upgrade from wheezy error on conversion
- rorrr
01 Jun 2022 20:49 #244404
by rorrr
upgrade from wheezy error on conversion was created by rorrr
Hi guys,Thanks for your help. I guess I have a problem. I installed the new os and started linuxcnc with my old config files in my home directory. It tried to run the conversion but I think that failed. Can you help please?Thanks a bunch,Robert
- Thank you received: 7478
01 Jun 2022 21:43 #244411
Replied by tommylight on topic upgrade from wheezy error on conversion
The attached report does not belong to the attached ini file, base periods are not the same.
Attach the report generated by the ini/hal file in actual use.
- rorrr
01 Jun 2022 21:52 #244412
by rorrr
Replied by rorrr on topic upgrade from wheezy error on conversion
Sorry,
Here you go...
Here you go...
01 Jun 2022 23:34 #244414
in section [JOINT_0] should beNotice the space before the dot, it is not allowed.
Just to make sure it is a conversion error, can you please copy the old config to another folder, like Downloads then try the conversion again.
Thank you.
HOME_OFFSET = -0 .200000HOME_OFFSET = -0.200000Just to make sure it is a conversion error, can you please copy the old config to another folder, like Downloads then try the conversion again.
Thank you.
- rorrr
02 Jun 2022 00:41 #244418
by rorrr
Thanks... I checked the old ini on the wheezy partition and it has the space so I assume the conversion didn't make a mistake. Here are my files as they sit now...
02 Jun 2022 08:38 #244428
Remove "(inches per second)" or put a # in front of them.
- rorrr
02 Jun 2022 15:23 #244456
by rorrr
Thanks a bunch! commenting didn't work but removing it did! I'm in. You rock!
Time to create page: 0.167 seconds
