- Thank you received: 8
Installing LinuxCNC on Debian 9 - 13
- daiman444
3 years 11 months ago #256222
by daiman444
Replied by daiman444 on topic Installing LinuxCNC on Debian 9 - 13
Hi. in this particular case, I followed your instructions to install lcnc 2.9 on debian 11. as it was suggested above that the development branch has changed, then I get cloned not what I need. tomorrow I will try to clone with an explicit indication of the branch 2.9.
3 years 11 months ago #256224
Replied by andypugh on topic Installing LinuxCNC on Debian 9 - 13
No need to re-clone, you can just
Or not bother. At the moment 2.9 and 2.10 are identical.
git checkout 2.9
- JT
- Thank you received: 598
3 years 11 months ago #256226
by JT
JT
Replied by JT on topic Installing LinuxCNC on Debian 9 - 13
Ok, that page needs fixing and I'll sort that out shortly.Hi. in this particular case, I followed your instructions to install lcnc 2.9 on debian 11. as it was suggested above that the development branch has changed, then I get cloned not what I need. tomorrow I will try to clone with an explicit indication of the branch 2.9.
JT
The following user(s) said Thank You: seuchato, daiman444
- Thank you received: 4153
3 years 11 months ago - 3 years 11 months ago #256235
So this is the very original Gigabyte N3160 PC I first installed linuxcnc on years ago. It was running Debian Bullseye 5.10 as an office PC for a long time so its had a few upgrades since while struggling with error finishing read which was an issue on it.
I did a full upgrade to Bookworm last night which gave me the 6.0 kernel and lost the network connection. The NIC was not there. I installed linux-headers and that seemed to rebuild the r8168-dkms driver before I did.
INstalled linuxcnc from the bookworm repo. Error finishing read is gone. Latency was around 130k until I added Isolcpus=2,3 Ping times to the 7i76e took quite a hit but Latency is amazing. It was around 0.100 ms before
Time will tell if I need to remove the isolcpus but at this stage everything appears normal.
PS: Also built a RIP install last night which was working too.
Replied by rodw on topic Installing LinuxCNC on Debian 9 - 13
I just did! And it works!After doing an update on debian 12 and 13 I see linux-image-6.00-2-rt-amd64 in synaptic, has anyone tried 6.0? with a Mesa ethernet card?
JT
packing@packing:~$ halcmd show param hm2_*.tmax*
Parameters:
Owner Type Dir Value Name
36 s32 RW 0 hm2_7i76e.0.read-request.tmax
36 bit RO FALSE hm2_7i76e.0.read-request.tmax-increased
36 s32 RW 555360 hm2_7i76e.0.read.tmax
36 bit RO FALSE hm2_7i76e.0.read.tmax-increased
36 s32 RW 76240 hm2_7i76e.0.write.tmax
36 bit RO FALSE hm2_7i76e.0.write.tmax-increased
packing@packing:~$ uname -v
#1 SMP PREEMPT_RT Debian 6.0.5-1 (2022-10-28)
packing@packing:~$
Last edit: 3 years 11 months ago by rodw.
3 years 11 months ago #256237
One of the things with isolcpus is the nic interrupt is probably being serviced by the same core as the servo thread which probably accounts for the slower ping times. You can see what cores are used if you type
cat /proc/interrupts
explore the output on the right hand side and you will see the NIC port listed
This old article, I think is useful but I don't think all interrupts go to the one core anymore
www.alexonlinux.com/smp-affinity-and-pro...pt-handling-in-linux
Also this one too:
blog.dan.drown.org/nic-interrupt-coalesce-impact-on-ntp/
BUt it is not supported on my PC
Also this one too:
- drdoc
- Thank you received: 3
3 years 11 months ago #257943
by drdoc
Replied by drdoc on topic Installing LinuxCNC on Debian 9 - 13
With this in mind, is there any benefit to building from source? I'm running bookworm on a pretty healthy 4th-generation i5 system, and will be using a 7i96 board.
Time to create page: 0.841 seconds
