A follow-up to my earlier post about the N5105-based mini-PC.
After doing a more thorough latency test, I got some very high numbers (not far short of 1 mS jitter). I didn't see how the NIC could cause the symptoms (disabling the interface doesn't make any difference), but I ended up with a messed up system (somehow I "upgraded" from gcc-12 to gcc-10, which prevented the r8168-dkms package installing), so I decided to do a clean build closely following Rod's instructions to see if fixing the NIC driver helped latency.
First surprise was that I could not install the recommended weekly build ISO. grub would not get past the grub prompt and the grub shell didn't even see the root partition. I couldn't fix it, so I tried the debian-bookworm-DI-alpha1-amd64-netinst iso, and that worked. This release (6.1.0-3) includes support for the UHD graphics, but the RTL8821ce WiFi driver needed to be built from source again. Using Synaptic, I installed linux-headers-6.1.0-3-rt-amd64 and linux-image-6.1.0-3-rt-amd64 from the bookworm repository, along with r8168-dkms, linux-uspace, linux-uspace-dev and mesaflash (2.9.0~pre1+git20230208.f1270d6ed7).
I did a quick test with Axis and a 7i96s on the bench. It seemed to work Ok the first time, but when restarting Axis I got the "read finish" error (servo period 1mS). Restarting the PC was needed to avoid the error after exiting Axis. This aside, it seemed to work, and I got the following results:
sudo chrt 99 ping -i.001 -q 10.10.10.10
--- 10.10.10.10 ping statistics ---
9269 packets transmitted, 9269 received, 0% packet loss, time 9281ms
rtt min/avg/max/mdev = 0.054/0.186/1.632/0.164 ms
I don't know what the root cause of the "read finish" error is, but it sounds to me that the inability to clear it is a driver bug. I did find that increasing the servo period to 2mS in pncconf eliminated the "read finish" error, even after restarting Axis.
Out of interest, I installed a TP-link UE300, a $10 USB ethernet dongle using the RTL8153. This gave me the following results:
sudo chrt 99 ping -i .001 -q 10.10.10.10
11455 packets transmitted, 11455 received, 0% packet loss, time 11454ms
rtt min/avg/max/mdev = 0.271/0.349/0.876/0.031 ms
The min and average RTTs are higher than for the RTL8168, which I suppose is due to the USB, but the max is much lower, perhaps suggesting the RTL8168 driver needs some work? Maybe I don't have it installed correctly, or maybe even have a hardware issue; I'd be interested to see what numbers other people get.
As another comparison, my previous system using Debian 4.19.0-23 and LinuxCNC 2.6.1 and a very old AMD 79C970 NIC gives the following:
rtt min/avg/max/mdev = 0.245/0.275/0.497/0.019 ms
My surmise is that built-in RTL8168H ethernet will probably work as well as the USB dongle or the older NIC, if the "read finish" error can be avoided by increasing the servo period. I plan on substituting the mini PC for the current PC on my mill, so we'll see if that's so.
