Error message.
09 Jul 2021 07:12 - 09 Jul 2021 07:36 #214062 by EastRaw
Error message. was created by EastRaw
Good time of the day.I'm building my own CNC machine and totally new to Linux. Original idea was to install LinuxCNC on Mint, but somehow i've managed to install Debian with Linux CNC.Well fine with that as long as it works, but it doesn't. When i wanted to do some initial testing of my motors, 7i76e and so on i'm getting this error message. Honestly i have no clue what went wrong and why it's not working. Any help is appreciated. Thanks a lot in advance.
Image of error message:
Link removed by moderator
Last edit: 09 Jul 2021 07:36 by tommylight. Reason: link removed
  • Moderator
  • Moderator
09 Jul 2021 07:37 #214064 by tommylight
Replied by tommylight on topic Error message.
Could you please uplad the pictures or even better the error log here on the forum?
Using 3 party websites is never a good idea, to many scripts running on those sites.
09 Jul 2021 08:33 #214067 by EastRaw
Replied by EastRaw on topic Error message.
Hi there,
I've tried it at first but kept getting error messages.
Now should work.
09 Jul 2021 12:21 #214089 by EastRaw
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
Machine configuration directory is '/home/eastraw/Documents'
Machine configuration file is '1001.ngc'
INIFILE=/home/eastraw/Documents/1001.ngc
VERSION=
halfiles =
halpaths = []
update script failed in an unexpected way.
Debug file information:
Can not find -sec EMC -var VERSION -num 1
File "/usr/bin/update_ini", line 197, in <module>
all_sections.remove("EMC")
ValueError: list.remove(x): x not in list
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fri 9 Jul 12:52:22 BST 2021
UTC Date: Fri 9 Jul 11:52:22 UTC 2021
this program: /usr/bin/linuxcnc_info
uptime: 12:52:22 up 5 days, 21:34, 1 user, load average: 0.33, 0.62, 0.44
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/eastraw/Documents
USER: eastraw
LOGNAME: eastraw
HOME: /home/eastraw
EDITOR:
VISUAL:
LANGUAGE: en_GB:en
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: lightdm-xsession
display size: 1366x768 pixels (361x203 millimeters)
PATH: /usr/bin:/home/eastraw/Documents/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: eastraw
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.146-1 (2020-09-17)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-11-rt-amd64 root=UUID=022e671d-8534-4e23-91f5-b128d6d50d03 ro initrd=/install/initrd.gz quiet
model name: Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz
cores: 1
cpu MHz: 1661.189
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-cn 1:2.8.0 all motion controller for CNC machines and robots (Chinese
ii linuxcnc-doc-en 1:2.8.0 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.0 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.0 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.0 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.0 amd64 PC based motion controller for real-time Linux
09 Jul 2021 12:42 #214090 by andypugh
Replied by andypugh on topic Error message.
How are you starting LinuxCNC? It seems that LinuxCNC is being passed a G-code file where it expects an configuration (INI) file.
09 Jul 2021 13:42 #214103 by EastRaw
Hi Andy,
I'm starting it from Applications and than I'm trying to open a test file... File was made for me to test motors.
I'm doing it wrong i guess?
09 Jul 2021 13:44 #214105 by andypugh
I think so. You need to open a machine configuration file first, then open the .ngc file from the GUI.
Have you created a machine config yet?
09 Jul 2021 14:15 #214110 by EastRaw
If only i knew that i needed to do that...
Can you kick me in the right direction pls..
09 Jul 2021 14:19 #214111 by andypugh
Links from here:
linuxcnc.org/docs/2.8/html/user/user-intro.html
All the docs can be found here:
09 Jul 2021 18:30 - 09 Jul 2021 19:36 #214129 by EastRaw
You think it's wort installing 2.8.2 straight away?
And if so, i just make bootable USB from ISO and it will install everything from zero right?
NVM,
Already found your response in search ;) Upgraded.
Last edit: 09 Jul 2021 19:36 by EastRaw.
Time to create page: 0.367 seconds
