LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
23 Sep 2021 12:13 #221425
by billykid
Replied by billykid on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
Trust me Tom
the path was right, double slash was just in the message. the hm2 folder in usr / lib / firmware did not exist. i copied hm2 from buster 2.9 master disk on usb stick and with root file manager on mx 19 put it in the right place it works regularly. sorry I didn't think about it before but this problem never occurred. the 5i23 will be old but runs servo threads at 8 khz
- snowgoer540
- Thank you received: 588
23 Sep 2021 12:15 #221426
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
Glad you got it going!
I am curious, what exactly is in the hm2 folder? And if it's another folder, then what's in that folder, and so on?
Just trying to capture what exactly needs to go in there for the future.
23 Sep 2021 12:26 - 23 Sep 2021 12:29 #221427
by billykid
the missing folder is in: / usr / lib / firmware it is called hm2 and contains the subfolders with the various mesa tabs. I am attaching mine that I copied.
I deleted some boards for the 1.6 mega limits of the forum but the structure is that.
Last edit: 23 Sep 2021 12:29 by billykid.
The following user(s) said Thank You: tommylight, snowgoer540
- Thank you received: 4390
23 Sep 2021 15:10 #221431
Replied by tommylight on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
Never used a 5i23, but i was sure no installation is required, just copy/paste the .bin files, recalled from when i was doing due diligence first time i ordered Mesa stuff.
Glad you figured it out, and yes the Mesa boards are magnificent pieces of enginiering!
Snowwy, older Mesa boards required having the bin file on the hdd at boot time they would load that as requested by loadrt in hal, new ones have that in EEPROM.
- snowgoer540
23 Sep 2021 15:14 #221432
by snowgoer540
I was not previously aware, so I'm glad to learn this, always love learning new things about this project.
I'm not sure if it should be included in my install docs or not, as I am not sure how common some of that older stuff is. But, I am open to suggestion. The discussion is also captured here, so that will likely help those in the future who have similar issues.
23 Sep 2021 15:18 #221434
Might wana check if they are still sold by Mesa, they are quite the beasts as Billy mentioned they can easily do 8KHz servo period, although i have pushed Mesa 5i25 or 6i25 ( not sure) to 4KHz.
And they have lots of pins, lots !
The following user(s) said Thank You: billykid, snowgoer540
23 Sep 2021 16:52 - 23 Sep 2021 16:54 #221441
by Clive S
Replied by Clive S on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
@Greg
First thanks for taking the time for the MX Linux 19.4 docs etc.
I would like to try this. Some time ago I set up a 1200x1200 size plasma with PlasmaC using the axis gui this is about 70 miles from home. It is a production machine so don't want it off line. This has run fine but as you know PlasmaC is EOL so want to convert it to QT.
The plan is to make another ssd with MX and set it up at home first on my machine then take it over and swap out the ssd's.
The setup up is very similar to mine both using a Mesa 7i96
Would MX be stable enough for what I want to do?
Edit: will it work on 32 and 64 bit ?
Last edit: 23 Sep 2021 16:54 by Clive S.
- snowgoer540
23 Sep 2021 16:58 #221442
by snowgoer540
Quite welcome, happy to help.
Funny you should ask that because I was wondering the same thing just today. I was going to set up another pc for test stuff in the winter (cold in the garage
), the PC I have ear-marked for that is totally different than the PC at my machine, so I'll test it out and swap the drives one of these days (maybe sat/sun) and report back.
- snowgoer540
23 Sep 2021 16:59 #221443
by snowgoer540
Will what exactly work on 32 vs 64?
The images are different 32 to 64, so I'd guess swapping drives for different architectures would not work.
23 Sep 2021 17:04 #221444
by billykid
At first glance it looks very promising MX 19.4 and simple. it has the root filemanager, file search and other nice things. the cnc seems to work well I also try the plasma so with only one system I do both, just a spare disk for safety.
Time to create page: 0.099 seconds
