current master (2.9) building debs error?
4 years 6 months ago #240338 by robertspark
all was working, now flinging an error:
rob@RobsCNC:~/linuxcnc-dev/debian$ ./configure no-docs uspace uspace is accepted for compatibility, but ignored successfully configured for 'uspace-Debian-11'.. rob@RobsCNC:~/linuxcnc-dev/debian$ cd .. rob@RobsCNC:~/linuxcnc-dev$ dpkg-buildpackage -j4 -b -uc dpkg-buildpackage: error: syntax error in debian/control at line 44: block lacks the 'Package' field
any ideas what i should be doing different?
thanks
4 years 6 months ago #240349 by rodw
try dpkg-buildpackage -B
There were some changes required for Debian Packaging.
I remember having similar issues but got past it
I may have dropped the no-docs
The following user(s) said Thank You: robertspark
4 years 6 months ago #240374 by robertspark
tham rod, I'll give it a shot.
I did check the Dev docs and there wasn't anything different
so that may need changing
linuxcnc.org/docs/devel/html/code/buildi...ding_debian_packages
I'll give it a try later thanks again
4 years 6 months ago #240383 by rodw
Rob, this was the issue
github.com/LinuxCNC/linuxcnc/pull/1700
It followed on from a issue I logged because linuxcnc-uspace package in Debian unstable was uninstallable because of an change in python versions.
4 years 5 months ago #243723 by tripwire
I'm getting the same error message even when running dpkg-buildpackage -B
Did it work for you @robertspark? If not, what was your solution?
4 years 5 months ago #243726 by robertspark
Yes, I've had it working.
basically it was my no-docs that was wrong {that seems to have been removed}
./configure uspace
then
cd ..
if you have a 4 core processor then add j4.... it will speed up the build.... just add the right number to match your cores (2,4,16, 32).
The following user(s) said Thank You: tripwire
Time to create page: 0.060 seconds
