(Need Help) Linux CNC + EtherCat + RPi 4 Setup
- Dj Junior
24 Jan 2022 12:37 - 24 Jan 2022 12:50 #232954
by Dj Junior
(Need Help) Linux CNC + EtherCat + RPi 4 Setup was created by Dj Junior
Hi everyone
I hope not to have the wrong section, this is my first post from Italy. I am installing linuxcnc on rpi with ethercat following the instructions of
Bouni whom I thank in advance for the work done
gist.github.com/Bouni/8b4532d0bdf012bd83c65d3eb62f8aa2
and MetalMusings
I followed the instructions step by step but arrived at the last stage:
halcmd setp lcec.0.<module-no>.dout-<output-no> <state>
halcmd setp lcec.0.3.dout-3 1 (knowing my el2008 device is the third slave)
I get the following error: <commandline>: 0: parameter or pin 'lcec.0.3.dout-3' not found
In addition, starting linuxcnc I get the following error:
HAL: ERROR: thread 'servo-thread' not found
I've searched for a file or function with the name servo-thread but can't find anything
I'm probably missing something.
Can anyone help me?
pi@linuxcnc:~ $ ethercat slaves
0 0:0 PREOP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL1018 8Ch. Dig. Input 24V, 10�s
2 0:2 PREOP + EL1104 4K. Dig. Eingang 24V, 3ms, Sensorversorgung
3 0:3 PREOP + EL2008 8K. Dig. Ausgang 24V, 0.5A
4 0:4 PREOP + TQ870(COE)
5 0:5 PREOP + TQ870(COE)
Thanks in advance.
Ps: Thanks to everyone who wrote source code to make our life easier
and MetalMusings
Can anyone help me?
Thanks in advance.
Last edit: 24 Jan 2022 12:50 by Dj Junior.
- Thank you received: 7478
24 Jan 2022 13:34 #232957
Replied by tommylight on topic (Need Help) Linux CNC + EtherCat + RPi 4 Setup
Edit the .INI file, there should be and entry for
servo-period
in the emcmot section, something like this:
servo-period
[EMCMOT]
EMCMOT = motmod
SERVO_PERIOD = 1000000Please Log in or Create an account to join the conversation.
- arvidb
- Thank you received: 158
24 Jan 2022 13:43 #232960
by arvidb
Replied by arvidb on topic (Need Help) Linux CNC + EtherCat + RPi 4 Setup
If your device is the third slave it will have number 2, since slave numbers start at 0.Hi everyone
- Dj Junior
24 Jan 2022 14:24 #232964
by Dj Junior
Replied by Dj Junior on topic (Need Help) Linux CNC + EtherCat + RPi 4 Setup
Thanks for your quick reply
I entered SERVO_PERIOD = 1000000 in the axis.ini file but I get the same error
- Dj Junior
24 Jan 2022 14:27 #232965
by Dj Junior
Sorry I made a mistake. It is in the fourth position
pi@linuxcnc:~/linuxcnc/configs/sim.axis $ ethercat slave
24 Jan 2022 14:31 #232967
What error ?
- Dj Junior
24 Jan 2022 14:36 - 24 Jan 2022 14:37 #232968
by Dj Junior
This error thread 'servo-thread' not found
pi@linuxcnc:~/linuxcnc/configs/sim.axis $ linuxcnc axis.ini
LINUXCNC - 2.8.2
Machine configuration directory is '/home/pi/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
application-specific initialization failed: no display name and no $DISPLAY environment variable
Error in startup script: invalid command name "."
while executing
". configure -borderwidth 0 -highlightthickness 0"
(file "/usr/lib/tcltk/linuxcnc/bin/popimage" line 35)
Found file(REL): ./ethercat.hal
Note: Using POSIX realtime
./ethercat.hal:3: addf failed
LinuxCNC terminated with an error. You can find more information in the log:
/home/pi/linuxcnc_debug.txt
and
/home/pi/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
LINUXCNC - 2.8.2
while executing
and
Last edit: 24 Jan 2022 14:37 by Dj Junior.
24 Jan 2022 17:15 #232984
Well that should have gotten rid of that error, so do check again if it is added to the correct section, otherwise i can not think of anything causing that error.
Can you upload the ini file here ?
- Dj Junior
24 Jan 2022 17:57 - 24 Jan 2022 18:01 #232989
by Dj Junior
Here are the configuration files
I noticed that the SERVO_PERIOD variable was already present so one was removed
Last edit: 24 Jan 2022 18:01 by Dj Junior.
- Hakan
- Thank you received: 454
24 Jan 2022 18:41 - 24 Jan 2022 18:43 #232995
by Hakan
Replied by Hakan on topic (Need Help) Linux CNC + EtherCat + RPi 4 Setup
Hi Dj, I made that video.
I would think you should add the HALFILE line as the last line in this section
Put it after the "HALFILE = check_xyz_constraints.hal" line.
Then there is something with the gui, are you running this without a display? Not sure how that works.
Also, with that specific ethercat-conf.xml you will not see the individual devices, just that ethercat is up and running. To get the devices in there is another ethercat-conf.xml; it is in a forum-posts further in that thread. As others already have pointed out, the devices in ethercat-conf.xml must be ordered the same way as you see in your listing.[/code]
[HAL]
HALFILE = ethercat.hal
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALFILE = core_sim.hal
HALFILE = sim_spindle_encoder.hal
HALFILE = axis_manualtoolchange.hal
HALFILE = simulated_home.hal
HALFILE = check_xyz_constraints.halPut it after the "HALFILE = check_xyz_constraints.hal" line.
Last edit: 24 Jan 2022 18:43 by Hakan.
Time to create page: 0.393 seconds
