current master (2.9) building debs error?
- robertspark
- Thank you received: 216
rob@RobsCNC:~/linuxcnc-dev/debian$ ./configure no-docs uspace
uspace is accepted for compatibility, but ignored successfully configured for 'uspace-Debian-11'..
rob@RobsCNC:~/linuxcnc-dev/debian$ cd ..
rob@RobsCNC:~/linuxcnc-dev$ dpkg-buildpackage -j4 -b -uc
dpkg-buildpackage: error: syntax error in debian/control at line 44: block lacks the 'Package' fieldany ideas what i should be doing different?
thanks
- Thank you received: 4154
There were some changes required for Debian Packaging.
I remember having similar issues but got past it
I may have dropped the no-docs
- robertspark
I did check the Dev docs and there wasn't anything different
so that may need changing
linuxcnc.org/docs/devel/html/code/buildi...ding_debian_packages
I'll give it a try later thanks again
github.com/LinuxCNC/linuxcnc/pull/1700
It followed on from a issue I logged because linuxcnc-uspace package in Debian unstable was uninstallable because of an change in python versions.
- tripwire
- Thank you received: 12
Did it work for you @robertspark? If not, what was your solution?
- robertspark
basically it was my no-docs that was wrong {that seems to have been removed}
./configure uspace
then
cd ..
if you have a 4 core processor then add j4.... it will speed up the build.... just add the right number to match your cores (2,4,16, 32).
- tripwire
I can launch linuxcnc but when I try to open, say axis, I get the following:
dave@debianDave:~$ linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/dave/linuxcnc/configs/sim.axis-2'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(lib): /usr/share/linuxcnc/hallib/check_xyz_constraints.hal
link (updating variable file): No such file or directory
File "/usr/bin/hal_manualtoolchange", line 69, in <module>
nf.start(app); nf.makecommand(app, "_", _)
File "/usr/lib/python3/dist-packages/nf.py", line 120, in start
source_lib_tcl(r, "support.tcl")
File "/usr/lib/python3/dist-packages/nf.py", line 112, in source_lib_tcl
r.tk.call("source", os.path.join(tcl_libdir, f))
_tkinter.TclError: couldn't load file "/usr/lib/tcltk/x86_64-linux-gnu/Img1.4.13/libtifftcl4.1.0.so": /usr/lib/tcltk/x86_64-linux-gnu/Img1.4.13/libtifftcl4.1.0.so: undefined symbol: _TIFFsetString, version LIBTIFF_4.0
File "/usr/bin/axis", line 128, in <module>
nf.start(root_window)
task: 1192 cycles, min=0.000010, max=0.001213, avg=0.001053, 0 latency excursions (> 10x expected cycle time of 0.001000s)
LinuxCNC terminated with an error. You can find more information in the log:
/home/dave/linuxcnc_debug.txt
and
/home/dave/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
dave@debianDave:~$Any ideas?
Thanks.
- robertspark
did the build go well?
how did you install linuxcnc debs?
sudo dpkg -i package_file.debdid you install all of the debs?
it looks like it is missing part of the files.... those are compiled files....
what are you installing it on? (Debian / Ubuntu / MX / Mint???)
what hardware (PC I presume x86?)
- robertspark
linuxcnc.org/docs/devel/html/code/buildi...g-Build-Dependencies
sudo apt-get install dpkg-dev
cd linuxcnc-dev/debian
./configure uspace
cd ..
dpkg-checkbuilddeps.... if not, install the missing ones and rebuild + reinstall the debs...
- tripwire
dave@debianDave:~$ sudo apt-get install dpkg-dev
[sudo] password for dave:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
dpkg-dev is already the newest version (1.21.7).
dpkg-dev set to manually installed.
