Installing Linuxcnc on Debian Bookworm
3 years 1 month ago #280685 by nwallace
@rodw
Noticed that the download of the 6.3 rt kernel is no longer working from google drive. No matter what day, ip, device, browser or OS I try from I just get a timeout error when downloading the linux-image file. Luckily I had the file already on another device. I noticed this about a week ago and just tried again with the same errors.
3 years 1 month ago #280720 by rodw
I have not changed it. Try this  drive.google.com/drive/folders/1NzQIHnf9...chOOxaER?usp=sharing
Also there is the ISO image in the stickies in this section...
3 years 1 month ago #280761 by nwallace
I could use the image but I figured you should know about any issues since this is linked in the official documentation of how to install LinuxCNC. Attached is what I get when I try to download that file from 2 different machines in Chrome and Firefox as well as from 3 different public IP's.
3 years 1 month ago - 3 years 1 month ago #280779 by rodw
I suspect there are other factors at play with your connection to Google Drive.
IN the same folder, another document lists the commands to build it from scratch.
The 6.4 commands are untested.
apt update sudo apt install -y build-essential bin86 libncurses5-dev pkg-config libssl-dev dwarves bison flex gnupg libelf-dev libssl-dev wget qtbase5-dev debhelper rsync git mkdir rtlinux cd rtlinux git clone -b v6.3 --depth 1 https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git linux-6.3 wget https://mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/6.3/patch-6.3-rt11.patch.gz tar xvf linux-6.3.tar.xz gunzip patch-6.3-rt11.patch.gz cp patch-6.3-rt11.patch linux-6.3 cd linux-6.3 cat patch-6.3-rt11.patch | patch -p1 git add * make xconfig #Set the following: General Settings/Preemption model = Fully Preemptible Kernel #Save then exit (Click on General settings and select option on the right side. # These keys override security and key settings to allow .debs to be built scripts/config --disable SYSTEM_REVOCATION_KEYS scripts/config --disable DEBUG_INFO scripts/config --enable DEBUG_INFO_NONE scripts/config --set-str SYSTEM_TRUSTED_KEYS "" make -j4 deb-pkg LOCALVERSION=-linuxcnc
Last edit: 3 years 1 month ago by rodw.
3 years 1 month ago #280805 by Cant do this anymore bye all
Headers & doc download ok, Kernel is a no go.
3 years 1 month ago #280826 by rodw
It downloads for me but there is quite a pause while Google virus checks it then it displays a warning that it could be dangerous.
We are talking Google drive here and all files in the folder have the same permissions so take it up with them. A lot of people have downloaded it and it has not changed for months... Its possible you may have some security settings at your end preventing the download.
Time to create page: 0.170 seconds
