Installing Linuxcnc on Debian Bookworm
3 years 1 month ago #280983 by rodw
Hi Tom, i am Tom ! :)
That version is for Ethecat, not for ethernet, Mesa needs ethernet, although it should work properly.
Tommy, that is totally wrong advice. My installer includes some preinstalled repositories for ethercat and qtpyvcp. Its up to the user if he wants to install those pieces or not. If he doesn't install them, its a standard linuxcnc install based on Debian and forked from the linuxcnc installer on github. github.com/LinuxCNC/linuxcnc-live-build .
If you are going to give alternative installation options, please stick to the method in the docs as it includes everything and it uses the correct installer which is available from the debian.org home page.
linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.html
3 years 1 month ago #280994 by aussietom
Hello Rod!
Thank you for all your help in these forums and development! :)
So i think i have done mostly everything right so far.. i am up to the point on trying to install a better?later kernel 6.3, as you and other have said it improves latency by more than 200%. explained in this link linuxcnc.org/docs/2.9/html/getting-start...lling_a_later_kernel
what am i doing wrong here? still says ive got 6.1 kernel?
also, do you do contract work with this sort of help you can provide?
Thank you,
-Tom
3 years 1 month ago #280998 by rodw
If you look at the grub boot menu, there is probably an option to select the 6.3 kernel.
You can lock in the kernel you want to boot with grub-customizer which will also show them all.
If you really get stuck, you can contact me via this form. I am in Brisbane
www.vmn.com.au/contact
3 years 1 month ago #281020 by tommylight
OMG that sounds so much easier than what i have been doing. I'll try that tomorrow as i've been awake all night and have many things to do today LOL
@Rod
Simple, several times i insisted on doing a simple how to, i waited enough and i can not continue to feel bad for new members watching them going through all this and that.
Simple.
The following user(s) said Thank You: rubes
3 years 1 month ago #281045 by rodw
Can't get much simpler than this:
Unless you use my installer
3 years 1 month ago #281046 by rodw
The best place to start with a copy of Debian 12 is to go to
www.debian.org/
and click on the download button. This gives you the same version as I recommend in the docs. We don't want links in forums to obscure installation.
Time to create page: 0.246 seconds
