Linuxcnc will not connect to MESA 7i76e IP Address
25 May 2024 22:10 #301445 by RMJ fabrication
Hey everyone! This is my first post and first time installing and configuring Linuxcnc with a Plasma Table that has four Clearpath servo motors and a MESA 7i76e and THCAD-10. I have reinstalled multiple different versions of Linuxcnc trying to solve my problems. So far the 2.7 stretch version of Linuxcnc connects to the 7i76e just fine and I am able to jog the motors but this version missing the slave axis functions I need for my machine's gantry with two motors. Every single later version of Linuxcnc 2.8 and 2.9 give me network configuration problems but has the slave axis(tandem axis) functions my machine needs. I decided to go with the newest version of Linuxcnc 2.9.2 I went through the pncconf and made a base configuration with IP address 192.168.1.121 now when I open the configuration I get stuck on getting Linuxcnc to start due to this error:
Print file information: RUN_IN_PLACE=nO
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/ust/bin
LINUXCNC_TCL_DIR=/ust/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/ust/lib/linuxcnc/modules
LINUXCNC CONFIG DIR=
LINUXCNC_LANG_DIR=/usI/lib/tcltk/linuxcnc/msgs
INIVAR=inivar
HAL CMD=halcmd
LINUXCNC_EMCSH=/ust/bin/wish8.6
LINUXCNC - 2.9.2
Machine configuration directory is '/home/rolando/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is "my_LinuxCNG_machine ini"
INIFILE=/home/rolando/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY-gmoccapy
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ kinstype=B0TH
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvi
Found file(REL): -/my_LinuxCNC_machine.hal
Running HAL shutdown script
identityKinematicsSetup: coordinates:XYYZ
Joint 0 ==> Axis X
Jount 1==> AKIS Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
hm2: loading Mesa HostMot2 driver version a.15
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 192.168.1.121: Connection refused
hm2: unloading
Debug file information:
Note: Using POSIX realtime hm2_eth: Itapi_app_main: Connection refused (-111)
/my_LinuxCNC_machine.hal:9: waitpid failed /ust/bin/tapi_app hm2_eth
_/my_LinuxCNC_machine.hal:9: /ust/bin/rtapi_app exited without becoming ready
-/my_LinuxCNC_machine.hal:9: insmod for hm2_eth failed, returned -1
1718
Stopping realtime threads
Unloading hal components
25 May 2024 22:26 #301448 by tommylight
I would guess the Mesa is wired to a network switch and there is something else there with the same IP address, as i have never ever seen a "connection refused" from a Mesa board.
So how is the Mesa wired to the PC? It should be directly wired, not switch or hub or router.
What is the jumper settings on Mesa regarding the IP address?
Did you check the manual?
25 May 2024 22:45 #301449 by RMJ fabrication
Replied by RMJ fabrication on topic Linuxcnc will not connect to MESA 7i76e IP Address
I am not using a network switch and the jumpers are at default position. This is how I have the board connected in the attached.
  • Platinum Member
  • Platinum Member
25 May 2024 23:02 #301450 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Linuxcnc will not connect to MESA 7i76e IP Address
What's the IP address of the computer and is the ethernet cable known to be good ?
25 May 2024 23:06 #301451 by tommylight
Probably the same address on the PC, so that might return "connection refused".
Change the 121 at the end to 100.
25 May 2024 23:49 #301454 by RMJ fabrication
I don't know much about networking but when I type "hostname -I"into the terminal to check my computer's IP address I get 192.168.1.121 so they are the same I see now.
  • Platinum Member
  • Platinum Member
26 May 2024 07:16 #301462 by Cant do this anymore bye all
Maybe the Mesa card manuals (if anyone reads them) needs to state that the computer & Mesa card must have different addresses. Or something along these lines. It keeps coming up from time to time.
26 May 2024 12:52 #301474 by rodw
There was a time you had to know about networks but now its all dumbed down via DHCP.
Sounds like you need to watch my video wich goes through this about 16 minutes in
26 May 2024 17:02 #301505 by RMJ fabrication
Okay thank you all this info helps a lot. But simply moving the w3 from down to up will not change the board address to 10.10.10.10 alone. Do I basically have to do step 3 like in this post here to change the board address to 10.10.10.10? forum.linuxcnc.org/12-milling/44860-sett...on-a-mesa-card-7i76e
26 May 2024 17:38 #301508 by tommylight
Yes it will, simply changing the jumper will change the board IP, but that is not your issue, you have to change the PC address as you have already done once when you set the IP to 192.168.1.121, but this time set the last part to anything but 121, so 10 or 100 or 200 will work.
What howto did you use to change the PC IP address? The one you linked is not useful due to many other stuff discussed there.
Time to create page: 0.188 seconds
