Installing Beckhoff ethercat 64 bit with linuxcnc
- Dj Junior
02 Feb 2022 08:54 - 02 Feb 2022 08:56 #233780
by Dj Junior
Installing Beckhoff ethercat 64 bit with linuxcnc was created by Dj Junior
Hi everyone
i followed the Grotius's tutorial to install linux on my machine. But when I arrived at step 2 (ec-debianize) with the command dpkg-buildpackage it gives me the following error
dpkg-source: error: can't build with source format '3.0 (quilt)': no upstream tarball found at ../etherlabmaster_1.5.2+20190904hg33b922p8ea394.orig.tar.{bz2,gz,lzma,xz}
dpkg-buildpackage: error: dpkg-source -b etherlabmaster gave error exit status 255
looking on the internet they say to use the following command
dpkg-buildpackage -b -rfakeroot -us -uc
but this also gives the following error
Can't stat debian/tmp: No such file or directory
at /usr/bin/dh_install line 288.
dh_install: missing files, aborting
debian/rules:30: recipe for target 'override_dh_install' failed
make[1]: *** [override_dh_install] Error 255
make[1]: Leaving directory '/home/djunior/ec-debianize/etherlabmaster'
debian/rules:15: recipe for target 'binary' failed
make: *** [binary] Error 2
dpkg-buildpackage: error: fakeroot debian/rules binary gave error exit status 2
What can it be due to?
Last edit: 02 Feb 2022 08:56 by Dj Junior.
- Grotius
- Thank you received: 2349
02 Feb 2022 10:19 #233784
by Grotius
Replied by Grotius on topic Installing Beckhoff ethercat 64 bit with linuxcnc
I think that tutorial is outdated. Some things are changed in the past time.
Try this one.
forum.linuxcnc.org/ethercat/44969-can-t-...file?start=10#233638
If you want to get more insights extract the .deb file and have a look at the postinst file.
To repack the deb you can perform a duckduck.
Try this one.
- Dj Junior
02 Feb 2022 10:24 #233785
by Dj Junior
Replied by Dj Junior on topic Installing Beckhoff ethercat 64 bit with linuxcnc
Time to create page: 1.062 seconds
