Mesa 7i96S
- Thank you received: 7478
28 Apr 2023 10:10 #270105
Replied by tommylight on topic Mesa 7i96S
Choose the card from the menu, do not use discovery.
Create the config, save, then start that config.
Post the Debug info, if it fails to load.
The following user(s) said Thank You: Vector, behai
28 Apr 2023 11:49 #270111
Replied by andypugh on topic Mesa 7i96S
pncconf does call mesaflash so if you don;t have mesaflash that might explain why discovery is not working.
Does "sudo apt-get install mesaflash" work?
Did you manage to create a config in Debian 12? If you did, then that same config should work in 11.
- Vector
- Thank you received: 27
28 Apr 2023 21:25 - 28 Apr 2023 22:11 #270135
by Vector
Replied by Vector on topic Mesa 7i96S
Thank you, tommylight and andypugh!
Your combined responses gave me the confidence to power on everything and actually try it even though the "driver" selected in the dropdown during pncconf was 7i96 not 7i96s.
Wonderful now: I have servo motor motion, so that's a big step forward.
Follow up question, during the wizard, on the Mesa Card 0 page, the TB1/TB2 tab, I am trying to use what should be the second Num 0... ie, below Num 4: Unused StepGen, for the PWM spindle. But it doesn't seem to provide a PWM option. Then when it writes the .hal file, the loadrt hm2_eth config parameter has "...num_encoders=1, num_pwmgens=0..." which is internally consistent but not what I need.
(for clarity regarding placement on the hardware, I'm talking about the "top" of the board, ie if you hold the board so that the words printed on it are right side up, this is the topmost 4-wire socket in the TB2 column, where the pins are marked NC, Spin-, Spinout, and Spin+. I'm wired to Spin- and Spin+)
I can manually change the .hal file to try and work it out, but it does make me worry that I've somehow got a wrong driver on the linuxcnc side (my understanding is that board already has it's firmware, according to documentation and the fact that servos are working.)
Any thoughts or insights?
Would compiling mesaflash and querying the board change the options on the tab?
(my repos do not allow me to sudo apt install mesaflash... package not found)
Last edit: 28 Apr 2023 22:11 by Vector.
- Thank you received: 5326
28 Apr 2023 23:20 #270143
Replied by PCW on topic Mesa 7i96S
You should not need to use mesaflash if you are using the
analog spindle output as this is supported with the stock firmware
What version of LinuxCNC are you running? pnnconf should support
the 7I96S
the 7I96S
- Vector
29 Apr 2023 00:16 #270151
by Vector
The dpkg version is linuxcnc-uspace version: 1:2.9.0~pre arm64
ie the splash screen says 2.9.0~pre0
Are you saying use the analog spindle output like it's a potentiometer attached to the spindle power supply?
I know the spindle power supply came with that as a possible configuration for manual speed control.
I had the concept (probably left over from trying to go straight through gpio pins) that the 7i96s was going to generate PWM and feed that through the power supply like its an amplifier.
But if I get what you are saying, the board just becomes like the potentiometer dial that came with the spindle control, except that it's controllable through LinuxCNC, right?
(Thanks)
(Thanks)
29 Apr 2023 00:19 #270152
Yes, the 7I96S has a potentiometer replacement type analog output
(Typically powered by 10V)
- Vector
29 Apr 2023 08:36 #270173
by Vector
That's spinning it... can you help me in the next baby step... why is it leaking .25 v? That's enough to make it spin at a lazy 150 rpm. I can hold it still with my hand at that slow speed.
29 Apr 2023 15:01 #270210
The The 7I96S minimum analog output voltage should be less than 50 mV
with PWM at 0%. Is it possible you have an offset in the hal settings or there is back current from the drive?
You can check the actual PWM value by reading hm2_7i96s.0.pwmgen.00.value
with halshow
You could check for any back current by testing with spinout disconnected from the drive
with halshow
- Vector
30 Apr 2023 08:40 - 30 Apr 2023 09:52 #270296
by Vector
Wow! You are sooo right.
By saying "back current" from the drive, I presume you were anticipating that there's a voltage potential on the "signal" input terminals to the power supply that drives the spindle motor.
Meanwhile, the "signal" cable from the mesa card is rock-solid at 0.000volts.
That back current must be somewhat common? (Or more common with cheaper drives, which is what I surely bought by buying a spindle kit for about $100.)
Any quick advice for best fix? You mentioned an offset in the hal settings... can this be set to be the negative that cancels out the the small voltage? Or is it a hardware fix? (I see three adjustable pots inside the grille, behind the giant yellow sticker that says "high voltage, no user serviceable parts inside) Or do I need to buy a better power driver?
The relevant parts of the .ini and .hal file that pncconf generated:
(when I tested the spindle with 5v and 10v inputs, the RPM was 6700 and 13500 respectively) The wizard then calculated that encoder scale number = 4.
I tried to do the open loop test, but I didn't know how to make it work, so I skipped it.
.ini file:
.hal file:
Thanks again!
.ini file:
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 6700.0
ENCODER_SCALE = 4.0.hal file:
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=0xxxxx"
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt scale names=scale.spindle
loadrt near
addf pid.s.do-pid-calcs servo-thread
addf scale.spindle servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf near.0 servo-thread
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
setp [HMOT](CARD0).encoder.00.counter-mode 0
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
setp [HMOT](CARD0).encoder.00.scale [SPINDLE_0]ENCODER_SCALE
net spindle-revs <= [HMOT](CARD0).encoder.00.position
net spindle-vel-fb-rps <= [HMOT](CARD0).encoder.00.velocity
net spindle-vel-fb-rpm <= [HMOT](CARD0).encoder.00.velocity-rpm
net spindle-index-enable <=> [HMOT](CARD0).encoder.00.index-enable
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
net spindle-vel-cmd-rps => near.0.in1
net spindle-vel-fb-rps => near.0.in2
net spindle-at-speed <= near.0.out
setp near.0.scale 1.000000
setp near.0.difference 3.333333
# Use ACTUAL spindle velocity from spindle encoder
# spindle-velocity bounces around so we filter it with lowpass
# spindle-velocity is signed so we use absolute component to remove sign
# ACTUAL velocity is in RPS not RPM so we scale it.
setp scale.spindle.gain 60
setp lowpass.spindle.gain 1.000000
net spindle-vel-fb-rps => scale.spindle.in
net spindle-fb-rpm scale.spindle.out => abs.spindle.in
net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in
net spindle-fb-rpm-abs-filtered lowpass.spindle.out Thanks again!
Last edit: 30 Apr 2023 09:52 by Vector. Reason: Add ini and hal files
30 Apr 2023 20:03 #270334
Its not common (offset current) It just explains the behavior
I would probably just disable the spindle below some minimum speed
It sounds like a fairly high speed spindle so probably not useful below
some minimum RPM anyway
Time to create page: 0.195 seconds
