Installing LinuxCNC 2.9 or Master on Linux Mint 21
3 years 2 months ago #277398 by Cant do this anymore bye all
Just rebuilt Linuxcnc 2.9 on a stock Mint 21 system, no issues.
Have done this in the last 2 couple of days on both Vanessa & Vera.
The following user(s) said Thank You: rabler
3 years 1 month ago #279686 by cmorley
The trick to a deb is to compile debian on the system, it seems. you used to be able to set the python minimum directly but now it seems to pull it from the system.
2 years 11 months ago - 2 years 11 months ago #284604 by alangibson
Hello all,
I trying to compile the current LinuxCNC 2.9 branch on Linux Mint 21 with non-realtime kernel just to experiment with component development. According to the docs, the following should work. Has anyone encountered this error before?
$ ./autogen.sh $ ./configure --with-realtime=uspace --disable-gtk2 [snip] $ make Makefile:121: *** Makefile.inc must specify RTPREFIX and other variables.  Stop.
My system is currently
$ uname -a Linux oxcart 6.2.0-33-generic #33~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Sep  7 10:33:52 UTC 2 x86_64 x86_64 x86_64 GNU/Linux $ cat /etc/issue Linux Mint 21.1 Vera \n \l
Last edit: 2 years 11 months ago by alangibson.
2 years 11 months ago #284605 by Aciera
Do you actually need the option --disable-gtk2?
2 years 11 months ago #284608 by rodw
I wonder if it is possible to install the new 2.9.1 deb file on Mint from here?
www.linuxcnc.org/dists/bookworm/2.9-rt/
Might be a shortcut
2 years 11 months ago #284610 by alangibson
Same result without that flag I'm afraid
Time to create page: 0.081 seconds
