- Thank you received: 2181
root@vmc:/home/rabler# uname -v
#35-Ubuntu SMP PREEMPT_RT Tue Jan 24 11:45:03 UTC 2023
root@vmc:/home/rabler# apt install linuxcnc-uspace
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc-uspace : Depends: python3 (>= 3.11~) but 3.10.6-1~22.04 is to be installed
Depends: libboost-python1.74.0 (>= 1.74.0+ds1) but it is not going to be installed
Depends: libboost-python1.74.0-py311 but it is not installable
Depends: libpython3.11 (>= 3.11.0) but 3.11.0~rc1-1~22.04 is to be installed
Recommends: hostmot2-firmware-all but it is not installable
Recommends: linux-image-rt-amd64 but it is not installable
Recommends: python3-pil.imagetk but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Start here for a Debian 12.1 config and select mate instead of xfce if you must:Not bothering with this anymore since LinuxCNC is officially in the Debian repos and Debian has a Mate edition, so it is the same thing, granted Mint is still somehow much faster at booting.
Get the Debian 12 BookWorm Mate edition ISO, i am pretty sure you can install Mint-Y-blue or whatever Mint theme you want, so it even looks and feels the same.
cdimage.debian.org/debian-cd/current-liv...2.1.0-amd64-mate.iso
You can't seem to specify the python minimum version anymore on the build system.I have to admit that I struggled a bit to wade through this nearly year-long thread, apologies if I missed something.
Has anyone figured a way around the python3.11 issue for Mint (which I'm using elsewhere too) and LinuxCNC 2.9? Is building from 2.10 an option on mint? Or do I need to use Debian?
2.8.4 is not an option, at least not without some real contortions, due to missing kernel modules to support a more recent AMD GPU.root@vmc:/home/rabler# uname -v
