Help me install on Raspbian 10 - via Rasberry Pi 3B
- dudesquat
23 Aug 2021 19:18 #218537
by dudesquat
Help me install on Raspbian 10 - via Rasberry Pi 3B was created by dudesquat
I'm following the instructions here which I think are out of date:
linuxcnc.org/docs/html/getting-started/g...lling_on_raspbian_10
After adding the key, then the repo and doing an apt-get update, this happens:
root@raspberrypi:/home/pi# sudo apt-key adv --keyserver hkp://keys.openpgp.org --recv-key 3cb9fd148f374fef
Executing: /tmp/apt-key-gpghome.HaA1MP2Wl8/gpg.1.sh --keyserver hkp://keys.openpgp.org --recv-key 3cb9fd148f374fef
gpg: key 3CB9FD148F374FEF: new key but contains no user ID - skipped
gpg: Total number processed: 1
gpg: w/o user IDs: 1
root@raspberrypi:/home/pi# sudo apt-get update
Get:1 linuxcnc.org buster InRelease [28.5 kB]
Hit:2 archive.raspberrypi.org/debian buster InRelease
Hit:3 raspbian.raspberrypi.org/raspbian buster InRelease
Err:1 linuxcnc.org buster InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEF
Reading package lists... Done
W: GPG error: linuxcnc.org buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEF
E: The repository 'linuxcnc.org buster InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Help please!
Help please!
- Thank you received: 7488
23 Aug 2021 22:04 #218554
Replied by tommylight on topic Help me install on Raspbian 10 - via Rasberry Pi 3B
That seems to be the wrong key, where did you get that from so we can remove it?
Try these
forum.linuxcnc.org/38-general-linuxcnc-q...-05?start=280#212635
Try these
- dudesquat
23 Aug 2021 23:18 #218562
by dudesquat
Replied by dudesquat on topic Help me install on Raspbian 10 - via Rasberry Pi 3B
Within this URL.
I'm still not sure what to do. Are these URLs correct in that same link?
Is it even possible to install Linux CnC on Raspbian?
Within this URL.
23 Aug 2021 23:26 #218563
Thank you, info seems to be recent so i am not sure exactly what is correct, maybe someone else can shed more light on this?
There should be some ready made images for RPI4 (some mention RPI3 also), but since i never used them i will refrain from "helping".
Sorry.
Sorry.
- dudesquat
24 Aug 2021 04:16 #218583
by dudesquat
No problem, amgio. Thank for the info.
I suck at linux and this is linux basics stuff so some linux geek might have pity on me and give me a hand.
- cakeslob
- Thank you received: 280
25 Aug 2021 23:29 #218741
by cakeslob
Sorry, I dont have any pity, but I do have empathy because linux is hard.
linuxcnc.org/docs/html/getting-started/g...tml#_normal_download
I will suggest downloading the pre-made image for rpi. Keyserver, I dont know what it is exactly, but i can assume it has to do with apt-get update.
Replied by cakeslob on topic Help me install on Raspbian 10 - via Rasberry Pi 3B
- elovalvo
- Thank you received: 127
26 Aug 2021 14:57 - 26 Aug 2021 15:24 #218808
by elovalvo
stackoverflow.com/questions/1139127/how-...public-key-is-not-av
Replied by elovalvo on topic Help me install on Raspbian 10 - via Rasberry Pi 3B
I think the solution to the problem can be found in this link:
Last edit: 26 Aug 2021 15:24 by elovalvo.
01 Sep 2021 22:10 #219367
Replied by andypugh on topic Help me install on Raspbian 10 - via Rasberry Pi 3B
Did you get this sorted out? The keyservers are in a bit of a tangle right now, and it looks like we might have switched to one that doesn't respond in the way that apt wants it to.
- dgdodo
16 Nov 2021 00:59 #226616
by dgdodo
Replied by dgdodo on topic Help me install on Raspbian 10 - via Rasberry Pi 3B
Yes, andypugh, I did.
Use the following just before sudo apt-get update:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 3CB9FD148F374FEF
And sorry, I can NOT post my logs as there are too many links in it???
Regards, DG
(PS. This internal word-processor is weird, 1 word italic, next the whole rest of my message is italic? 1 rule quote, next whole text quoted ? I'm getting weird too this way... Over half an hour to write this message, yes right ... )
Regards, DG
16 Nov 2021 17:44 #226665
It's worse than that, it's terrible.
I have found that the only way to use it is to click the <>Source button and put the tags in by hand.
Time to create page: 0.135 seconds
