ERROR: You must use the PyQt5 bindings
19 May 2022 03:12 - 19 May 2022 03:29 #243312 by tripwire
ERROR: You must use the PyQt5 bindings was created by tripwire
I'm stuck! As far as I know nothing changed (except I did turn off my pc) from when everything was working until I became unable to open any VCP in Qt Designer.
The other strange behavior is that now when I invoke editvcp on the command line, I get a file chooser dialog with no option to create a new vcp.
The main error I got when running editvcp vcptemplate from the command line is the following:
2022-05-18 19:49:49,986 - EditVCP.Designer - INFO - Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
2022-05-18 19:49:50,440 - EditVCP.Designer - INFO - /home/dave/.local/lib/python3.9/site-packages/qtpy/__init__.py:201: RuntimeWarning: Selected binding "pyqt5" could not be found, using "pyside2"
2022-05-18 19:49:50,441 - EditVCP.Designer - INFO -   warnings.warn('Selected binding "{}" could not be found, '
2022-05-18 19:49:50,442 - EditVCP.Designer - INFO - ERROR: You must use the PyQt5 bindings in order to use the custom
2022-05-18 19:49:50,442 - EditVCP.Designer - INFO - widgets in QtDesigner.
2022-05-18 19:49:50,495 - EditVCP - INFO - EditVCP finished
The following is the entire output:
[code]2022-05-18 19:49:49,521 - EditVCP - INFO - Logging to /home/dave/qtpyvcp.log
2022-05-18 19:49:49,673 - EditVCP - INFO - Loading YAML config file: /home/dave/vcptemplate/vcptemplate/config.yml
2022-05-18 19:49:49,735 - EditVCP.EditVCP.utilities.config_loader - DEBUG - Loading config files: ['/home/dave/vcptemplate/vcptemplate/config.yml', '/home/dave/dev/qtpyvcp/qtpyvcp/yaml_lib/default_config.yml']
2022-05-18 19:49:49,964 - EditVCP.EditVCP.utilities.config_loader - DEBUG - Merged YAML config:
default_menubar: &id001
- title: File
  items:
  - title: '&Open ...'
    action: win.openFile
    shortcut: ctrl+o
  - title: '&Recent Files'
    provider: qtpyvcp.widgets.recent_files_menu:RecentFilesMenu
  - title: '&Reload'
    action: program.reload
  - title: '&Close'
    action: program.clear
  - title: Save &As
    action: null
  - separator
  - title: Edit ToolTable
    action: win.showDialog
    args:
    - tool_edit
  - separator
  - title: Exit
    action: app.exit
    shortcut: ctrl+q
- title: Machine
  items:
  - title: Toggle E-Stop
    action: machine.estop.toggle
    shortcut: F1
  - title: Toggle Power
    action: machine.power.toggle
    shortcut: F2
  - separator
  - title: Run Program
    action: program.run
    shortcut: R
  - title: Step
    action: program.step
    shortcut: T
  - title: Pause
    action: program.pause
    shortcut: P
  - title: Resume
    action: program.resume
    shortcut: R
  - title: Abort
    action: program.abort
    shortcut: esc
  - title: Optional Stop
    action: program.optional_stop.toggle
  - title: Optional Skip
    action: program.optional_skip.toggle
  - separator
  - title: Homing
    provider: qtpyvcp.widgets.menus.homing_menu:HomingMenu
  - title: Cooling
    items:
    - title: Flood
      action: coolant.flood.toggle
      shortcut: F7
    - title: Mist
      action: coolant.mist.toggle
      shortcut: F8
  - title: Set Work Offsets
    args:
    - set_work_offsets
  - separator
  - title: Override Limits
    action: machine.override_limits
- title: Settings
  items:
  - title: Show On-screen Keyboard
