RPi4 Mesa install: No 7C81 board found
- sameedansar
11 Sep 2024 18:04 - 11 Sep 2024 18:11 #309927
by sameedansar
Replied by sameedansar on topic RPi4 Mesa install: No 7C81 board found
Thanks. I will try using another cable. Is there any other way to connect the Mesa 7C81 with the Raspberry Pi 4? I have heard that you can connect the Mesa 7C81 using PNCoff, but I don’t understand how. If possible, could you explain it to me?
Last edit: 11 Sep 2024 18:11 by sameedansar.
- Thank you received: 5308
11 Sep 2024 21:02 #309942
Replied by PCW on topic RPi4 Mesa install: No 7C81 board found
You can make a configuration with pncconf
(select 7c81-internal data, 5ABOBx3 firmware
and run LinuxCNC with the created configuration file set)
(This may need the master version of LinuxCNC, not sure if
7C81 support is in 2.9.3)
- sameedansar
12 Sep 2024 17:10 #310015
by sameedansar
I tried with longer jumper wires but got the same error. I have the 2.8.1 version of linuxcnc so I will try what you suggested. Thanks for the speedy responses
Time to create page: 0.519 seconds
