Can't install etherlabmaster deb file
- Thank you received: 4154
10 Feb 2022 20:25 - 10 Feb 2022 20:26 #234547
Replied by rodw on topic Can't install etherlabmaster deb file
got it!
Edit ~/.profile and add
export LD_LIBRARY_PATH=usr/local/lib
This will let the linker find the libethercat.so.1 library at run time
Thanks for the help guys.
Now I just have to get ethercat service to auto start. Any ideas?
I found this debian link so I think I'll give it a try
wiki.debian.org/systemd/Services
Last edit: 10 Feb 2022 20:26 by rodw.
- Grotius
- Thank you received: 2349
11 Feb 2022 07:37 - 11 Feb 2022 07:40 #234571
by Grotius
Replied by Grotius on topic Can't install etherlabmaster deb file
One of my favorite script files, debootstrap chrooting and more:
github.com/grotius-cnc/Linux-Pro/release...d/1.0.0/this-iso.txt
line 47 tells you how to auto start the ethercat bus. Just edit the "enp0s25" to your value :
# Edit crontab -e
# Add lines :
@reboot echo MASTER0_DEVICE="$(cat /sys/class/net/enp0s25/address)" DEVICE_MODULES=generic > /etc/sysconfig/ethercat
# Slow down the process so above line is done before the restart.
@reboot /opt/ethercat/script/init.d/ethercat start
@reboot /opt/ethercat/script/init.d/ethercat stop
@reboot /opt/ethercat/script/init.d/ethercat restart
Last edit: 11 Feb 2022 07:40 by Grotius.
- Grotius
11 Feb 2022 09:42 #234577
by Grotius
lcec: dlopen: libethercat.so.1: cannot open shared object file: No such file or directory
Then i would suggest to do a : $ sudo ldconfig ~/paht_to_your_lib.
But I am having trouble opening my config. I suspect files may not be in the right spot yet because of the shortcuts we took.
I had to manually copy some files to the /lib/linuxcnc/modules folder but still they do not open. Any ideas here?
Here you see the whole lcnc-ethercat implementation is just a rt-component. A clean solution.
The lcec.so & lcec_conf & ethercat-conf.xml is copied to the ~/rtlib/
- Grotius
11 Feb 2022 09:46 - 11 Feb 2022 09:49 #234579
by Grotius
And if you look at the make file. You see it's compiled by gcc instead of halcompile.
You can easely add your own ethercat-drivers to the list. I think hal-core is rpi compatible thanks to a contribution.
You can just rip the ethercat hal-core code and put it in the lcnc environment.
Last edit: 11 Feb 2022 09:49 by Grotius.
Time to create page: 0.873 seconds
