Debian Wheezy rt (RTAI) 2.8.2 no linuxcnc-dev ?
- gaston48
- Thank you received: 5
17 Jul 2021 12:32 #215132
by gaston48
Debian Wheezy rt (RTAI) 2.8.2 no linuxcnc-dev ? was created by gaston48
Hello,
Under Debian Wheezy rt (RTAI) 2.8.2
I cannot install linuxcnc-dev ?
- Thank you received: 7465
17 Jul 2021 17:14 #215147
Replied by tommylight on topic Debian Wheezy rt (RTAI) 2.8.2 no linuxcnc-dev ?
sudo apt-get install linuxcnc-uspace-dev
- gaston48
17 Jul 2021 17:28 #215152
by gaston48
Replied by gaston48 on topic Debian Wheezy rt (RTAI) 2.8.2 no linuxcnc-dev ?
Merci tommylight
but why in uspace?
and not :
sudo apt-get install linuxcnc-dev
It's the same problem as in this post here:
forum.linuxcnc.org/9-installing-linuxcnc...ing-on-2-8-rt#201956
but why in uspace?
and not :
17 Jul 2021 17:36 #215154
Uspace = user space = for RT-Preempt kernel
There is also the RTAI kernel version, that was talked about in the link you posted.
- gaston48
17 Jul 2021 17:40 #215155
by gaston48
I am under wheezy, so I would like the version for RTAI !
17 Jul 2021 21:19 #215172
As far as i can see there is no dev for RTAI version:
linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI
Found it for Wheezy:
buildbot.linuxcnc.org/dists/wheezy/master-rt/binary-i386/
but that should work also from terminal, did you do a
sudo apt-get update
before install?
sudo apt-get update
before install?
- gaston48
18 Jul 2021 06:40 #215204
by gaston48
I have a large mesa configuration with 3 serial cards which only works under RTAI.
with a lot of components to compile and install.
rtai under buster is very risky for my big milling machine, so I am forced to stay
under wheezy.
Following the post here:
Andy installed the package linuxcnc-dev on Wheezy rtai 2.8.1 in 15 minutes (it was an oversight)
that is no longer possible on 2.8.2 ?
under wheezy.
- Thank you received: 4648
28 Jul 2021 22:50 #216159
Replied by andypugh on topic Debian Wheezy rt (RTAI) 2.8.2 no linuxcnc-dev ?
I think that this is the package that you need:
www.linuxcnc.org/dists/wheezy/2.8-rt/bin...c-dev_2.8.2_i386.deb
I don't know why the package manager is not finding it.
- gaston48
29 Jul 2021 08:16 #216197
by gaston48
Thanks andy,
In the mean time, I installed debian buster alone
with the intention of installing RTAI
and linuxcnc 2.8.2 following the instructions given here:
but the packages were not found either ...
About Mesa and my 3 serial cards, they don't want to start with a 1000000 ns servo-thread
they start with 500000 ns ? which is incompatible with rt-preempt .
29 Jul 2021 08:56 #216201
RT-Preempt does not care much about servo period as long as the PC can handle it, and the cards connected to that PC.
Not sure how to say this, but if it works with 500000 it should work with 1000000, there is no justifiable reason for it not to work except a typo in the ini file.
Time to create page: 0.116 seconds
