current master (2.9) building debs error?
- robertspark
- Thank you received: 216
25 May 2022 23:02 #243858
by robertspark
Replied by robertspark on topic current master (2.9) building debs error?
thinking about it...... there may be a quicker / easier way than building debs on your local machine.....
Just install a clean version of debian bullseye
I would recommend:
cdimage.debian.org/cdimage/unofficial/no....0-amd64-netinst.iso
then just install the debs from the buildbot respostory for linuxcnc and install them:
buildbot.linuxcnc.org/dists/buster/maste...reempt/binary-amd64/
basically just look for the newest date ones:
you only need:
buildbot.linuxcnc.org/dists/buster/maste...g433a36711_amd64.deb
buildbot.linuxcnc.org/dists/buster/maste...1.g433a36711_all.deb
install each of the debs using:
and you SHOULD have a working linuxcnc distro.....
there may be dependencies when you try to install the deb files.... just install them
(I can give you a walkthrough tomorrow night if you want)
I would recommend:
you only need:
sudo dpkg -i <packagename>.deband you SHOULD have a working linuxcnc distro.....
The following user(s) said Thank You: tripwire
- tripwire
- Thank you received: 12
25 May 2022 23:26 #243859
by tripwire
Replied by tripwire on topic current master (2.9) building debs error?
I really appreciate your detailed help on this, thanks!
I’ll try the bullseye/lcnc 2.9 (yes, not “9”) install tomorrow as per your instructions and let you know how it goes. (I’m in the U.S. Pacific time.)
(Btw, I’m using linuxcnc for a 3-axis homemade CNC router.)
Thanks again!
Thanks again!
- robertspark
26 May 2022 06:05 #243870
by robertspark
I'm in the UK on GMT+1/ Zulu+1 time (British summer time).
I'll set up a pc with bullseye and the current master from debs so if you have issues I should have the same ones
give me a few hours need to get the day job out of the way
- robertspark
26 May 2022 10:08 #243885
by robertspark
Hmm.... lets take a step back.... What is your final destination for qtpyvcp?
what GUI do you want to run?
are you looking for ProbeBasic?
I ask because the instructions for ProbeBasic are confusing..... (bare with me, before the posts start flying).
probe basics install instructions are written for BUSTER + LinuxCNC 2.8
kcjengr.github.io/probe_basic/index.html
qtpyvcp install instructions and recommendations are to use Debian 11 and Master.
www.qtpyvcp.com/install/bullseye.html
or at least some of them are....
I've set up a debian 11 / bullseye machine (clean install) and got as far as a working qtpyvcp install.... then I've come to add probebasic and the dependencies listed are all python(2)....!!!
I've just remembered that there is another branch for probe basic!!! which is the python3 branch. Just remember why I hated the install last time.
github.com/kcjengr/probe_basic/tree/python3
QTPyVCP "master" branch is for Python3.
ProbeBasic "master" is for Python2!!!!
again what is your final destination ..... what gui do you want to install??
Thanks for that. But can you be more specific with the commands and file locations? I haven’t used buildbot before.
And will I end up with. Debian 11 and Linuxcnc 9? I plan to work with qtpyvcp so I think those are prerequisits.
Thanks!
- tripwire
26 May 2022 14:25 #243897
by tripwire
Great questions. I was actually creating my own linuxcnc gui in qtpyvcp, incorporating a lot of Probe Basic features. (Mainly because Probe Basic requires Python2 and I like the challenge of creating it myself
.) As I said, I had a working Bullseye, lcnc2.9, qtpyvcp system running. I got pretty far along with my gui. Then, I think because of an improper pc shutdown, something broke. I started a topic about it
here
. My problem never got solved so I reinstalled Bullseye and ran into an issue installing lcnc2.9 which is the subject of this topic.
So, now I have a(nother!) fresh install of Bullseye and am ready to install lcnc2.9 and qtpyvcp.
I notice that the lcnc debs you listed in a previous post were all located in a Buster directory. Is this what I want?
I believe I did have success following the instructions for the Bullseye installation of lcnc2.9 and qtpyvcp on qtpyvcp.com.
Again, I really appreciate your help on this!!
Dave
Dave
- robertspark
26 May 2022 14:49 #243901
by robertspark
if you follow this / these you will get a working linuxcnc install of bullseye and 2.9
forum.linuxcnc.org/show-your-stuff/45039...etup?start=10#243886
I have had pyqtvcp running once with it earlier in the day, I am just testing the second install of pyqtvcp.... hence it WILL work up to the qtpyvcp part ..... after that I would wait.... I need to test something else
- robertspark
26 May 2022 15:52 #243910
by robertspark
I can now confirm that if you follow the sequence up to the
PROBE BASIC
on the above post of mine it WILL install
Debian Bullseye 11 + Linuxcnc + QTPyVCP and it WILL work.
PROBE BASIC
- tripwire
26 May 2022 15:56 #243913
by tripwire
Thanks for that!!
I posted a few questions about the sequence in that thread. When I hear back, I'll give it a try.
Thanks again for all your work and help!
- tripwire
26 May 2022 16:01 #243915
by tripwire
Quick question-- do you use timeshift? It would be really nice to not have to reinstall everything on a little glitch...
- robertspark
26 May 2022 16:13 #243917
by robertspark
no never heard of timeshift, just found it now, thanks,
