Help required in testing a few fixes to the 2.9.2 install ISO. Linked added
08 Jun 2024 23:29 #302656 by rodw
I'm pretty sure the live build debs are buggy and introduce the raspberry firmware bug that was in Debian 12.0 (fixed in 12.1) even if you are running a later version.
It is therefore best to build live Build from source as described in the live build manualĀ live-team.pages.debian.net/live-manual/html/live-manual/toc.en
The source is much more current than the 02 May 2023 the deb is date stamped.
Note that LB will build for the Debian Version on the host the ISO is built on so be sure your PC is current.
The following user(s) said Thank You: Cant do this anymore bye all
  • Cant do this anymore bye all's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Jun 2024 03:00 #302667 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Help required in testing a few fixes to the 2.9.2 install ISO.
Thanks for the heads up Rod.
The latest Debian Bookworm live-build version works, once a small error in the auto/config is sorted, as mentioned in a previous post.
I built the ISO on Mint 21.3 and got this in .disk/info
Debian GNU/Linux 12 "Bookworm" - Official Snapshot amd64 LIVE/INSTALL Binary 20240606-02:09
When building on Debian Bookworm apart from the date the file has the same info same.
So I can conclude that the ISO can be successfully built on Mint 21.3 with the current Debian live-build package installed.
The build process removes rpi-firmware along with libre-office, this is in the Linuxcnc-live-build-repo, which is where I started the all from.
After installing from the ISO and updating there was no mention of rpi-firmware being an issue, even runnning sudo update-grub
rpi-firmware is still listed, being marked as residual config indicating that it has been removed but theres some files hanging around. ATM I don't think it's an issue.
Just built live build from source using the instructions you linked to and got this package
live-build_20230502_all.deb Built on Mint 21.3 & Debain 12.5 and package is the same. So I guess that we can conclude the package from debian is the most up to date. Unless of course if you are aware of any branches that are more mature.
After checking against the version I have installed:
rmurphy@ThinkPad-T530:~/tmp$ lb --version
20230502
If you have any more info Rod it would be appreciated.
Just to be sure I've used this to install on:
VirtualBox on 2 different machines.
T61 Thinkpad (just to test that it will install) Core2Duo
HP T610 Plus Thinclient (could be a potential candiate for the Lathe)
Acer Aspire D255 Intel Atom (install process went fine not at all a candidate to run a machine only 1GB ram)
T530 ThinkPad, just testing a live session as no free disk space to install
M72e ThinkStation, with a 3rd Gen i5 it is good (another curb find).
2006 ish Intel iMac.....had to let the install have the whole disk, didn't bother investigating dual boot with rEFInd too far. Just want to see if this thing I found on the curb would work.
Asrock J3355b-tx with a 256GB Evo NVMe on a cheap ebay card, does boot directly from the NVMe, bios sees it as a boot disk.
Tested on USB 2.0 flash drives of 4GB & 8GB and USB 3.0 Flash drive of 16GB.
I'm a bit of a hoarder. Don't really want to try the odroid as it's a pain to get to and running the mill and setup sweet.
  • Platinum Member
  • Platinum Member
10 Jun 2024 18:43 #302787 by Cant do this anymore bye all
  • Platinum Member
  • Platinum Member
12 Jun 2024 02:22 #302860 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Help required in testing a few fixes to the 2.9.2 install ISO. Linked added
No interest ? No one got the time ?
30 Jun 2024 20:24 #304111 by tommylight
Had not time to test, but before this goes into the official waters:
-can not contain non official repositories
-must be set to update/upgrade from the main servers, not from local ones
- ... that is it or i am to depraved of sleep, 3:23AM here! :)
  • Platinum Member
  • Platinum Member
30 Jun 2024 20:45 #304115 by Cant do this anymore bye all
I forked the official live build repo, made a change to the kernel command line in grub and made a change in to fix the lower panel.
Didn't touch any repos or anything like that.
Time to create page: 1.126 seconds
