Can't get past "Configuring the Network" Screen on fresh install
29 Jun 2024 16:31 #304031 by jhuth
Hello All,
I had earlier installed the Sherline EMC2 CD software onto this PC desktop... but that preconfigured system is based on the ancient Ubuntu 12.04 LTS and it cannot seem to find network drivers or PCI parallel port.  So am hoping to just install the latest Debian-based version of LinuxCNC from this website.
HOWEVER... Downloaded the latest LinuxCNC_2.9.2-amd64.hybrid.iso and put onto USB stick using Balena Etcher. Attempted multiple times to install onto Lenovo i3-8100 3.6GHz desktop.  Keeps hanging after I enter the information for either WiFi or LAN access... "Configuring the Network" on sceen... no progress beyond that.
Any suggestions about what I'm doing wrong?  Thank you.
29 Jun 2024 17:23 #304035 by andypugh
I think that this happens if your network does not support IPv6.
There is a way to add a command-line parameter to the boot process to turn off ipv6 - "ipv6.disable=1" which may help. (I don't have installer here so can't give more detailed instructions)
The following user(s) said Thank You: jhuth
  • Platinum Member
  • Platinum Member
29 Jun 2024 19:05 #304048 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Can't get past "Configuring the Network" Screen on fresh install
drive.google.com/file/d/1-akVp7OStuMzRxG...Rgi/view?usp=sharing
Here’s a link to an iso that needs testing that attempts to solve that issue
30 Jun 2024 17:38 #304093 by jhuth
Thanks again… tried that ISO this morning. It worked!
The following user(s) said Thank You: Cant do this anymore bye all
  • Platinum Member
  • Platinum Member
30 Jun 2024 21:44 #304100 by Cant do this anymore bye all
Thanks for the feed back, congratulations on being the first to give feedback.
30 Jun 2024 22:09 #304102 by tommylight
Yeah... sorry but had flooding on both shops several days back, so for now out of commission cleaning everything.
30 Jun 2024 23:42 #304105 by andypugh
What did you change? Do you want to submit a pull request to: github.com/LinuxCNC/linuxcnc-live-build ?
01 Jul 2024 00:29 #304107 by rodw
I think he already has
01 Jul 2024 01:25 - 01 Jul 2024 01:26 #304112 by tommylight
Moving this discussion to where it belongs, some requirements mentioned there.
forum.linuxcnc.org/9-installing-linuxcnc...dded?start=10#304111
Last edit: 01 Jul 2024 01:26 by tommylight. Reason: forgot the link
  • Platinum Member
  • Platinum Member
01 Jul 2024 01:47 #304116 by Cant do this anymore bye all
Yep did that, my GitHub name is different to my user name on here. Got am email saying that it had all been accepted.
Time to create page: 0.346 seconds
