4th and 5th axes fail to function
- elf
- Thank you received: 14
18 Jan 2022 01:20 #232223
by elf
4th and 5th axes fail to function was created by elf
I'm using Pncconf Wizard to add 4th and 5th axes to Mesa 7i76e hardware. X, Y, and Z are using Clearpath SDSK servos and are functioning. The 4th and 5th axes are using DM542T (version 4) drivers. When connected to another machine, the steppers and drivers are working properly. Axis A does not respond in the wizard.
Hal and ini files attached.
- Thank you received: 4154
18 Jan 2022 01:38 #232229
Replied by rodw on topic 4th and 5th axes fail to function
Can you check that 5v is selected with the switch on the drive?
You are the second reporting issues with this drive
forum.linuxcnc.org/38-general-linuxcnc-q.../44771-7i76e?start=0
- elf
18 Jan 2022 02:23 #232232
by elf
Replied by elf on topic 4th and 5th axes fail to function
Funny, you should mention that
The other machine I used to do the test is a rose engine for which I designed the hardware and firmware. It can use onboard drv8825 drivers or external drivers. Last week one of the users installed the DM542T v4 driver and couldn't get them to work. I finally convinced him that even though the drivers were using 24v to power the steppers, the logic was 5v.
18 Jan 2022 02:57 #232238
Did they work when set to 5 volts?
- elf
18 Jan 2022 03:10 #232241
by elf
The drivers work when set to 5v on the rose engine, but not with the 7i76e and Linuxcnc. I'm using a single 24v power supply for the 7i76e and the steppers. (The servos use 75v). I've tried supplying 5v to the Enable pins on the driver, but that didn't change the behaviour from not having any connection to the Enable pins.
18 Jan 2022 03:36 #232244
Very strange. I've used the DM542A from Longs Motors for years and they perform really well. I did hear some DM542's from other suppliers were not so good so I was fussy with brands.
I have had one other drive fail to run on my 7i76e which was a 2 amp Sanyo Denki Nema 24 on a throttled back 6 amp LAM Technologies DS1076a but it ran fine on a 3 amp Lam DS1073a so I worked around it.
All I can think of is 24 volts is close to the minimum voltage of 20 volts.
I am contemplating purchasing some DM542's from rtelligent who have a version that will handle my 60V AC toroid. Seems like brand definitely matters!
- Thank you received: 7504
18 Jan 2022 04:53 #232257
Replied by tommylight on topic 4th and 5th axes fail to function
Do the motors wired to 542 lock when power is applied?
If yes, set the step time and step space to at least 5000 in the ini file and test again.
18 Jan 2022 04:57 #232259
I'd be surprised if that makes a difference as this is what I was using. But on a different brand of DM542Do the motors wired to 542 lock when power is applied?
DIRSETUP = 500
DIRHOLD = 500
STEPLEN = 2500
STEPSPACE = 2500Please Log in or Create an account to join the conversation.
18 Jan 2022 04:59 #232260
And this is what is in the users ini file posted earlier
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
- elf
18 Jan 2022 14:06 #232328
by elf
Well, I can't see any big differences in the .hal and .ini files, but the 4th and 5th axes are working now. I removed the wires to the Enable pins and set microstepping to 8 in the wizard. I also added the B axis by copying the A axis.
Time to create page: 0.107 seconds
