- Thank you received: 4153
rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
2 years 6 months ago #297966
Replied by rodw on topic rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
I'm not sure if it is compatible with our image. Some boot files are in subfoldersDid you try
Code:sudo apt-get install raspi-config ?
- rdtsc
- Thank you received: 14
2 years 6 months ago #297981
by rdtsc
Replied by rdtsc on topic rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
Tried to satisfy the grisly requirement of old Bullseye build `python << 3.8` to update 2.9.0; gave up, moved back to new Bookworm build.
On current Bookworm, `config.txt` was in /boot/broadcom, enabled `dtparam=spi=on` and that seems to work, thank you. Was then able to complete upgrading `linuxcnc-uspace (1:2.9.2) over (1:2.9.1)` successfully.
Any chance we can try to get VNC working on it? Not for everyday use; just for setup and configuration. It would be much easier to work on the config from a workstation rather than the touchscreen. www.waveshare.com/product/raspberry-pi/d...5.6inch-hdmi-lcd.htm
- Thank you received: 426
2 years 6 months ago #297982
Replied by Cant do this anymore bye all on topic rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
I was playing around a month or so ago with a remote desktop login, once I read the docs I found out I couldn't do a remote login whilst logged at the physical console.
Can't for the life on me what remote server it was.
2 years 6 months ago #297987
It was a long time ago but I did have XRDP running and was able to open the Pi in Windows RDP.
I tried briefly again with no luck recently but did not stick with it.
There will most likely be some missing premissions
- BHar
2 years 6 months ago #298150
by BHar
Replied by BHar on topic rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731.img - TigerVNC?
Facing the same issue as yourself, looking for VNC connection to this "rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-11-17-1731" image, and failing.
I ended up installing X11VNC.
$sudo apt-get install x11vnc
$x11vnc
I Don't know much about it, seems to be a VNC server that connects only to active screen session rather than opening a new session.
Works with Tiger and Real VNC Clients. Regardless of the fact its sharing the main session, I stopped here as this was fine for my use and after seeing the amount of time you spent trying to do it properly I have called it quits here.
$x11vnc
- rdtsc
2 years 6 months ago #298155
by rdtsc
Nice BHar, thanks for sharing. Gave that a shot; sure enough it works! Awesome.
Wanted to mention that I got autologin working by editing /etc/lightdm/lightdm.conf and changing `#autologin-user=` to `autologin-user=cnc`. There's also some settings in there for VNC but they seemed irrelevant (for tigervncserver anyways.)
Time to create page: 0.243 seconds