    action: settings.virtual-input.enable
- title: View
  items:
  - title: Show Gridlines
    action: settings.backplot.show-grid
  - separator
  - title: Show Machine Bounds
    action: settings.backplot.show-machine-bounds
  - title: Show Machine Labels
    action: settings.backplot.show-machine-labels
  - title: Show Machine Ticks
    action: settings.backplot.show-machine-ticks
  - separator
  - title: Show Program Bounds
    action: settings.backplot.show-program-bounds
  - title: Show Program Labels
    action: settings.backplot.show-program-labels
  - title: Show Program Ticks
    action: settings.backplot.show-program-ticks
  - title: Use Colors per Tool
    action: settings.backplot.multitool-colors
  - separator
  - title: Perspective View
    action: settings.backplot.perspective-view
  - title: View Angle
    action: settings.backplot.view
- title: Tools
  items:
  - title: HAL Meter
    action: tool.halmeter
  - title: HAL Scope
    action: tool.halscope
  - title: HAL Show
    action: tool.halshow
  - title: LCNC Status
    action: tool.status
  - title: Calibration
    action: tool.calibration
  - title: Classicladder PLC
    action: tool.classicladder
  - title: Simulated Probe
    action: tool.simulate_probe
- title: About
  items:
  - title: About QtPyVCP
    args:
    - about_qtpyvcp
  - title: About Qt
    action: app.aboutQt
vcp:
  version: v0.0.1
  author: My Name
  description: "Put a short description of your VCP here. This will be shown in the\
    \ VCP Chooser when launching QtPyVCP with the --chooser option.\n\nExamples of\
    \ what to included here:\n  * VCP Features\n  * Type of machine the VCP is for\n\
    \  * Development status\n  * Acknowledgments"
windows:
  mainwindow:
    provider: vcptemplate.mainwindow:MyMainWindow
    kwargs:
      menu: *id001
      ui_file: /home/dave/vcptemplate/vcptemplate/ui/mainwindow.ui
      stylesheet: null
      title: vcpTemplate v0.0.1
data_plugins:
  status:
    provider: qtpyvcp.plugins.status:Status
    kwargs:
      cycle_time: 75
  persistent_data_manager:
    provider: qtpyvcp.plugins.persistent_data_manager:PersistentDataManager
    kwargs:
      serialization_method: pickle
  settings:
    provider: qtpyvcp.plugins.settings:Settings
  position:
    provider: qtpyvcp.plugins.positions:Position
    kwargs:
      report_actual_pos: true
      use_program_units: true
  tooltable:
    provider: qtpyvcp.plugins.tool_table:ToolTable
  offsettable:
    provider: qtpyvcp.plugins.offset_table:OffsetTable
  notifications:
    provider: qtpyvcp.plugins.notifications:Notifications
    kwargs:
      enabled: true
      mode: native
      max_messages: 5
      persistent: true
  file_locations:
    provider: qtpyvcp.plugins.file_locations:FileLocations
    log_level: debug
    kwargs:
      default_location: NC Files
      local_locations:
        Home: ~/
        Desktop: ~/Desktop
        NC Files: ~/linuxcnc/nc_files
      network_locations: null
    exportedhal:
      provider: qtpyvcp.plugins.exported_hal:ExportedHal
  virtual_input:
    provider: qtpyvcp.plugins.virtual_input_manager:VirtualInputManager
dialogs:
  open_file:
    provider: qtpyvcp.widgets.dialogs.open_file_dialog:OpenFileDialog
  set_work_offsets:
    provider: qtpyvcp.widgets.dialogs.offsets_dialog:OffsetsDialog
  tool_edit:
    provider: qtpyvcp.widgets.dialogs.tool_edit_dialog:ToolEditDialog