The following packages were automatically installed and are no longer required:
bc cups cups-browsed cups-client cups-core-drivers cups-daemon cups-filters
cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
fcitx-bin fcitx-frontend-all fcitx-frontend-qt6 fcitx-ui-classic
fcitx5-config-qt fcitx5-frontend-gtk3 fcitx5-frontend-qt5 fonts-symbola
g++-10 gir1.2-champlain-0.12 gir1.2-dazzle-1.0 gir1.2-evince-3.0
gir1.2-gdata-0.0 gir1.2-geocodeglib-1.0 gir1.2-gfbgraph-0.2
gir1.2-gnomebluetooth-1.0 gir1.2-gtkchamplain-0.12 gir1.2-gtkclutter-1.0
gir1.2-gweather-3.0 gir1.2-handy-0.0 gir1.2-rb-3.0 gir1.2-rest-0.7
gir1.2-tracker-2.0 gir1.2-zpj-0.0 hyphen-en-us libabsl20200923 libamtk-5-0
libamtk-5-common libaom0 libb2-1 libbotan-2-17 libcamel-1.2-62 libcbor0
libcmis-0.5-5v5 libcodec2-0.9 libcolord-gtk1 libcupsfilters1 libdav1d4
libdazzle-1.0-0 libdazzle-common libedataserver-1.2-25
libedataserverui-1.2-2 libextutils-pkgconfig-perl libfcitx5gclient1
libfcitx5gclient2 libfluidsynth2 libfontembed1 libfwupdplugin1
libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf2.0-0 libgettextpo0 libgit2-1.1
libglew2.1 libgpod-common libgpod4 libgupnp-1.2-0 libgweather-3-16
libgweather-common libhandy-0.0-0 libicu67 libidn11 libigdgmm11 libime-bin
libkf5itemviews-data libkf5itemviews5 libkf5widgetsaddons-data
libkf5widgetsaddons5 libldap-2.4-2 liblibreoffice-java liblirc-client0
libllvm11 liblouisutdml-bin liblouisutdml-data liblouisutdml9 libmailutils7
libmbedcrypto3 libmbedtls12 libmbedx509-0 libmms0 libmozjs-78-0
libmusicbrainz5-2 libmusicbrainz5cc2v5 libneon27-gnutls libntfs-3g883
libofa0 liborcus-0.16-0 liborcus-parser-0.16-0 libotf0 libperl5.32
libpoppler-cpp0v5 libpoppler102 libpth20 libpython3.9 libqpdf28
libqrcodegencpp1 libqt6core6 libqt6dbus6 libqt6gui6 libquvi-0.9-0.9.3
libquvi-scripts-0.9 libreoffice-help-en-us libsgutils2-2 libstdc++-10-dev
libtepl-5-0 libtracker-control-2.0-0 libtracker-miner-2.0-0
libtracker-sparql-2.0-0 libunoloader-java liburing1 libvpx6 libwebp6
libx264-160 libx265-192 libxcb-damage0 libxencall1 libxendevicemodel1
libxenevtchn1 libxenforeignmemory1 libxengnttab1 libxenhypfs1 libxenmisc4.14
libxenstore3.0 libxentoolcore1 libxentoollog1 libxmlb1 lua-bitop lua-expat
lua-json lua-lpeg lua-socket mythes-en-us perl-modules-5.32 python3-ldb
python3-mako python3-markupsafe python3-serial python3-talloc
qt6-gtk-platformtheme ruby2.7 task-desktop tegaki-zinnia-japanese
unicon-imc2 unoconv ure-java x11-apps x11-session-utils xinit xorg
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
dave@debianDave:~$And
dave@debianDave:~$ cd dev/linuxcnc/debian
dave@debianDave:~/dev/linuxcnc/debian$ ./configure uspace
successfully configured for 'uspace-Debian-unstable'..
dave@debianDave:~/dev/linuxcnc/debian$dave@debianDave:~/dev/linuxcnc$ dpkg-checkbuilddeps
dave@debianDave:~/dev/linuxcnc$And...I'm getting the same error message when I try to open axis...
I'm installing LINUXCNC - 2.9.0~pre0 on Debian 11 on a x86 machine. I was following rodw's instructions in one of his posts (I can't even find it now.) I had all this working before but ran into a snag with qtpyvcp and ended up reinstalling Debian 11.
Is there a definitive recipe for installing linuxcnc 9 on Debian 11?
Thanks.
