rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
- BHar
2 years 6 months ago #298211
by BHar
Replied by BHar on topic rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
Cheers - I just got a blank screen this morning on VNC connection and realised that it doesn't work pre-login - so was coming back to mention it here and found your update.
"autologin-user=cnc" works perfect - thanks again.
Not sure if you have noticed a similar issue, but I need to wait about 30 seconds after boot before I see a port listening on 5900 with $netstat -pat , and am able to connect? I suppose its not a big issue.
I have set the service to startup as follows:
[Unit]
Description=Start x11vnc at startup.
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/x11vnc -auth guess -forever -loop -noxdamage -repeat -rfbauth /etc/x11vnc.pwd -rfbport 5900 -shared -o /var/log/x11vnc.log -localhost
[Install]
WantedBy=multi-user.target
[Unit]
[Service]
Type=simple
[Install]
- rdtsc
- Thank you received: 14
2 years 6 months ago #298430
by rdtsc
I think this stems from `After=multi-user.target`. multi-user.target is systemd's way of targeting the point in the boot process where a console login would have been presented. Technically this is still too early, as X isn't even loaded yet. But by the time the service runs, X is mostly started, and it should patiently wait for screen :0.0 to be created then connect to it immediately.
Here's what I'm currently using, and it seems to activate right alongside the GUI.
x11vnc -xkb # with -noxkb, shift and alt did not work in vnc
-noxrecord # intentionally disabled
-xfixes # supposedly includes some fixes
-xdamage # supposed to reduce network bandwidth, unconfirmed
-display :0 # on multi-display systems, this may need to be :0.1 or :1.0
-auth guess # not exactly sure what this does
-rfbauth /home/cnc/.vnc/passwd # this specifies where the vnc passwd file is
-geometry 1024x768 # setting the geometry here will force the vnc window to this size (regardless of aspect ratio)
Restart=always # on-failure will work, but may not restart if client purposely closes vnc (untested)
RestartSec=5 # restart slowly
OOMPolicy=kill # if out of memory, kill this service
Will have to `sudo systemctl daemon-reload` then `sudo systemctl restart x11vnc` or reboot to see the changes.
Replied by rdtsc on topic rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
[Unit]
Description="x11vnc server"
Requires=display-manager.service
After=display-manager.service
[Service]
ExecStart=/usr/bin/x11vnc -xkb -noxrecord -xfixes -xdamage -display :0 -auth guess -rfbauth /home/cnc/.vnc/passwd -geometry 1024x768
ExecStop=/usr/bin/killall x11vnc
Restart=always
RestartSec=5
OOMPolicy=kill
[Install]
- rdtsc
2 years 6 months ago - 2 years 3 months ago #299146
by rdtsc
After using the above for awhile, these two things may be helpful:
1. Add "-repeat" to the x11vnc server line if using the TigerVNC client. That client doesn't understand x11vnc's key repeat sequence. Adding "-repeat" causes key repeating to work as expected with this client. Re: github.com/TigerVNC/tigervnc/issues/66
2. If x11vnc is taking 1:30 to shut down when powering off or rebooting the pi (x11vnc not closing properly), "sudo mkdir /etc/systemd/system.conf.d && sudo cp /etc/systemd/system.conf /etc/systemd/system.conf.d/ && sudo nano /etc/systemd/system.conf.d/system.conf" and add "DefaultTimeoutStopSec=15s" to it. Re: www.reddit.com/r/kde/comments/rpwcm4/sdd...tem_for_130_minutes/
EDIT:
3. Every once-in-awhile I'll get a black (blank) desktop. Unsure what causes it, but seems to be related to the lighdm display manager. Have found two ways of getting around that: a) Do a CTRL-ALT-F2 and login, then issue a "systemctl restart lightdm". b) SSH into it and do the previous or "sudo reboot now". Issues with LightDM hanging are sporadic for many people and computers, so it's likely nothing special about the Rpi or Debian 12.
EDIT:
Last edit: 2 years 3 months ago by rdtsc. Reason: Edited blank screen info.
Time to create page: 0.153 seconds