  probe_sim:
    provider: qtpyvcp.widgets.dialogs.probesim_dialog:ProbeSim
  about_qtpyvcp:
    provider: qtpyvcp.widgets.dialogs.about_dialog:AboutDialog
virtual_input_providers:
  number:
    provider: qtpyvcp.widgets.virtual_input.virtual_input:VirtualInput
    kwargs:
      ui_file: /home/dave/dev/qtpyvcp/qtpyvcp/yaml_lib/../widgets/virtual_input/numpad.ui
  text:
    kwargs:
      ui_file: /home/dave/dev/qtpyvcp/qtpyvcp/yaml_lib/../widgets/virtual_input/keyboard.ui
application:
  provider: qtpyvcp.app.application:VCPApplication
  kwargs:
    stylesheet: /home/dave/vcptemplate/vcptemplate/ui/style.qss
settings:
  touch-probe.diameter-offset:
    default_value: 0.123123
    persistent: true
    min_value: 0
    max_value: 1
  dro.display-units:
    default_value: 0
    options:
    - Auto
    - Inch
    - Metric
  dro.lathe-radius-mode:
    default_value: 0
    options:
    - Auto
    - Radius
    - Diameter
  dro.inch-format:
    default_value: '%9.4f'
    value_type: str
  dro.millimeter-format:
    default_value: '%9.3f'
    value_type: str
  dro.degree-format:
    default_value: '%9.2f'
  backplot.show-grid:
    default_value: false
  backplot.show-program-bounds:
  backplot.show-program-labels:
  backplot.show-program-ticks:
  backplot.show-machine-bounds:
  backplot.show-machine-labels:
  backplot.show-machine-ticks:
  backplot.perspective-view:
    default_value: true
  backplot.view:
    default_value: 0
    options:
    - 'X: Front View'
    - 'XZ: Lathe View'
    - 'XZ2: Lathe View'
    - 'Y: Front View'
    - 'Z: Top View'
    - 'Z2: Bottom View'
    - 'P: Isometric'
  backplot.multitool-colors:
    default_value: true
qtdesigner:
  qss_file: /home/dave/vcptemplate/vcptemplate/ui/style.qss
2022-05-18 19:49:49,966 - EditVCP - INFO - Loading UI file: /home/dave/vcptemplate/vcptemplate/ui/mainwindow.ui
2022-05-18 19:49:49,966 - EditVCP - INFO - Loading QSS file: /home/dave/vcptemplate/vcptemplate/ui/style.qss
2022-05-18 19:49:49,966 - EditVCP - INFO - Starting QtDesigner ...
Any help would be greatly appreciated!!
[/code]
Last edit: 19 May 2022 03:29 by tripwire. Reason: added more info about the problem
20 May 2022 01:47 - 20 May 2022 01:54 #243379 by tripwire
Replied by tripwire on topic ERROR: You must use the PyQt5 bindings
To try to diagnose the problem, I've placed print statements in the file, /home/dave/.local/lib/python3.9/site-packages/qtpy/__init__.py. I'm showing the state of the "API" variable. As can be seen, it stays set to "pyqt5" before the open file dialog but after I choose (any) vcp to open, you can see the variable change to pyqt6, then pyside2. I don't think it's suppose to do that.
dave@DavesLinuxMachine:~$ editvcp
(DL Diagnostics line 105 - API = pyqt5
(DL Diagnostics 2- API = pyqt5
(DL Diagnostics line 130 - API = pyqt5
(DL Diagnostics line 132- API = pyqt5
(DL Diagnostics line 156 - API = pyqt5
(DL Diagnostics line 205 - API = pyqt5
Note: at this point I'm presented with a file open dialog box instead of launching Qt Designer directly.
The following is the output in the terminal after I choose (any) vcp to edit:
2022-05-19 18:27:07,391 - EditVCP - INFO - Logging to /home/dave/qtpyvcp.log
2022-05-19 18:27:45,265 - EditVCP - INFO - Loading UI file: /home/dave/vcp1/vcp1/ui/mainwindow.ui
2022-05-19 18:27:45,266 - EditVCP - INFO - Starting QtDesigner ...
