Installing LinuxCNC Beelink U59 Pro
3 years 8 months ago #265418 by vitorfranx
Replied by vitorfranx on topic Installing LinuxCNC Beelink U59 Pro
I made the xorg.conf in /etc/X11/xorg.conf
I put this in the xorg:
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
HorizSync 31-64
VertRefresh 50-120
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1920x1080" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
But it didn't do anything do I have to run it somehow? I already restarted the PC.
3 years 8 months ago #265421 by andypugh
Replied by andypugh on topic Installing LinuxCNC Beelink U59 Pro
Is the path to the file
/etc/X11/xorg.conf
or
/etc/X11/xorg.conf.d/xorg.conf ?
Both of those should work.
From your description there seems to be a small chance that you created
/etc/X11/xorg.conf/xorg.conf
But I suspect that is just the way you phrased it?
Also, this might all be completely out of date if you are using Wayland...
3 years 8 months ago #265430 by vitorfranx
I meant that the file path was /etc/X11/xorg.conf so to edit it I just used:
cd /etc/X11/
sudo geany xorg.config
Then edited the file and saved it.
I don't have more free time this week, I'll try again next saturday.
3 years 8 months ago #265458 by andypugh
Typo?
3 years 7 months ago #265900 by vitorfranx
Hi guys,
Massive progress yesterday.
I did a clean install of linux Bookworm. It had a lot of drivers missing and the sources.list file had the text badly written so I couldn't even install the packages I wanted.
Then I had to erase all the text and copy/paste the links from the debian wiki about sources.list files.
After that I used synapsis (I don't remember exactly how the software is called) and installed all the packages that contained all my missing drivers.
I also installed Linux CNC and followed the Ethercat guide to be able to control some drivers/inverters I have access to.
It's all working fine, I did a latecy test and showed: about 400.000 ns jitter in servo thread and 450.000 ns jitter in base thread.
From what I read in the forum this is really not great but it will allow me to test and verify the system.
3 years 7 months ago #265904 by rodw
Replied by rodw on topic Installing LinuxCNC Beelink U59 Pro
400000 is not viable. But you say you had issues with sources.list. Bookworm has never had sources.list errors for me.
That makes me think you are getting something wrong.
But you are up and running, try settting isolcpus=2,3 using grub-customizer which is in the bookworm repos.
Then check that cstates =1 is set in your bios. (You can also do in grub but  would need to research the values.)
 The Celeron 5105 should have enough grunr to run linuxcnc if set up right.
If that still fails to get latency < 150000, disable/remove/uninstall your wifi card/driver.
Time to create page: 1.036 seconds
