Error message.
- Thank you received: 7488
12 Jul 2021 22:47 #214444
Replied by tommylight on topic Error message.
I did say for ROOT no password, normal users must have a user name and password.Next time you install Debian, when it asks for root password, just press enter and leave it blank.
- EastRaw
13 Jul 2021 06:44 #214495
by EastRaw
Replied by EastRaw on topic Error message.
Ah ok...
I never selected root password, just a standard user password.
I did used it for root password as well. So i'm a bit confused.
Because some stuff does asks for root password right?
Ok just when ever it asks for root password just leave it.
13 Jul 2021 10:19 #214530
On Debian, having a root user and a normal user puts it in multi-user mode, so anything regarding administration requires logging in as both users, that can cause issues with permisions that will have to be manually added later for the normal user.
When there is no root user, that is a single user mode and any addministration is done with temporary escalated priviledges as a normal user ( see SUDO), so the permissions are set right away with no need for further work. This also is a safety feature as the system will not allow anything to run with administrative priviledges without explicit permission from the user.
16 Jul 2021 11:57 #215024
Replied by andypugh on topic Error message.
Just a bit of clarification:
The latest 2.8.2 ISO installs Network Manager rather than WICD.
If you have an entry in /etc/network/interfaces, as described in the hm2_eth docs, then Network Manager says that the connection is "unmanaged" and ignores it.
(Which is fine, it should still work for the mesa card)
