- probotix
26 May 2022 20:58 #243947
by probotix
buster-live-build has quit working. I havent needed to touch it in 9 months or so. Do you know if they fidgeted with the addresses for the update servers again?
26 May 2022 22:52 #243952
What error do you get?
- probotix
26 May 2022 23:04 #243954
by probotix
404s on the repositories.
27 May 2022 00:01 #243960
LinuxCNC repositories or Debian repos?
My Debian install doesn't seem to be having any trouble, which repitory (exactly) is failing?
andypugh@buster:~/linuxcnc-dev/src$ sudo apt-get update
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://www.linuxcnc.org buster InRelease
Reading package lists... Done Please Log in or Create an account to join the conversation.
- robertspark
- Thank you received: 216
27 May 2022 12:55 #243984
by robertspark
Replied by robertspark on topic Installing from linuxcnc-2.8.0-buster.iso fails via USB
slightly off topic..... {but related}
github.com/LinuxCNC/buster-live-build/bl...e-lists/desktop.list
suggest changing nm-tray to network-manager-gnome {which is what gets used in bullseye + does not load multiple entries}
if I wanted to add stuff like freecad, etc etc is this where I would add it?
grub-customizer {easy grub editing}
power-manager {easy screen saver + lock + screen blank disable}
I am guessing I could change all of the repositories etc so that bullseye / bookworm could be built with linuxcnc master as an iso?
Time to create page: 0.391 seconds
