How to proper compile, built, and install linuxCNC
4 years 9 months ago - 4 years 9 months ago #231819 by Matt Hat
Which branch has a fair chance to compile on wheezy? Could I use e.g. linuxcnc branch 2.7?
Which python version should be used to built from source? will 2.7 work ? and which branches transitioned to python3? was that linuxcnc 2.9?
any other important arguments to be used to fix python versions? I found this on github:
./configure --with-realtime=uspace --with-python=python3 --with-boost-python=boost_python-py35
Eventually I will test
sourceforge.net/projects/linux-debian-bullseye-11-rtos/
But I still need some help on "how to add custom kinematics for the 4th rotary axis".
Last edit: 4 years 9 months ago by Matt Hat.
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 9 months ago #231842 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic How to proper compile, built, and install linuxCNC
Ok there are Wheezy 2.8.2 packages on buildbot, so if your sources are setup there is no need to build linuxcnc.
buildbot.linuxcnc.org/
To build & install your comp, provided you have linuxcnc-dev installed.
sudo halcompile --install rot4thaxiskins.c
linuxcnc.org/docs/2.8/html/man/man1/halcompile.1.html
4 years 9 months ago - 4 years 9 months ago #231907 by Matt Hat
Thanks, the was very helpful indeed. Unfortunately loading the compiled rot4thaxiskin still fails:
Debug file information: Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/rot4thaxiskins.ko: Unknown symbol in module ./rot4thaxiskins.hal:4: exit value: 1 ./rot4thaxiskins.hal:4: insmod for rot4thaxiskins failed, returned -1
Whats the issue about? Suggestions to fix it?
I worked through lncnc 2.7 and 2.8 from buildbot with same result. These steps seems to work:
1) remove installed version with Synaptic Package Manager
2) add repo sources:
deb http://buildbot.linuxcnc.org/ wheezy 2.8-rt for 2.8 and deb http://buildbot.linuxcnc.org/ wheezy 2.7-rt for 2.7
3) install linuxcnc and linuxcnc-dev
4) Check startup with standard config using trivkins.c -> works
5)
sudo halcompile --install rot4thaxiskins.c -> compiles and copies file to usr/realtime-3.4.9-rtai-686-pae/modules
6) Start linuxcnc with some 4-axis config.ini that loads rot4thaxiskin.c
4 years 9 months ago #231908 by Matt Hat
Reports:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.8.2-72-gbcb0b7c Machine configuration directory is '/home/mattu/linuxcnc/configs/my-4-axisCNC' Machine configuration file is 'rot4thaxiskins.ini' INIFILE=/home/mattu/linuxcnc/configs/my-4-axisCNC/rot4thaxiskins.ini VERSION=1.1 check_config: Unchecked: [KINS]KINEMATICS={rot4thaxiskins coordinates=XYZAUVW} PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI= DISPLAY=axis COORDINATES=XYZAUVW KINEMATICS=rot4thaxiskins coordinates=XYZAUVW Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Found file(REL): ./rot4thaxiskins.hal Shutting down and cleaning up LinuxCNC... Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/rot4thaxiskins.ko: Unknown symbol in module ./rot4thaxiskins.hal:4: exit value: 1 ./rot4thaxiskins.hal:4: insmod for rot4thaxiskins failed, returned -1 See the output of 'dmesg' for more information. 3182 Stopping realtime threads Unloading hal components Kernel message information: [ 3168.750490] I-pipe: head domain RTAI registered. [ 3168.750496] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 3168.750525] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 3168.750528] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12499048, CLK_FREQ 2499949000, CPU_FREQ 2499949000 [ 3168.750531] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 3168.750534] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12499048, 12499048, 11061000 [ 3168.759919] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 3168.759953] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 3168.759957] RTAI[sched]: hard timer type/freq = APIC/12499048(Hz); default timing: oneshot; linear timed lists. [ 3168.759960] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2499949000 hz. [ 3168.759962] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 3168.770755] RTAI[math]: loaded. [ 3168.799974] rot4thaxiskins: Unknown parameter `coordinates' [ 3169.053160] RTAI[math]: unloaded. [ 3169.054680] SCHED releases registered named ALIEN PEDV$D [ 3169.059130] RTAI[malloc]: unloaded. [ 3169.156025] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 3169.157894] I-pipe: head domain RTAI unregistered. [ 3169.157933] RTAI[hal]: unmounted. ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file:    /tmp/linuxcnc_info.txt can be posted to a forum or a web site like:      http://pastebin.com in order to provide information about the linuxcnc system and configuration.                 Date: Sat Jan 15 18:44:20 CET 2022             UTC Date: Sat Jan 15 17:44:20 UTC 2022         this program: /usr/bin/linuxcnc_info               uptime: 18:44:19 up 53 min, 1 user, load average: 0.11, 0.27, 0.24      lsb_release -sa: Debian Debian GNU/Linux 7.11 (wheezy) 7.11 wheezy       which linuxcnc: /usr/bin/linuxcnc                  pwd: /home/mattu/linuxcnc/configs/my-4-axisCNC                 USER: mattu              LOGNAME: mattu                 HOME: /home/mattu               EDITOR:               VISUAL:             LANGUAGE:                 TERM: dumb            COLORTERM:              DISPLAY: :0.0              DESKTOP: lightdm-xsession         display size: 1920x1080 pixels (507x285 millimeters)                 PATH: /usr/bin:/home/mattu/linuxcnc/configs/my-4-axisCNC/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items:          nodename -n: duco       kernel-name -s: Linux       kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc           machine -m: i686         processor -p: unknown          platform -i: unknown       oper system -o: GNU/Linux /proc items:              cmdline: BOOT_IMAGE=/vmlinuz-3.4-9-rtai-686-pae root=UUID=a8f2ffdf-03e5-42b8-9ef2-4dfa2dbd4c6a ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5           model name: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz                cores: 2              cpu MHz: 2499.949              parport: 0378-037a : parport0               serial: 03f8-03ff : serial Versions:                  gcc: gcc (Debian 4.7.2-5) 4.7.2               python: Python 2.7.3                  git: git version 1.7.10.4           git commit: NA                  tcl: 8.5                   tk: 8.5                glade: not_in_PATH           glade-gtk2: glade3 3.8.0 linuxcnc_var all:      LINUXCNCVERSION: 2.8.2-72-gbcb0b7c LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples             REALTIME: /etc/init.d/realtime                  RTS: /usr/realtime-3.4-9-rtai-686-pae/bin/rtai-config           HALLIB_DIR: /usr/share/linuxcnc/hallib dpkg -l '*linuxcnc*': Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name                                    Version                            Architecture Description +++-=======================================-==================================-============-============================================================================== ii  linuxcnc                                1:2.8.2.72.gbcb0b7c                i386         motion controller for CNC machines and robots ii  linuxcnc-dev                            1:2.8.2.72.gbcb0b7c                i386         PC based motion controller for real-time Linux un  linuxcnc-doc                            <none>                                          (no description available) ii  linuxcnc-doc-en                         1:2.8.2.72.gbcb0b7c                all          motion controller for CNC machines and robots (English documentation) un  linuxcnc-sim                            <none>                                          (no description available) un  linuxcnc-sim-dev                        <none>                                          (no description available) rc  linuxcnc-uspace                         1:2.8.2.72.gbcb0b7c                i386         motion controller for CNC machines and robots un  linuxcnc-uspace-dev                     <none>                                          (no description available)
4 years 9 months ago #231911 by Matt Hat
Same issue for same procedure for XYZACkins -- 5-axis kinematics for a milling machine
wiki.linuxcnc.org/cgi-bin/wiki.pl?ContributedComponents
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.8.2-72-gbcb0b7c Machine configuration directory is '/home/mattu/linuxcnc/configs/XYZAC' Machine configuration file is 'XYZAC.ini' INIFILE=/home/mattu/linuxcnc/configs/XYZAC/XYZAC.ini VERSION=1.1 check_config: Unchecked: [KINS]KINEMATICS={XYZACkins coordinates=XYZACW} PARAMETER_FILE=XYZAC.var TASK=milltask HALUI=halui DISPLAY=axis COORDINATES=XYZACW KINEMATICS=XYZACkins coordinates=XYZACW Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./XYZAC_sim.hal Shutting down and cleaning up LinuxCNC... Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: . Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/XYZACkins.ko: Unknown symbol in module ./XYZAC_sim.hal:4: exit value: 1 ./XYZAC_sim.hal:4: insmod for XYZACkins failed, returned -1 See the output of 'dmesg' for more information. 4652 Stopping realtime threads Unloading hal components Kernel message information: [11690.178210] I-pipe: head domain RTAI registered. [11690.178215] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [11690.178247] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [11690.178250] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12499048, CLK_FREQ 2499949000, CPU_FREQ 2499949000 [11690.178253] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [11690.178256] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12499048, 12499048, 11888500 [11690.186417] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [11690.186458] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [11690.186463] RTAI[sched]: hard timer type/freq = APIC/12499048(Hz); default timing: oneshot; linear timed lists. [11690.186466] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2499949000 hz. [11690.186468] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [11690.191477] RTAI[math]: loaded. [11690.336181] XYZACkins: Unknown parameter `coordinates' [11690.590860] RTAI[math]: unloaded. [11690.592483] SCHED releases registered named ALIEN PEDV$D [11690.597138] RTAI[malloc]: unloaded. [11690.696023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [11690.697882] I-pipe: head domain RTAI unregistered. [11690.697917] RTAI[hal]: unmounted. ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file: /tmp/linuxcnc_info.txt can be posted to a forum or a web site like: http://pastebin.com in order to provide information about the linuxcnc system and configuration. Date: Sat Jan 15 21:06:48 CET 2022 UTC Date: Sat Jan 15 20:06:48 UTC 2022 this program: /usr/bin/linuxcnc_info uptime: 21:06:48 up 3:15, 2 users, load average: 0.09, 0.08, 0.12 lsb_release -sa: Debian Debian GNU/Linux 7.11 (wheezy) 7.11 wheezy which linuxcnc: /usr/bin/linuxcnc pwd: /home/mattu/linuxcnc/configs/XYZAC USER: mattu LOGNAME: mattu HOME: /home/mattu EDITOR: VISUAL: LANGUAGE: TERM: dumb COLORTERM: DISPLAY: :0.0 DESKTOP: lightdm-xsession display size: 1920x1080 pixels (507x285 millimeters) PATH: /usr/bin:/home/mattu/linuxcnc/configs/XYZAC/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items: nodename -n: duco kernel-name -s: Linux kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc machine -m: i686 processor -p: unknown platform -i: unknown oper system -o: GNU/Linux /proc items: cmdline: BOOT_IMAGE=/vmlinuz-3.4-9-rtai-686-pae root=UUID=a8f2ffdf-03e5-42b8-9ef2-4dfa2dbd4c6a ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 model name: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz cores: 2 cpu MHz: 2499.949 parport: 0378-037a : parport0 serial: 03f8-03ff : serial Versions: gcc: gcc (Debian 4.7.2-5) 4.7.2 python: Python 2.7.3 git: git version 1.7.10.4 git commit: NA tcl: 8.5 tk: 8.5 glade: not_in_PATH glade-gtk2: glade3 3.8.0 linuxcnc_var all: LINUXCNCVERSION: 2.8.2-72-gbcb0b7c LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples REALTIME: /etc/init.d/realtime RTS: /usr/realtime-3.4-9-rtai-686-pae/bin/rtai-config HALLIB_DIR: /usr/share/linuxcnc/hallib dpkg -l '*linuxcnc*': Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-=======================================-==================================-============-============================================================================== ii linuxcnc 1:2.8.2.72.gbcb0b7c i386 motion controller for CNC machines and robots ii linuxcnc-dev 1:2.8.2.72.gbcb0b7c i386 PC based motion controller for real-time Linux un linuxcnc-doc <none> (no description available) ii linuxcnc-doc-en 1:2.8.2.72.gbcb0b7c all motion controller for CNC machines and robots (English documentation) un linuxcnc-sim <none> (no description available) un linuxcnc-sim-dev <none> (no description available) rc linuxcnc-uspace 1:2.8.2.72.gbcb0b7c i386 motion controller for CNC machines and robots un linuxcnc-uspace-dev <none> (no description available)
  • New Member
  • New Member
4 years 9 months ago - 4 years 9 months ago #231924 by ALittleOffTheRails
Ok what i would do is uninstall (apt purge) all versions of Linuxcnc then install the version that matches your kernel, eg either rt for rtai or uspace for rt_preemept. Make sure the linuxcnc-dev package matches as well.
what does the following return ?
uname -a
Make sure you have the kernel headers installed for the kernel you are using as well.
Last edit: 4 years 9 months ago by ALittleOffTheRails.
Time to create page: 0.092 seconds
