Deckel FP4A
- Ginou
30 May 2024 06:55 #301821
by Ginou
Deckel FP4A was created by Ginou
Hello, I'm new to the forum. If possible, I would like help with a parameterization problem. I installed, LinuxCNC2.8 to drive a Deckel FP4A I kept activated the boch Tr15 two-axis dimmer and stepper motor siemens of the time I integrated a leadshine motor and servo motors for the Y axis that is not yet activated.For this I set up a 6i25 7i77 in daughter card 7i78 I flachė all this with 5i25_7i77_7i78.bit successfully.On TB5 are connected and active the XYZ channels of an EXE 805 heindenhane also connected to optical measurement rules.Now Linux, CNC can't display the movements. I have the impression that it is still in demo and that it does not take into account the movement signals. I still have not connected the 7i77 output pins.The emergency stop loop is preserved and operational.Maybe I would have to connect all the relays to activate the axes?Excuse me for this translation from French to English.Thank you very much for your help.I can always give you other information if necessary.Sincerely.Eugene
- Thank you received: 7487
30 May 2024 10:54 #301835
Replied by tommylight on topic Deckel FP4A
Use PncConf to create a new configuration for your machine with 5i25 and 7i77, save, start that config.
Probably will need more editing and tuning, so have a look here, plenty of info on how to wire, test, and tune:
- Ginou
30 May 2024 16:04 #301853
by Ginou
Replied by Ginou on topic Deckel FP4A
Merci beaucoup je vais m’y employer il me faut une marche à suivre pour ne pas faire n’importe quoi.
Je vous tiendrai informé dès que possible des résultats.
Encore merci .
Eugène
Encore merci .
Eugène
- Ginou
31 May 2024 16:09 #301966
by Ginou
bonjour .
hello there I followed the instructions given but my DRO remains inactive however the coders are well taken into account attached to the photo of the open page. I'm stuck at this level
31 May 2024 16:14 #301968
Upload the hal and ini files here so we can have a look.
Do the numbers move on screen when you move the motor by hand?
- Ginou
31 May 2024 16:54 #301974
by Ginou
oui ils bougent etb meme dans les bons sens et-. voici mes fichiers ini et hal.merci
31 May 2024 16:58 #301975
Not good, there is nothing about 7i77 and encoders in those files, just 5i25 with stepgens.
Use the PncConf wizard to create a config for 5i25 with 7i77.
- Ginou
03 Jun 2024 14:13 #302245
by Ginou
hello i come back after several inconclusive tests and with almost always the the same message see photo attached
- Thank you received: 5329
03 Jun 2024 14:50 #302249
Replied by PCW on topic Deckel FP4A
Those errors look like you selected a 5I25+7I76 configuration in pncconf
(the error is because the 7I76 configuration enables 5 stepgens
and you only have 4 in the 7I77+7I78 firmware)
As tommylight said, you should chose 5I25+7I77 in pncconf.
Then get that part working before tackling the 7I78 part
- Ginou
03 Jun 2024 17:46 #302254
by Ginou
Time to create page: 0.151 seconds
