How to Install LinuxCNC?
- xenon-alien
- Thank you received: 4
13 Nov 2022 13:05 - 13 Nov 2022 13:18 #256570
by xenon-alien
How to Install LinuxCNC? was created by xenon-alien
Hello!
Can you tell me how to install the 2.9 version of LCNC?
Because now the master is 2.10
forum.linuxcnc.org/29-forum-announcement...s-now-linuxcnc-v2-10
What is new in 2.10?
Last edit: 13 Nov 2022 13:18 by xenon-alien.
- Online
- Thank you received: 7490
13 Nov 2022 17:16 #256584
Replied by tommylight on topic How to Install LinuxCNC?
2.9 and 2.10 are still pretty much the same, 2.9 is separated to be stabilized for release while 2.10 will continue development.
13 Nov 2022 17:43 #256585
Replied by andypugh on topic How to Install LinuxCNC?
At the moment there are almost no differences between 2.9 and 2.10, but 2.9 is meant to be stabilising (bug fixes mainly) prior to release and 2.10 is open for more risky changes.
The buildbot is not currently making 2.9 .deb packages. I don't really know why, but I have just pushed some changes that might fix that.
- xenon-alien
13 Nov 2022 19:32 #256598
by xenon-alien
Replied by xenon-alien on topic How to Install LinuxCNC?
What do I need to do, to install 2.9?
Or just use the 2.10?
Where can I post the bugs for 2.9?
We using it for lathe with MESA 7i96s + a turret (tools have offsets). When we run the program receive a message for limit reach for axis, but there is enough space - version 7770, or something like that. May be it was fixed. If needed, tomorrow I can post my configuration and the *.ngc file
- JT
- Thank you received: 595
15 Nov 2022 12:14 #256767
by JT
Replied by JT on topic How to Install LinuxCNC?
The following user(s) said Thank You: xenon-alien, Patrice
- xenon-alien
15 Nov 2022 20:05 #256799
by xenon-alien
I'm not a "super-user" in Linux OS.
For me is the easiest to add a repository and install it. (figured it out, how to use that way with the synaptic)
I do it with the stable LinuxCNC 2.8.4 ISO image still the main was the 2.9 in master, but now it's the 2.10.
Thanks for the tip!A complete install guide for many different versions
gnipsel.com/linuxcnc/index.html
JT
- xenon-alien
21 Nov 2022 20:49 - 21 Nov 2022 20:59 #257257
by xenon-alien
Any news to install 2.9 (update 2.8.4 Buster Debian 10 to 2.9) with synaptic repositories?
Last edit: 21 Nov 2022 20:59 by xenon-alien.
22 Nov 2022 23:26 #257399
Yes, there are now 2.9 debs (only for buster) on the buildbot.
Either grab them manually from buildbot.linuxcnc.org/dists or guess the new repository description (almost certainly
deb buildbot.linuxcnc.org/ buster 2.9-rtpreempt
- xenon-alien
23 Nov 2022 18:14 #257496
by xenon-alien
I see it. Synaptic shows 2.9.0~pre1.24.............
All changes are available? (bug fixes) The last I have downloaded was a 7770 (were issues) and a 8*** somethig (was better).
What is the version? Like a 2.9.1 (stable will it be in the future)?
On this week I will try to update the lathe from 7770. I hope it will better.
OkYes, there are now 2.9 debs (only for buster) on the buildbot.
23 Nov 2022 23:48 #257529
The digits at the end are the git hash of the most recent commit to that branch. It is possible to work out exactly when in the development process the deb was built, but it is not obvious by inspection.
2.9.0.... is the latest release candidate, it contains all accepted bug fixes but will not include any new features from after about 3 weeks ago.