2022-05-19 18:27:45,797 - EditVCP.Designer - INFO - /home/dave/.local/lib/python3.9/site-packages/qtpy/__init__.py:207: RuntimeWarning: Selected binding "pyqt5" could not be found, using "pyside2"
2022-05-19 18:27:45,798 - EditVCP.Designer - INFO -   warnings.warn('Selected binding "{}" could not be found, '
2022-05-19 18:27:45,799 - EditVCP.Designer - INFO - (DL Diagnostics line 105 - API = pyqt5
2022-05-19 18:27:45,799 - EditVCP.Designer - INFO - (DL Diagnostics 2- API = pyqt5
2022-05-19 18:27:45,799 - EditVCP.Designer - INFO - (DL Diagnostics line 130 - API = pyqt5
2022-05-19 18:27:45,799 - EditVCP.Designer - INFO - (DL Diagnostics line 156 - API = pyqt6
2022-05-19 18:27:45,799 - EditVCP.Designer - INFO - (DL Diagnostics line 167 - API = pyside2
2022-05-19 18:27:45,799 - EditVCP.Designer - INFO - (DL Diagnostics line 205  - API = pyside2
2022-05-19 18:27:45,800 - EditVCP.Designer - INFO - ERROR: You must use the PyQt5 bindings in order to use the custom
2022-05-19 18:27:45,800 - EditVCP.Designer - INFO - widgets in QtDesigner.
2022-05-19 18:27:45,853 - EditVCP - INFO - EditVCP finished
I really need to resolve this. Please help. I don't want to reinstall everything...again!
Last edit: 20 May 2022 01:54 by tripwire.
20 May 2022 02:05 #243381 by TurBoss
Replied by TurBoss on topic ERROR: You must use the PyQt5 bindings
hello
could you try to install python3-pyqt5
thanks
20 May 2022 05:02 #243393 by tripwire
Thanks for the suggestion, TurBoss but it didn't change anything. Here is the result:
dave@DavesLinuxMachine:~$ sudo apt-get install  python3-pyqt5
[sudo] password for dave:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
python3-pyqt5 is already the newest version (5.15.2+dfsg-3).
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Before your suggestion, I had actually uninstalled python3-pyqt5 and then reinstalled it. When it was uninstalled, Qt Designer opened normally but didn't contain any of the VCP widgets. Reinstalling python3-pyqt5 didn't change the errors I was getting.
I realize I may have improperly shut down my computer which may have caused the problem. Does this fact give you any other ideas?
Thanks!
20 May 2022 05:12 #243394 by TurBoss
can you please check if the pyqt5 libraries got installed
github.com/kcjengr/qtpyvcp/tree/master/p...15.2-64bit/python3.9
thanks
20 May 2022 23:01 #243444 by tripwire
I will check that out, thanks!
21 May 2022 03:14 #243457 by tripwire
I did the following but it didn't change the behaviour:
dave@DavesLinuxMachine:~/dev/qtpyvcp/pyqt5designer/Qt5.15.2-64bit/python3.9$ sudo ./install.sh
renaming existing libpyqt5.so to libpyqt5.so.old
copying libpyqt5.so for python 3.9 to /usr/lib/x86_64-linux-gnu/qt5/plugins/designer
Note that my vcp runs fine when launched from linuxcnc. So I must have the pyqt5 libraries.
I've attached the
/home/dave/.local/lib/python3.9/site-packages/qtpy/__init__.py file which is where an exception is thrown and this causes the API var to change from pyqt5 to pyqt6 and then pyside2.
I realize it's a lot to dig into but I'd be curious as to why that exception is thrown.
File Name: __init__.py.txt
File Size:10 KB
21 May 2022 19:36 - 21 May 2022 20:01 #243501 by TurBoss
can you try to run
python3.9 -m pip install pyqt5
thanks
Last edit: 21 May 2022 20:01 by TurBoss.
22 May 2022 02:57 #243528 by tripwire
thanks for hanging in there with me, TurBoss.
I will give your suggestion a try.
23 May 2022 20:20 #243638 by tripwire
I tried. Here is the result. I still have the same problem.
dave@DavesLinuxMachine:~$ which python3.9
/usr/bin/python3.9
dave@DavesLinuxMachine:~$ python3.9 -m pip install pyqt5
Requirement already satisfied: pyqt5 in /usr/local/lib/python3.9/dist-packages (5.15.4)
Requirement already satisfied: PyQt5-Qt5>=5.15 in /usr/local/lib/python3.9/dist-packages (from pyqt5) (5.15.2)
Requirement already satisfied: PyQt5-sip<13,>=12.8 in /usr/lib/python3/dist-packages (from pyqt5) (12.8.1)
Moderators: KCJ, Lcvette
Time to create page: 0.188 seconds
