Installing LinuxCNC on Debian 9 - 13
3 years 11 months ago #257965 by tommylight
Replied by tommylight on topic Installing LinuxCNC on Debian 9 - 13
Not that i am aware of.
3 years 6 months ago #268491 by ChironFZ16
Replied by ChironFZ16 on topic Installing LinuxCNC on Debian 9 - 13
Bookworm have change the nonfree Software :https://www.debian.org/releases/bookworm/amd64/release-notes/ch-information.html#non-free-split
3 years 6 months ago #268763 by Gubby
Replied by Gubby on topic Installing LinuxCNC on Debian 9 - 13
Do you know if the uspace of 2.9 and 2.10 versions work with Ethernet cards like EC500
3 years 6 months ago #268771 by rodw
Replied by rodw on topic Installing LinuxCNC on Debian 9 - 13
Yes, the linuxcnc-uspace-dev in the bookworm repositories works with ethercat if you follow my sticky in the ethercat sction.
Support for individual ethernet cards is a matter for the developers of iGh etherlabmaster. I have not had any issues with the cards I have used including onĀ  ARM CPU's such as Pi4B and Odroid N2+
3 years 6 months ago #269239 by CtodLinuxcnc
Replied by CtodLinuxcnc on topic Installing LinuxCNC on Debian 9 - 13
I had linuc cnc running on deb 11.6 but latency was awful. Could you link more info on the isolcpus? Think that would fix my latency?
Im about to five up and just run it on a pi
3 years 6 months ago #269242 by rodw
sudo apt install grub-customizer
sudo grub-customizer
second tab it will have a field that says quiet.
change that to:
2 core PC: quiet isolcpus=1
4 core PC: quiet isolcpus=2,3
Save, exit, reboot
Note if you have an older 2 core machine its well and truly past its useby so you may need to upgrade.
The following user(s) said Thank You: CtodLinuxcnc
Time to create page: 2.288 seconds
