Install 2.9 on Debian 11
- BigJohnT
- Thank you received: 994
05 May 2022 12:18 #242032
by BigJohnT
Install 2.9 on Debian 11 was created by BigJohnT
Trying to update 2.9 to continue working on the 7i96S configuration but I'm running into issues.
Gdebi install button doesn't enable and there are a ton of linitan errors.
Trying to install from the command line with dpkg -i and I get these errors:
Running sudo apt dist-upgrade failed and when I fix install linuxcnc-uspace is removed.
What a morning...
JT
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python3 (<< 3.8); however:
Version of python3 on system is 3.9.2-3.
linuxcnc-uspace depends on libboost-python1.67.0; however:
Package libboost-python1.67.0 is not installed.
linuxcnc-uspace depends on libpython3.7 (>= 3.7.0); however:
Package libpython3.7 is not installed.
linuxcnc-uspace depends on libreadline5 (>= 5.2); however:
Package libreadline5 is not installed.Running sudo apt dist-upgrade failed and when I fix install linuxcnc-uspace is removed.
What a morning...
JT
- BigJohnT
05 May 2022 12:35 #242034
by BigJohnT
Replied by BigJohnT on topic Install 2.9 on Debian 11
For fun I tried to install 2.8.1 deb and I get:
JT
Error: Dependency is not satisfiable: libboost-python1.67.0JT
- BigJohnT
05 May 2022 15:09 #242044
by BigJohnT
Running configure on a fresh pull of master I get:
JT
checking for python... none
configure: error: python not foundJT
- Thank you received: 4150
05 May 2022 21:03 #242067
Replied by rodw on topic Install 2.9 on Debian 11
John, this seems a bit odd. Can you tell us how originally installed Debian Bullseye (11) ? Did you upgrade from Buster?
It looks a bit like you have had 2.8 running on your PC somehow in the past because of the Python version
dependency becasue of:Note Bullseye was upgraded to V 11.3 in March but I have never had any issues installing linuxcnc on a new build from source either using the recipe on the QTPYVCP web site or using Joco-nz's install script in his git
Bullseye uses Python 3.9 and Bookworm uses Python 3.10 and it installs on both for me.
You should not see that error unless possibly you have checked out V2.8. Its this dependency rubbish that made me adopt Bullseye and master branch when it was first released as it eliminated Python 2.7
Version of python3 on system is 3.9.2-3.Bullseye uses Python 3.9 and Bookworm uses Python 3.10 and it installs on both for me.
- BigJohnT
06 May 2022 11:23 #242121
by BigJohnT
I must have built a deb because a deb is building now.
In the debian directory:
In the top most linuxcnc directory:
Odd I did have to satisfy a couple of dependencies for imagemagick and inkscape
JT
./configure uspaceIn the top most linuxcnc directory:
dpkg-buildpackage -b -ucOdd I did have to satisfy a couple of dependencies for imagemagick and inkscape
sudo apt install imagemagick inkscapeJT
- BigJohnT
06 May 2022 11:39 #242122
by BigJohnT
I did have to manually create the CNC menu but that's no big issue.
JT
JT
- Jalapeno56
- Thank you received: 17
06 May 2022 22:27 #242182
by Jalapeno56
Replied by Jalapeno56 on topic Install 2.9 on Debian 11
Not sure if I can help or hinder but.....I have debian 11 with Lcnc 2.9.0 running on a real time machine. Uspace would not work. I had to install -dev version to make things work properly.
forum.linuxcnc.org/plasmac/45743-thc-cannot-keep-up?start=30
Start at page 2
Start at page 2
Time to create page: 0.268 seconds
