Can't install etherlabmaster deb file
  • Hakan
  • Platinum Member
  • Platinum Member
31 Jan 2022 02:30 - 31 Jan 2022 02:30 #233613 by Hakan
Replied by Hakan on topic Can't install etherlabmaster deb file
I think the chance is more than 50% that it works. I have an "unsupported" builtin network interface and the GENERIC driver works just fine.
I looked at the gitlab code and maybe it is better to be at the source of everything. But I couldn't find anything that fixes your problem.
I looked around in the code. This is what it looks like when the problem occurs.
#ifdef EC_DEBUG_RING
#define EC_DEBUG_RING_SIZE 10
typedef enum {
TX, RX
} ec_debug_frame_dir_t;
typedef struct {
ec_debug_frame_dir_t dir;
struct timeval t;
uint8_t data[EC_MAX_DATA_SIZE];
unsigned int data_size;
} ec_debug_frame_t;
#endif
So the code is surrounded by the #ifdef EC_DEBUG_RING so I think this code is active only when debugging is switched one. If you could switch off the debug and undefine the EC_DEBUG_RING, then this piece of code will not be active and it should be smooth sailing to build the kernel modules.
I can't help, I don't have a 5.10 system. And to find how to do this using ec-debianize well that is why I went away from it in the first place.
Last edit: 31 Jan 2022 02:30 by Hakan.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Jan 2022 02:57 #233616 by rodw
Replied by rodw on topic Can't install etherlabmaster deb file
Thanks, I had another go today using the igh git and then your git on a pi.
Both failed at exactly the same place. Looking for a network driver for the 5.10 kernel in the ethercat source.
I think I'm between a rock and a hard place. It won't install on bullseye and I can't use Buster because I need the NIC driver that is included in Bullseye. Its an extentsion to the RT8169 driver which is supported by ethercat. Last time I tried the LCNC 2.8 .ISO on this PC, it would not install without a network connection so I could not get far enough to install the network driver.
2.8 would be ok for this machine. I might look at Linux Mint again with 2.8. I'm that used to working with master branch for plasma...
Silly part is I have an older pc running Debian 11 and ethercat.... It coming to work with me tomorrow :)
31 Jan 2022 09:12 #233638 by Grotius
Replied by Grotius on topic Can't install etherlabmaster deb file
Hi Rod,
Problably this will work:
wget github.com/grotius-cnc/Linux-Pro/release.../ethercat-master.deb
dpkg -i ethercat-master.deb
/opt/ethercat/script/init.d/ethercat restart
  • rodw
  • Platinum Member
  • Platinum Member
31 Jan 2022 12:10 #233656 by rodw
Grotius, thanks, I will give it a go I think.
Hopefully, I should be able to install my NIC driver after it is installed
I was wrong here. Its running debian 10 by the look of the kernel version...
  • rodw
  • Platinum Member
  • Platinum Member
31 Jan 2022 19:36 #233678 by rodw
Hi Rod,
A couple of errors. my network NIC is  enp3s0
cat: /sys/class/net/enp0s25/address: No such file or directory
/var/lib/dpkg/info/ethercat-master.postinst: line 47: /etc/init.d/ethercat: Permission denied
  • Hakan
  • Platinum Member
  • Platinum Member
01 Feb 2022 03:55 #233699 by Hakan
I tested to build from the source I use on Raspbian and there were two compilation errors when building the modules. It uses 5.10.something.
I had to change to "static unsigned int" on line 91 and 259 (I think) in cdev.c and then it compiles. Never tried it but that change is so minor that I think it will work.
02 Feb 2022 01:50 - 02 Feb 2022 02:21 #233774 by Grotius
Hi Rod,
I made a custom .deb package for you where the network nic is set to : enp3s0
To overcome the permission denied error, first perform these 3 terminal things :
# 1.Set user permissions /opt dir.
sudo chmod -R -f 777 /opt
# 2.Change owner /opt dir
sudo chown -R $USER /opt
# 3.Change group /opt dir
sudo chown -R $USER:$USER /opt
# 4.Install Rod's custom deb package
wget https://github.com/grotius-cnc/dump/releases/download/1.0/ethercat_rod.deb
sudo dpkg -i ethercat_rod.deb
Last edit: 02 Feb 2022 02:21 by Grotius.
  • rodw
  • Platinum Member
  • Platinum Member
10 Feb 2022 01:32 #234471 by rodw
Grotius, you are indeed a magician, I can now list the slaves!
Thank you very much.
But I am having trouble opening my config. I suspect files may not be in the right spot yet because of the shortcuts we took.
I had to manually copy some files to the /lib/linuxcnc/modules folder but still they do not open. Any ideas here?
mill2@mill2:~/dev/linuxcnc-ethercat/src$ linuxcnc -l
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/mill2/linuxcnc/configs/linuxcnc-cia402'
Machine configuration file is 'cia402.ini'
Starting LinuxCNC...
emc/iotask/ioControl_v2.cc 888: iov2: can't load tool table.
Found file(REL): ./cia402.hal
Note: Using POSIX realtime
./cia402.hal:14: execv(./lcec_conf): No such file or directory
./cia402.hal:14: waitpid failed ./lcec_conf lcec_conf
./cia402.hal:14: ./lcec_conf exited without becoming ready
iov2: exiting
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/mill2/linuxcnc_debug.txt
and
    /home/mill2/linuxcnc_print.txt
  • rodw
  • Platinum Member
  • Platinum Member
10 Feb 2022 03:52 #234480 by rodw
I suspect I need to install the linuxcnc-dev deb. Will regroup tomorrow.
  • rodw
  • Platinum Member
  • Platinum Member
10 Feb 2022 17:49 #234538 by rodw
Well, I made some progress following advice on this forum.
At least the xml is opened and parsed but
Now I get:
lcec: dlopen: libethercat.so.1: cannot open shared object file: No such file or directory
I am hoping this is just a path issue. Help would be appreciated
Time to create page: 0.252 seconds
