Installing LinuxCNC 2.9 or Master on Linux Mint 21
2 years 11 months ago #284611 by alangibson
It's pretty close to working actually:
alangibson@oxcart:~/dev/plasma/linuxcnc$ sudo gdebi linuxcnc_2.9.1_amd64.deb Reading package lists... Done Building dependency tree... Done Reading state information... Done Reading state information... Done This package is uninstallable Dependency is not satisfiable: libboost-python1.74.0 (>= 1.74.0+ds1) alangibson@oxcart:~/dev/plasma/linuxcnc$ sudo apt install libboost-python1.74.0 Reading package lists... Done Building dependency tree... Done Reading state information... Done libboost-python1.74.0 is already the newest version (1.74.0-14ubuntu3). libboost-python1.74.0 set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
I need to look into how to force it to think those two version or equivalent, or just ignore the dependency.
2 years 11 months ago #284614 by alangibson
On second thought, I was being too optimistic. Lack of boost for Python 3.11 will be a problem.
alangibson@oxcart:~/dev/plasma/linuxcnc$ sudo dpkg -i ./linuxcnc_2.9.1_amd64.deb Selecting previously unselected package linuxcnc. (Reading database ... 603625 files and directories currently installed.) Preparing to unpack ./linuxcnc_2.9.1_amd64.deb ... Unpacking linuxcnc (1:2.9.1) ... dpkg: dependency problems prevent configuration of linuxcnc: linuxcnc depends on libboost-python1.74.0 (>= 1.74.0+ds1); however: Version of libboost-python1.74.0 on system is 1.74.0-14ubuntu3. linuxcnc depends on libboost-python1.74.0-py311; however: Package libboost-python1.74.0-py311 is not installed. linuxcnc depends on libpython3.11 (>= 3.11.0); however: Package libpython3.11 is not installed. linuxcnc depends on python3-opengl; however: Package python3-opengl is not installed. linuxcnc depends on libgtksourceview-3.0-dev; however: Package libgtksourceview-3.0-dev is not installed. linuxcnc depends on tclreadline; however: Package tclreadline is not installed. linuxcnc depends on python3-pyqt5.qsci; however: Package python3-pyqt5.qsci is not installed. linuxcnc depends on python3-pyqt5.qtopengl; however: Package python3-pyqt5.qtopengl is not installed. linuxcnc depends on python3-opencv; however: Package python3-opencv is not installed. linuxcnc depends on python3-espeak; however: Package python3-espeak is not installed. linuxcnc depends on python3-dbus.mainloop.pyqt5; however: Package python3-dbus.mainloop.pyqt5 is not installed. linuxcnc depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; however: Package python3-pyqt5.qtwebengine is not installed. Package python3-pyqt5.qtwebkit is not installed. linuxcnc depends on espeak-ng; however: Package espeak-ng is not installed. linuxcnc depends on espeak; however: Package espeak is not installed. linuxcnc depends on python3-poppler-qt5; however: Package python3-poppler-qt5 is not installed. dpkg: error processing package linuxcnc (--install):
2 years 11 months ago #284620 by alangibson
I settled on just running it in a Docker container for now since all I really need is halcompile for the moment
docker pull debian:bookworm docker run -it --name=linuxcnc -v $PWD:/linuxcnc debian:bookworm bash apt update apt install -y curl curl -O https://www.linuxcnc.org/dists/bookworm/2.9-uspace/binary-amd64/linuxcnc-uspace_2.9.1_amd64.deb curl -O https://www.linuxcnc.org/dists/bookworm/2.9-uspace/binary-amd64/linuxcnc-uspace-dev_2.9.1_amd64.deb curl -O https://www.linuxcnc.org/dists/bookworm/2.9-uspace/binary-amd64/linuxcnc-uspace-dbgsym_2.9.1_amd64.deb dpkg -i linuxcnc-uspace_2.9.1_amd64.deb linuxcnc-uspace-dev_2.9.1_amd64.deb linuxcnc-uspace-dbgsym_2.9.1_amd64.deb apt --fix-broken -y install
2 years 11 months ago #284663 by cmorley
I don't think you need --with-realtime.
I'm using mint 21.2 for development - I don't remember doing anything unusual.
2 years 4 months ago #304170 by Holzwurm56
Hello,
when I want to download:
ftp.de.debian.org/debian/pool/main/l/lin...4_6.0.12-1_amd64.deb
and
http.us.debian.org/debian/pool/main/l/li...bda926-1.2_amd64.deb
I get allways The message:Not FoundThe requested URL was not found on this server.
Are they now on an other place?
Hans
Time to create page: 0.282 seconds
